meadowsad
Posts: 53 Joined: Sat Jun 15, 2013 9:56 am
Post
by meadowsad » Mon Aug 19, 2013 4:39 pm
So I just got my Reef Angel back from repair, I took this opportunity to add a second pump while I was hooking everything up. I have now 2 Tunze 6095s controlled by the Reef Angel. I am using the same exact code but the pumps are not behaving as expected. When I had one pump it would gradually speed up and slow down. Right now both pumps are turning on and off rapidly. Am I missing something in my code now that I have a second pump? Also when I go to Feeding Mode the pumps stop completely. I am so lost right now, help!
ReefAngel.FeedingModePorts = Port3Bit | Port4Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port5Bit | Port6Bit | Port7Bit;
ReefAngel.DCPump.FeedingSpeed=30;
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.DelayedOn( Port1,1 );
ReefAngel.Relay.DelayedOn( Port2,1 );
ReefAngel.Relay.DelayedOn( Port4,1 );
ReefAngel.StandardHeater( Port7,780,800 );
ReefAngel.StandardATO(Port8,1200);
if (hour()>=0000 && hour()<8)
ReefAngel.DCPump.SetMode( Constant,30,30 );
if (hour()>=8 && hour()<9)
ReefAngel.DCPump.SetMode( Lagoon,30,30 );
if (hour()>=9 && hour()<20)
ReefAngel.DCPump.SetMode( ReefCrest,70,70 );
if (hour()>=20 && hour()<21)
if (hour()>=21 && hour()<2359)
ReefAngel.Portal( "meadowsad" );
Posts: 12857 Joined: Fri Mar 18, 2011 6:47 pm
Post
by rimai » Mon Aug 19, 2013 5:40 pm
Code looks fine.
Did you have the same exact code before?
meadowsad
Post
by meadowsad » Mon Aug 19, 2013 5:52 pm
Yes, same exact code. I had to upload the code again since it looked like you had some test code in there after the repair. I even ran the wizard again and tried the dc pumps in reef crest mode without all the code for the times and it does the same thing.
Another thing I tried was just setting the ports to be always on. The control cable had to be unplugged for this to work. This code has the pumps on all the time, not being controlled, as expected.
ReefAngel.Relay.On( Port2 );
//ReefAngel.Relay.DelayedOn( Port1,1 );
//ReefAngel.Relay.DelayedOn( Port2,1 );
//ReefAngel.DCPump.UseMemory = false;
//ReefAngel.DCPump.SetMode( ReefCrest,70,70 );
//ReefAngel.DCPump.DaylightChannel = Sync;
//ReefAngel.DCPump.ActinicChannel = AntiSync;
mudcat1
Posts: 133 Joined: Sun Dec 09, 2012 7:23 pm
Post
by mudcat1 » Mon Aug 19, 2013 6:53 pm
Meadowsad,
Does the pump start and stop only when the pump speed is set to 30? Try to increase the minimum speed to 40 to see if the pumps no longer stop and start.
meadowsad
Post
by meadowsad » Mon Aug 19, 2013 7:03 pm
I tried with the pumps set at 70 and no luck. I did notice some more weirdness though. After a short amount of time on of the pumps started spinning fine. Then I left to go to the store and when I came back both pumps were off when it should have switched from reef crest to lagoon mode.
meadowsad
Post
by meadowsad » Tue Aug 20, 2013 10:27 am
Is there any code I should try to see if the pumps run normally?
Post
by rimai » Tue Aug 20, 2013 10:56 am
Try removing all the if statements and set the channels to 70% to see what it does
Sent from my SPH-L710 using Tapatalk 4
meadowsad
Post
by meadowsad » Tue Aug 20, 2013 12:42 pm
I removed all the extra code and just had this line
ReefAngel.DCPump.SetMode( ReefCrest,70,20 );
The pumps still turned on and off rapidly.
Post
by rimai » Tue Aug 20, 2013 1:31 pm
No, try setting them to always 70%
ReefAngel.PWM.SetActinic(70);
ReefAngel.PWM.SetDaylight(70);
meadowsad
Post
by meadowsad » Tue Aug 20, 2013 2:50 pm
I used the code below like you suggested and the pumps were spinning while the code was uploading but as soon as it was done the pumps started turning on and off rapidly.
Post
by rimai » Tue Aug 20, 2013 2:53 pm
You mentioned you had a repair done. May I ask what it was??
It sounds like you have the wrong dimming signal.
meadowsad
Post
by meadowsad » Tue Aug 20, 2013 3:06 pm
So now that you mention that...
I had an issue with port 6 turning on and off rapidly on the relay box. In the PM you sent back to me you said there was a defective chip in the head unit and you replaced the chip.
Also I ordered a relay expansion module with box while I waited for my unit to be repaired. Would using the new relay box instead of the original have anything to do with that? I can't be sure which one I am using because I got them mixed up.
Post
by rimai » Tue Aug 20, 2013 3:09 pm
Yes.
You must use the original one.
Post
by rimai » Tue Aug 20, 2013 3:10 pm
The original one will have a sticker "Analog Dimming" at the bottom
meadowsad
Post
by meadowsad » Tue Aug 20, 2013 6:01 pm
Sorry for being an idiot.... lol
Post
by rimai » Tue Aug 20, 2013 9:04 pm
There is no such thing...
