My almost completed pde
- JNieuwenhuizen
Re: My almost completed pde
So using the new Reef Angel Wizard, I now get the moonlights on, but they stay on as the Wizard generates a bit of code like this
If I try adding times toit like the Parabola code, or PWMslop code, it gives me errors.
if (hour()>=22 || hour()<6)
ReefAngel.PWM.SetChannel( 5, 0);
- JNieuwenhuizen
Its working now
Thank You
Thank You
Can you post the code working please? also can you post any pics of the controller?JNieuwenhuizen wrote:Its working now
Thank You
thank you
- JNieuwenhuizen
Hi pilonstar
This code is no more.
Since the PWM module code has been moved to it, my head unit code is as simple as a wizrad generated file, its only the custom main screens, and that is still a work in progress.
As soon as everything works, I'll paste the code for you
- JNieuwenhuizen
I have re-done my code in the next Memory and versions upgrades..
I got rid off all the extra screens, and the unwanted stuffs, as I did not use them.
Now, my menus dont work.. what did I do wrong?
My new code
My new code
//--------------------------------------------------------------------- Start of Global Variables ---------------------------------------------------------------------------
bool fOverrideRF = false;
byte vtechmode = 0;
boolean bFeeding=false;
byte x,y;
byte TempRelay =15;
byte TempRelay2=15;
//------------------------------------------------------------------------------- Custom Main -------------------------------------------------------------------------------
void DrawCircleOutline(byte x, byte y, byte radius, byte bordercolor);
void FillCircle(byte x, byte y, byte radius, byte fillcolor);
void DrawCircleOutletBox(byte x, byte y, byte RelayData, bool reverse = false);
//----------------------------------------------------------------------- Custom Menu Code ----------------------------------------------------------------------------------
#include <avr/pgmspace.h>
prog_char menu0_label[] PROGMEM = "Food";
prog_char menu1_label[] PROGMEM = "Cleanup";
prog_char menu2_label[] PROGMEM = "ATU Clear";
prog_char menu3_label[] PROGMEM = "pH";
prog_char menu4_label[] PROGMEM = "Salinity";
prog_char menu5_label[] PROGMEM = "Sump On";
prog_char menu6_label[] PROGMEM = "Sump Off";
prog_char menu7_label[] PROGMEM = "Item 8";
prog_char menu8_label[] PROGMEM = "Date/Time";
menu0_label, menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label, menu7_label, menu8_label };
void MenuEntry1()
ReefAngel.DisplayMenuEntry("Item 1");
ReefAngel.FeedingModeStart();
void MenuEntry2()
ReefAngel.DisplayMenuEntry("Item 2");
void MenuEntry3()
ReefAngel.DisplayMenuEntry("Item 3");
ReefAngel.ATOClear();
void MenuEntry4()
ReefAngel.DisplayMenuEntry("Item 4");
ReefAngel.SetupCalibratePH();
void MenuEntry5()
ReefAngel.DisplayMenuEntry("Item 5");
ReefAngel.SetupCalibrateSalinity();
void MenuEntry6()
ReefAngel.DisplayMenuEntry("Item 6");
ReefAngel.Relay.RelayMaskOn = ReefAngel.LightsOnPorts;
#ifdef RelayExp
ReefAngel.Relay.RelayMaskOnE[i] = ReefAngel.LightsOnPortsE[i];
#endif // RelayExp
ReefAngel.Relay.Write();
void MenuEntry7()
ReefAngel.DisplayMenuEntry("Item 7");
ReefAngel.Relay.RelayMaskOn = 0;
#ifdef RelayExp
ReefAngel.Relay.RelayMaskOnE[i] = 0;
#endif // RelayExp
void MenuEntry8()
ReefAngel.DisplayMenuEntry("Item 8");
if (!fOverrideRF && vtechmode == 9)
vtechmode=0;
ReefAngel.RF.SetMode(Feeding_Stop,0,0); //Temp fix for coming out of Night mode
vtechmode++;
fOverrideRF = true;
if ( vtechmode == 7 ) vtechmode = 9;
if ( vtechmode > 9 ) {
vtechmode = 0;
// 1st parameter is Mode, 2nd is speed, 3rd is duration
void MenuEntry9()
ReefAngel.DisplayMenuEntry("Item 9");
ReefAngel.SetupDateTime();
int x,y;
//Top Banner
ReefAngel.LCD.DrawLargeText(COLOR_WHITE, COLOR_CORNFLOWERBLUE, 0, 1, " Drop Reef Tank ", Font8x8); //Top Banner
// Display T1 Header Text
ReefAngel.LCD.DrawLargeText(COLOR_STEELBLUE,255,5,15,"Sump Temp", Font8x8);
// Display the T1 Temp Value
char text[7];
ReefAngel.LCD.Clear(255, 10, 25, 50, 60);
if (ReefAngel.Params.Temp[T1_PROBE]>290) ReefAngel.LCD.DrawHugeNumbers(COLOR_RED, 255, 10, 25, text);
else if (ReefAngel.Params.Temp[T1_PROBE]>270) ReefAngel.LCD.DrawHugeNumbers(COLOR_ORANGE, 255, 10, 25, text);
else ReefAngel.LCD.DrawHugeNumbers(COLOR_MIDNIGHTBLUE, 255, 10, 25, text);
// Display the T2 Header Text
ReefAngel.LCD.DrawLargeText(0,255,5,45,"Room Temp", Font8x8);
// Display the T2 Temp Value
ReefAngel.LCD.Clear(255, 90, 50, 132, 60);
ConvertNumToString(text, ReefAngel.Params.Temp[T2_PROBE], 10);
ReefAngel.LCD.DrawLargeText(COLOR_MIDNIGHTBLUE, 255, 90, 45, text, Num8x8);
// Display pH Header Text
ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,95,15,"pH", Font8x8);
// Display pH Value
ReefAngel.LCD.Clear(0, 65, 62 , 65, 62);
if (ReefAngel.Params.PH>840 || ReefAngel.Params.PH<790) ReefAngel.LCD.DrawLargeText(COLOR_RED, 255, 85, 25, text, Num8x8);
else if (ReefAngel.Params.PH>830 || ReefAngel.Params.PH<800) ReefAngel.LCD.DrawLargeText(COLOR_ORANGE, 255, 85, 25, text, Num8x8);
else ReefAngel.LCD.DrawLargeText(COLOR_MIDNIGHTBLUE, 255, 85, 25, text, Num8x8);
//------------------------------------------------------------------ Display Vortech Mode ------------------------------------------------------------------------------------
ReefAngel.LCD.DrawLargeText(0,255,5,55,"Vortech", Font8x8);
//---------------------------------------------------------------- Display EcoSmart Mode Value -------------------------------------------------------------------------------
ReefAngel.LCD.Clear(255, 66, 60, 132, 70);
if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255, 66, 55,"Constant");
else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255, 66, 55,"Lagoon");
else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255, 80, 55,"RCM");
else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255, 80, 55,"Short");
else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255, 66, 55,"Long");
else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255, 80, 55,"NTM");
else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255, 80, 55,"TSM");
else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_GRAY,255, 80, 55,"Night");
//------------------------------------------------------------------- Display Salinity ---------------------------------------------------------------------------------------
ReefAngel.LCD.DrawLargeText(0,255,64,114,"Salinity", Font8x8);
//----------------------------------------------------------------- Display Salinity Value -----------------------------------------------------------------------------------
ReefAngel.LCD.Clear(255, 82, 85, 65, 95);
ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 85, 122, text, Num8x8);
//-----------------------------------------------------------Start Moon Phase,Cloud or Storm Display---------------------------------------------------------------------------
/* if (ReefAngel.PWM.Channel[5] > 0);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,70,105,MoonPhaseLabel());
if (ReefAngel.PWM.ExpansionChannel[0] > 0 && (hour() < 14 ) )
ReefAngel.LCD.DrawLargeText(COLOR_ORANGERED,255,3,65, "Sunrise",Font8x8);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,3,75, ReefAngel.PWM.ExpansionChannel[0]);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,20,74, ":");
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,24,75, ReefAngel.PWM.ExpansionChannel[1]);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,41,74, ":");
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,45,75, ReefAngel.PWM.ExpansionChannel[2]);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,66,75, "|");
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,70,75, ReefAngel.PWM.ExpansionChannel[3]);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,87,74, ":");
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,91,75, ReefAngel.PWM.ExpansionChannel[4]);
else if (ReefAngel.PWM.ExpansionChannel[0] > 0 && (hour() > 14 ))
//---------------------------------------------------------- Display Main and Expansion Relay Box -----------------------------------------------------------------------------
TempRelay = ReefAngel.Relay.RelayData;
ReefAngel.LCD.DrawCircleOutletBox(10,90, TempRelay);
TempRelay2 = ReefAngel.Relay.RelayDataE[0];
TempRelay2 &= ReefAngel.Relay.RelayMaskOffE[0];
TempRelay2 |= ReefAngel.Relay.RelayMaskOnE[0];
ReefAngel.LCD.DrawCircleOutletBox(40,90, TempRelay2);
ReefAngel.WaterChangePorts = Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit | Port3Bit;
ReefAngel.LightsOnPortsE[0] = Port4Bit;
ReefAngel.OverheatShutoffPorts = Port5Bit | Port6Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port7 );
ReefAngel.Relay.DelayedOn( Port2 );
ReefAngel.StandardHeater( Port5 );
ReefAngel.StandardATO( Box1_Port5 );
ReefAngel.MoonLights( Box1_Port4 );
//------------------------------------------------------------------ Start Time-of-Day Based Functions ----------------------------------------------------------------------
//~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ These are the mode numbers for the RF Expansion Module for reference ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
//#define Constant 0
//#define Random1 1 // Lagoonal
//#define Random2 2 // Reef Crest
//#define ShortWave 3
//#define LongWave 4
//#define Smart_NTM 5 // Nutrient Transport Mode
//#define Smart_TSM 6 // Tidal Swell Mode
//#define Feeding_Start 7
//#define Feeding_Stop 8
//#define Night 9
//#define Slave_Start 97
//#define Slave_Stop 98
//#define None 99
//----------------------------------------------------------------- Start RF Daytime Control ------------------------------------------------------------------------------
if (!fOverrideRF)
if (hour() >8 && hour() < 14)
ReefAngel.RF.UseMemory=false;
ReefAngel.RF.SetMode(Smart_NTM,80,7);
vtechmode = Smart_NTM;
else if (hour() >14 && hour() < 22)
ReefAngel.RF.SetMode(Random2,60,7);
vtechmode = Random2;
//--------------------------------------------------------------- Start RF Nightmode Control -----------------------------------------------------------------------------
else if (hour()>=22 || hour()<8) // Defining "Nightmode" hours for VorTech = between 10 PM and 8 AM
ReefAngel.RF.SetMode(Night,10,0);
vtechmode = Night;
ReefAngel.RF.SetMode(vtechmode, InternalMemory.RFSpeed_read(), InternalMemory.RFDuration_read());
ReefAngel.Portal( "JNieuwenhuizen" );
You are missing one line in the setup() section:
- JNieuwenhuizen
Thanx Roberto!
