Let's Build Troubadour11's Code
PostPosted: Sun Nov 17, 2019 1:11 pm
rimai wrote:Yes, you can use it.
The only thing you get with the cloud wifi attachment over the one you have is the ability to connect to Uapp without having to setup port forwarding on your router. The cloud feature also lets you stream data so Uapp updates on the fly without having to hit the refresh button on Uapp. Because the connection is always established, the cloud feature is a lot more reliable.
To setup Uapp for the your regular wifi, simply add a controller and make sure you enter the ip address and port and do not enter the cloud credentials. Make sure you setup port forwarding or you won't be able to connect.
Thanks! That was easy. I already had static dns & port-forwarding set up from the wifi-connection and portal anyway. It's running on both my phone and desktop now with no problem.
PostPosted: Thu Nov 21, 2019 7:23 pm
So the Uapp integration went just fine. Again, thank you for the help with getting my RA system caught up to date.
A couple probably quick / easy questions on updating the head-unit.
I've still been manually updating my code by taking a laptop into my fish tank closet and pushing the code up to it via the cable. It seems like that has been left behind in favor of moving the the Web Wizard? Which seems awesome, having access to a code writer and my code library from anywhere. So I'd like to eventually get all my software caught up to the most current / best way to go about doing things. Which is the Web Wizard and the Uapp, correct?
Is there anyway for me to push code updates to the head-unit with the RA+ and Wifi connection? I'm guessing no, but thought I would ask before I just assumed there was no solution. Is the solution probably the cloud function I'm guessing or the blue-tooth connection you don't sell anymore?
My current sketch compiled, uploaded, and runs on my head-unit with no problem via the Ardurino Software and manual upload like when I originally got the RA unit. But when I copy / paste that exact code into the Web Wizard, it fails to compile the loop.
So could you briefly walk me through what the new / best interfaces are that are being supported for working on my system / getting the code adjusted and uploaded. And maybe any hints at why it can compile on "my old way" and why it fails and can't use the Web Wizard to compile? I'm guessing here: but is it a libraries or something issue that I need updated to run things via the Web Wizard now?
I'm in the process of starting to modify my system some and build it after letting it run rock solid for all these years as it was set up. For now, I can make the simple necessary adjustments to the current code and push it up the old way as I just need to modify a couple Relay's and what they run.
But the goal is to get it all up-to-date and easier to adjust / modify via accessing the memory locations and variables instead of always pushing new code.
As always, thanks for the help! It is greatly appreciated!!!
PostPosted: Fri Nov 22, 2019 10:24 pm
Can you post your code?
No, there is no way to update through wifi.
PostPosted: Sun Nov 24, 2019 9:45 am
rimai wrote:Can you post your code?
Absolutely. You will find the code I just pushed up to the head-unit this morning in the next / latest post.
However, I have a more pressing question about the dosing pump memory locations and the offset over the web-wizard code update. It should be pretty simple I hope.
I just received my 2 ATO pumps and got them physically set up (thanks for getting the 2nd one sent out so quickly!) :)
I wanted to run the pumps simultaneously in/out for an AWC system. I hooked them all up, ran a 100 ml timed calibration test, etc.
I want to change 1 gal total per day spread out over 6 runs a day. I need to run each pump 177 and 170 seconds (6 x per day)
In the code I pushed this morning: (both ports removed from "always on" list)
//Sets Port 7 on Power Unit to a dosing pump running on the Repeat and Time function set for Dosing Pump 1 in internal memory
    // Auto Water Change - New Sea Water going in
    ReefAngel.DosingPumpRepeat1(Port7);
    //Sets Port 8 on Power Unit to a dosing pump running on the Repeat and Time function set for Dosing Pump 2 in internal memory
    // Auto Water Change - Old Sea Water going out
    ReefAngel.DosingPumpRepeat2(Port8);
Then I wanted to use the Uapp to set the internal memory for the correct intervals
DP1 Repeat = 240 (in minutes, every 4 hours)
DP1 Timer = 177 (in seconds)
DP2 Repeat = 240 (in minutes, every 4 hours)
DP2 Timer = 170 (in seconds)
I noticed it says in there that DP-2 has a 5 min offset and DP-3 a 10 minute offset. Is this true in the way I have it set up and used?
I had planned to run in/out at the same time drawing from the drain chamber and feeding into the return chamber. I used a gravity fed ATO with Kalk, so lowering the level is not an option. With the way I have it set up, it looks like I might pump my 631 ml of NSW into the system, then 5 minutes offset pull 631 ml back out. Which is ok and better then having set it up the other way and lowering my water level. But I'll have to test if the extra water will constantly cause my skimmer to over-flow. If they were triggered at the same time, the level wouldn't fluctuate as much. But this small of an amount may not be an issue in the long run if that's the best way to do it while utilizing internal memory that I can adjust as needed.
So with how I set it up, will I be getting that offset, or will they both just run at the same time if I set them to the same Repeat Interval?
As a "next-step" to my AWC system. I'd like to make some functions that I can change "x-amount" of water with a push button trigger. Like a pre-programmed 5, 10, 20 gallon water-change using the AWC system. In case I ever need to do a big change for some emergency reason. But first, I just will be thrilled to have it running the 1 gal / day! :P
As always, awesome hardware and thanks for the help! :roll:
Latest code is solo in the next post:
PostPosted: Sun Nov 24, 2019 9:47 am
This compiled and pushed up fine on my laptops Ardurino set up.
//Start of PWM Expansion Code Header
//This is just how we are going to reference the PWM expansion ports within the code.
//You can change the labels if you would like, just as long as they are changed all throughout the code too.
                  //Standard PowerRelay PWM Daylight = L-DT White/Color
                  //Standard PowerRelay PWM Actinic = L-DT Blue/UV
#define LEDPWM0 0 // R-DT = White/Color
#define LEDPWM1 1 // R-DT = Blue/UV
#define LEDPWM2 2 // L-DT = MoonLight
#define LEDPWM3 3 // R-DT = Moonlight
#define LEDPWM4 4 // - EMPTY -
#define LEDPWM5 5 // - EMPTY -
//Initial values to all 6 channels at startup. They will always be 0.
byte PWMChannel[]={0,0,0,0,0,0};
//End of PWM Expansion Code Header
// - Creates a variable to control a "force cloud function" inside a menu.
boolean ForceCloud=false;
//added for custom menu set up
#include <avr/pgmspace.h>
// Create the menu entries
prog_char menu6_label[] PROGMEM = "Date / Time";
prog_char menu7_label[] PROGMEM = "Version";
prog_char menu8_label[] PROGMEM = "Storm Effect";
PROGMEM const char *menu_items[] = {menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label, menu7_label, menu8_label};
// Creating the custom menu fucntions. menu2_label corresponds to MenuEntry2 funtion
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ReefAngel.ATOClear();
void MenuEntry4()
ReefAngel.OverheatClear();
void MenuEntry5()
ReefAngel.SetupCalibratePH();
void MenuEntry6()
ReefAngel.SetupDateTime();
void MenuEntry7()
ReefAngel.DisplayVersion();
// Trying to add a menu to the RA Head Unit so I can trigger a cloud effect on demand.
void MenuEntry8()
ForceCloud=true;
////// Place global variable code below here //////
byte LDT_DaylightPWMValue=0;
byte LDT_ActinicPWMValue=0;
byte LDT_MoonLightANALOGValue=0;
byte RDT_DaylightPWMValue=0;
byte RDT_ActinicPWMValue=0;
byte RDT_MoonLightANALOGValue=0;
////// Place global variable code above here //////
    //This must be the first line.
    ReefAngel.Init();  //Initialize controller
    // Initialize the custom menu
    ReefAngel.AddStandardMenu();  // Add Standard Menu
    ReefAngel.Use2014Screen();  // Let's use 2014 Screen
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit;
    //Ports that are always on
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port5 );
    //ReefAngel.Relay.On( Port6 ); // removed to add delayed start feature to skimmer inside main loop section
      // Port1 = Heater
      // Port2 = Heater
      // Port3 = Refugium Light
      // Port4 = Refugium Pump
      // Port5 = Return Pump
      // Port6 = Protein Skimmer
      // Port7 = Auto Water Change - New Sea Water
      // Port8 = Auto Water Change - Old Sea Water
    ////// Place additional initialization code below here //////
// ***PLEASE HELP HERE********************************************************************************************************************************************
     //Sets values of ALL lighting channels to 0% on Start Up, I think.
     ReefAngel.PWM.SetDaylight(0);
     ReefAngel.PWM.SetActinic(0);
     ReefAngel.PWM.SetChannel(LEDPWM0,0);
     ReefAngel.PWM.SetChannel(LEDPWM1,0);
     ReefAngel.PWM.SetChannel(LEDPWM2,0);
     ReefAngel.PWM.SetChannel(LEDPWM3,0);
     ReefAngel.PWM.SetChannel(LEDPWM4,0);
     ReefAngel.PWM.SetChannel(LEDPWM5,0);
     // I believe using this got rid of my bright flash to 100% when I uploaded new code. Specifically setting the Standard Daylight/Actinic
    ////// Place additional initialization code above here //////
    ReefAngel.StandardHeater(Port1);
    ReefAngel.StandardHeater(Port2);
    ////// Place your custom code below here //////
    //Always on ports that have a delay. These ports will delay turning on for the specified MINUTE_DELAY
      // for: Controller Power Up, Feeding Mode (if toggled on), Water Change Mode (if toggled)
      // This function needs to be place dinside loop() and not inside setup()
      // Usage is DelayedOn (Port6, 5);
    ReefAngel.Relay.DelayedOn(Port6);
    //Sets Port 7 on the Power Unit to a dosing pump running for 5 seconds every 2 hours.
    //ReefAngel.DosingPumpRepeat( Port7,0,120,5 );
    //Set up for Refugium and Phytoplankton light cycle
    //USE THIS TO TOGGLE PORTS ON/OFF - ReefAngel.StandardLight(relay,onhour,onminute,offhour,offminute)
     //Turns Refugium Light plugged into port3 on at 10:30 pm and off at 5:30 am.
     ReefAngel.StandardLights(Port3,22,30,8,30);
                                   //// Calculate your regular sunrise/sunset PWM values ////
 //_____________________________________________________________________________________________________________
    // - Turns RDT - B/UV channel to 0% power between 8:55 p.m. and 10:00 a.m. to conserve energy
    // - Dimming Expansion - LEDPWM1 - RDT Blue/UV -
    // - Parabola dimming 11%-100%-11%
 if ((NumMins(hour(now()),minute(now())) > NumMins(10,00)) && (NumMins(hour(now()),minute(now())) < NumMins(20,55)))
         //RDT_ActinicPWMValue=PWMSlope(10,00,20,55,11,100,240,RDT_ActinicPWMValue);
         RDT_MoonLightANALOGValue=PWMSlope(10,00,20,55,11,100,240,RDT_MoonLightANALOGValue);
         //RDT_ActinicPWMValue=0;
    // - Turns LDT - B/UV channel to 0% power between 9:05 p.m. and 10:15 p.m. to conserve energy
    // - RA Standard Power Unit - LDT Blue/UV -
     if ((NumMins(hour(now()),minute(now())) > NumMins(10,15)) && (NumMins(hour(now()),minute(now())) < NumMins(21,05)))
        //LDT_ActinicPWMValue=PWMSlope(10,15,21,05,11,100,240,LDT_ActinicPWMValue);
        LDT_MoonLightANALOGValue=PWMSlope(10,15,21,05,11,100,240,LDT_MoonLightANALOGValue);
        //LDT_ActinicPWMValue=0;
    // - Turns RDT - W/C channel to 0% power between 8:30 p.m. and 10:25 a.m. to conserve energy
    // - Dimming Expansion - RDT White/Color -
    // - Parabola dimming 11%-50%-11%
     if ((NumMins(hour(now()),minute(now())) > NumMins(10,25)) && (NumMins(hour(now()),minute(now())) < NumMins(20,30)))
        RDT_DaylightPWMValue=PWMSlope(10,25,20,30,11,50,240,RDT_DaylightPWMValue);
    // - Turns LDT - W/C channel to 0% power between 8:45 p.m. and 10:35 a.m. to conserve energy
    // - RA Power Unit - LDT White/Color -
     if ((NumMins(hour(now()),minute(now())) > NumMins(10,35)) && (NumMins(hour(now()),minute(now())) < NumMins(20,45)))
        LDT_DaylightPWMValue=PWMSlope(10,35,20,45,11,50,240,LDT_DaylightPWMValue);
                                   //// Set MoonLights Cycles ////
    //LDT_MoonLightANALOGValue=PWMSlope(10,30,21,00,10,100,240,PWMSlope(21,20,23,15,20,MoonPhase()/5+10,30,LDT_MoonLightANALOGValue=0));
    LDT_ActinicPWMValue=PWMSlope(10,30,21,00,10,100,240,PWMSlope(21,20,23,15,20,MoonPhase()/5+10,30,LDT_ActinicPWMValue=0));
    //RDT_MoonLightANALOGValue=PWMSlope(10,20,20,50,10,100,240,PWMSlope(21,15,23,15,20,MoonPhase()/5+10,30,RDT_MoonLightANALOGValue=0));
    RDT_ActinicPWMValue=PWMSlope(10,20,20,50,10,100,240,PWMSlope(21,15,23,15,20,MoonPhase()/5+10,30,RDT_ActinicPWMValue=0));
    CheckCloud();
    ReefAngel.PWM.SetDaylight(LDT_DaylightPWMValue);
    ReefAngel.PWM.SetActinic(LDT_ActinicPWMValue);
    ReefAngel.PWM.SetChannel(LEDPWM2,LDT_MoonLightANALOGValue);
    ReefAngel.PWM.SetChannel(LEDPWM0,RDT_DaylightPWMValue);
    ReefAngel.PWM.SetChannel(LEDPWM1,RDT_ActinicPWMValue);
    ReefAngel.PWM.SetChannel(LEDPWM3,RDT_MoonLightANALOGValue);
    ////// Place your custom code above here //////
    //Connects Reef Angel Head Unit to the Portal through WiFi Unit.
    ReefAngel.Portal("troubadour11");
  // - My lighting is set up as:
  //      - LDT (Left Display Tank) fixture on the "Standard" 2 (PWM signal) slots on my power relay box.
  //      - RDT (Right Display Tank) fixture on channels 0=daylight and 1=actinic (PWM signal) of the Dimming Expansion.
  //      - Moonlights = channels 2 and 3 of the PWM expansion. These drivers are Analog and the jumper pins have been set for 0-10v Analog in Dimming Expansion.
 // - I'd like to calculate the cloud effect for the LDT lights using the "Weather Sim for Standard PWM" code which I think
 //   I got copied, set up, and working correctly for the 1 fixture on the Standard Ports.
 //                 - Then find a way to feed those values into the RDT lights with a "Random Sample" of + or - a small time offset for the cloud effect on the RDT
 //                                - This way I could randomly generate a weather sim, and randomly have the cloud move Right-to-Left or Left-to-Right each time a cloud occurs
//                  - Lightning effect could either be off set with a similar way with +/- value OR left sync'd to LDT lightning (would need to test what looks good).
//                  - Or possibly more or less lightning per fixture during cloud.
void CheckCloud()
  // I should create a random variable here to randomize the days it has clouds?
#define Clouds_Every_X_Days 1
#define Cloud_Chance_per_Day 50
  // Minimum number of minutes for cloud duration.  Don't use min duration of less than 6.
#define Min_Cloud_Duration 6
#define Max_Cloud_Duration 12
#define Min_Clouds_per_Day 5
#define Max_Clouds_per_Day 15
     // In this example, start could happen after 11:30am
#define Start_Cloud_After NumMins(13,00)
     // In this example, end must be before 6:45pm
#define End_Cloud_Before NumMins(19,45)
  // Percentage chance of lightning happening for every cloud
#define Lightning_Change_per_Cloud 50
  // Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen results could happen.
//____________________________________________________________________________________________________________________________________________________________
  //***Question***
  // Why do you have to double the amount of time from 250 to 500 in your example? - This is just a question to understand the programming better, I don't see why it needs to be doubled.
  // I see it in the code dividing by (numclouds*2), etc. What's the purpose of multiplying it up by 2? I'm just trying to learn on this question if you have time to explain. Thanks :-)
  //#define forcecloudcalculation // Uncomment this to force the cloud calculation to happen in the boot process.
  static byte cloudchance = 255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  //made individual lightningchance for each fixture
  static byte LDTlightningchance=0;
  //static byte RDTlightningchance=0;
  static byte cloudindex=0;
  //made separate lightning status for each fixture
  static byte LDTlightningstatus=0;
  //static byte RDTlightningstatus=0;
  static int LastNumMins=0;
  // - I created this value to use as +/- offset value to make clouds pass left-to-right or vice-versa.
  //static int RDTcloudstartOffset=0;
  // - I added this to use as a randomly chosen value between (-)x to y.
  // - This will be added to "cloudstart" in order to determine the start time of the RDT cloud effect.
  //static byte RDTcloudstart=0;
  // - I added this to create a random sample between 80% and 100% dimming power for "random" lightning intensity effect on each fixture.
  static byte LDT_LightningFlashPower=0;
  static byte RDT_LightningFlashPower=0;
  // - I added these to create a variable to randomize when and how long each lightning strike happens for each cloud.
  //LDTlightningRandomStart=0;
  //LDTlightningLength=0;
  //RDTlightningRandomStart=0;
  //RDTlightningLength=0;
#ifdef forcecloudcalculation
    if (cloudchance==255)
#else
#endif
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        // pick a random number between these values to offset the RDT cloud by this many minutes
        //RDTcloudstartOffset=random(-1,1);
        // adds the random offset value to "cloudstart" and sets the cloudstart time for RDT light fixture
        //RDTcloudstart=cloudstart+RDTcloudstartOffset;
        LDTlightningchance=random(100);
        //RDTlightningchance=random(100);
        // if picked number is greater than Lightning_Change_per_Cloud, we will not have lightning on the next cloud.
        if (LDTlightningchance>Lightning_Change_per_Cloud) LDTlightningchance=0;
        //if (RDTlightningchance>Lightning_Change_per_Cloud) RDTlightningchance=0;
  // Now that we have all the parameters for the cloud, let's create the effect down below.
// Force Cloud from Menu Function jumps to here to start cloud effect immediately for a show!
if (ForceCloud)
ForceCloud=false;
cloudchance=1;
cloudduration=8;
LDTlightningchance=1;
//RDTlightningchance=1;
cloudstart=NumMins(hour(),minute())+2;
//RDTcloudstart=NumMins(hour(),minute())+1;
  // - Controls Cloud and Lightning Effect timings for both fixtures
  if (cloudchance)
    //is it time for cloud yet over Left Display Tank?
      // - Dims LDT to create cloud and back up to Daylight Parabola. - maybe change to 11 in order to make minimum cloud power 11% so the lights don't click off.
      RDT_DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,RDT_DaylightPWMValue,10,180);
      LDT_DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,LDT_DaylightPWMValue,10,180);
      RDT_ActinicPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,RDT_DaylightPWMValue,20,180);
      LDT_ActinicPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,LDT_DaylightPWMValue,20,180);
      RDT_MoonLightANALOGValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,RDT_MoonLightANALOGValue,11,180);
      LDT_MoonLightANALOGValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,LDT_MoonLightANALOGValue,11,180);
      // To adjust possible length of time of lightning strike, Change the "second()< 5 " ... where 5 is the # of seconds of lightning during cloud.
      // and the "minute())=(cloudstart_(cloudduration/2)))" sets start time... dividing by 2 is exactly half way through cloud to trigger 5 seconds lightning.
      // if there is lightning and current time is 1/2 way through cloud, but less then 1/2 way through cloud + 5 seconds
     // if (lightningchance && (NumMins(hour(),minute())==(cloudstart+(cloudduration/LDTlightningRandomStart))) && second()<LDTlightningLength)
      if (LDTlightningchance && (NumMins(hour(),minute())==(cloudstart+(cloudduration/2))) && second()<5)
        if (random(100)<20) LDTlightningstatus=1;
        else LDTlightningstatus=0;
        if (LDTlightningstatus)
               // - This will correctly flash lightning up to 100% power every lightning strike.
          //LDT_DaylightPWMValue=100;
          //LDT_ActinicPWMValue=100;
          // - Trying to make a random sample between, say 80% & 100% for the brightness of the lightning?
          // - If there will be lightning, pick a random number between 80 and 100 for the lightning power.
          LDT_LightningFlashPower=random(80,100);
          RDT_LightningFlashPower=random(80,100);
          RDT_DaylightPWMValue=RDT_LightningFlashPower;
          RDT_ActinicPWMValue=RDT_LightningFlashPower;
          RDT_MoonLightANALOGValue=RDT_LightningFlashPower;
          LDT_DaylightPWMValue=LDT_LightningFlashPower;
          LDT_ActinicPWMValue=LDT_LightningFlashPower;
          LDT_MoonLightANALOGValue=LDT_LightningFlashPower;
          // - Changed these values from 0 to 11 so at end of lightning cycle, the go to min. 11% power
          RDT_DaylightPWMValue=11;
          RDT_ActinicPWMValue=20;
          RDT_MoonLightANALOGValue=11;
          LDT_DaylightPWMValue=11;
          LDT_ActinicPWMValue=20;
          LDT_MoonLightANALOGValue=11;
        delay(1);
      cloudindex++;
      if (cloudindex < numclouds)
//// - I think this resets the random offset and cloudstart time for the RDT Fixture to match the new/next "cloudstart" time if there will be another cloud today ////
      int x=0;
    if (LDTlightningchance)
      int x=0;
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
  //End Cloud & Lighting
PostPosted: Sun Nov 24, 2019 11:27 am
The code not compiling is because we changed a little bit how the menu items are declared.
This should compile:
const char  menu1_label[] PROGMEM = "Feeding";
const char  menu2_label[] PROGMEM = "Water Change";
const char  menu3_label[] PROGMEM = "ATO Clear";
const char  menu4_label[] PROGMEM = "Overheat Clear";
const char  menu5_label[] PROGMEM = "PH Calibration";
const char  menu6_label[] PROGMEM = "Date / Time";
const char  menu7_label[] PROGMEM = "Version";
const char  menu8_label[] PROGMEM = "Storm Effect";
PROGMEM const char * const menu_items[] = {menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label, menu7_label, menu8_label};
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
void MenuEntry4()
void MenuEntry5()
void MenuEntry6()
void MenuEntry7()
void MenuEntry8()
ForceCloud=true;
      // Port1 = Heater
      // Port2 = Heater
    CheckCloud();
void CheckCloud()
  //***Question***
#else
#endif
      if (cloudchance)
if (ForceCloud)
ForceCloud=false;
cloudchance=1;
cloudduration=8;
  if (cloudchance)
        delay(1);
      cloudindex++;
      int x=0;
      int x=0;
  cstart*=60;
  cend*=60;
PostPosted: Sun Nov 24, 2019 11:32 am
In this case, you can use the raw function.
ReefAngel.   DosingPumpRepeat(Port7, 0, InternalMemory.DP1RepeatInterval_read(), InternalMemory.DP1Timer_read());
ReefAngel.   DosingPumpRepeat(Port8, 0, InternalMemory.DP2RepeatInterval_read(), InternalMemory.DP2Timer_read());
The zero in the function is the offset.
DosingPumpRepeat1 basically calls the above function with zero offset and DosingPumpRepeat2 calls it with 5 offset.
PostPosted: Mon Nov 25, 2019 3:38 pm
This worked great. Thank you! :D
The Auto Water Change is up and running with the new pumps as expected!
Thanks again! I'll work on checking out and applying the fixes to move to the Web Wizard update soon. I'm glad it sounds like an easy update to the code.
PostPosted: Sun Mar 22, 2020 2:39 pm
I have a couple horizontal mount float switches that I would like to install and set up a few alerts to let me know when the switches are triggered.
1.) bottom of NewSeaWater barrel in the AWC system to alert when empty and turn off AWC system (2 ports on relay) until cleared
2.) bottom of ATO container to alert when empty and refill needed
3.) I do have a standard float I'd set up in my OldSeaWater barrel in the AWC system as safety measure to alert and turn off the AWC system if the barrel is to full. This would just be a fail-safe back-up to the low-water trigger in the NSW barrel once I have the first two installs working.
Right now I'm not using any of the float switch ports on my RA+.
On the hardware side:
- Is it as simple as installing the switches in place, and then running a pair of wires to bridge
the distance between the RA+ pig-tails plugged into the port?
- Does matter which wire connects to which end of the pig-tail connector at the RA unit?
- Is there a max distance the wires can run between water storage barrels and the head-unit to trigger alerts and turn on/off relay outlets?
On the software side:
I see reference to setting up the WifiAlerts. Which is I think what I need to get going to flag when the float switches triggered. Is there some good existing documentation you can point me to on setting that up? Or give me a point in the right direction for this update.
Thanks for any help! It's been nice slowly adding more helpful tools into my system as it grows and develops. And the community has always been helpful in building the design!
I believe this should be my latest code that I pushed around 11/24/19:
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
void MenuEntry4()
void MenuEntry5()
void MenuEntry6()
void MenuEntry7()
void MenuEntry8()
ForceCloud=true;
      // Port1 = Heater
      // Port2 = Heater
    CheckCloud();
void CheckCloud()
  //***Question***
#else
#endif
      if (cloudchance)
if (ForceCloud)
ForceCloud=false;
cloudchance=1;
cloudduration=8;
  if (cloudchance)
        delay(1);
      cloudindex++;
      int x=0;
      int x=0;
  cstart*=60;
  cend*=60;
PostPosted: Sun Mar 22, 2020 6:19 pm
Yes, you can just splice a pair of wires. There is no polarity and distance shouldn't matter.
You don't need to use the wifi alerts.
You can use the built-in portal alerts for ATO High and ATO Low ports with a condition to be = 1 or > 0. Either should work fine.
PreviousNext
Return to My PDE/INO file
