I have a few questions about your code as I would like to borrow a section or two and incorporate it into my code. You have a lot of custom memory locations, variables defined, etc. that I probably won't need because they relate to your custom main screen, etc. and I don't want to add in stuff I don't need. I was wondering if you could help me select only what I would need for the following features that you use:
1. Custom feeding mode - I would want it just like you have it (minus the reactor control since I have mine off the return pump manifold). I would also like to delay the ATO port for 5 minutes instead of the skimmer... though I can figure that part out myself (just changing the port). But definitely want the VorTechs to Nutrient mode for 15 mins after.
2. Lighting Effects - Does this part give you cloud/lighting effects? Is it set for random or just on-demand via an app or something? I see you have the sun rise/set, moonphase, checkcloud stuff all in there, so I'm guessing you have some sort of storm effects coded in. This is where you have a lot of custom main screen stuff involved and I don't need that since I'm going to use the "2014Screen".
I also noticed that you were active in Colin's thread and talking about converting his "standard dimmer" code over to the expansion dimmer module. Any progress on that?
Any help would be appreciated! Thanks in advance.
