here is my memory file:
// Autogenerated file by RAGen (v1.2.2.171), (04/22/2012 16:08)
// Memory_042212_1608.ino
#include <avr/pgmspace.h>
RA_NokiaLCD e;
e.Init();
e.BacklightOn();
InternalMemory.MHOnHour_write(0);
InternalMemory.MHOffHour_write(0);
InternalMemory.StdLightsOnHour_write(8);
InternalMemory.StdLightsOffHour_write(22);
InternalMemory.WM1Timer_write(200);
InternalMemory.LEDPWMDaylight_write(0);
InternalMemory.LEDPWMActinic_write(0);
InternalMemory.PHMin_write(539);
InternalMemory.DP1RepeatInterval_write(0);
InternalMemory.DP2RepeatInterval_write(0);
InternalMemory.PWMSlopeStartD_write(15);
InternalMemory.PWMSlopeEndD_write(100);
InternalMemory.PWMSlopeDurationD_write(60);
InternalMemory.PWMSlopeStartA_write(15);
InternalMemory.PWMSlopeEndA_write(100);
InternalMemory.RFMode_write(0);
InternalMemory.RFSpeed_write(100);
InternalMemory.PWMSlopeStart0_write(15);
InternalMemory.PWMSlopeEnd0_write(100);
InternalMemory.PWMSlopeDuration0_write(60);
InternalMemory.PWMSlopeStart1_write(15);
InternalMemory.PWMSlopeEnd1_write(100);
InternalMemory.PWMSlopeDuration1_write(60);
InternalMemory.PWMSlopeStart2_write(15);
InternalMemory.PWMSlopeEnd2_write(100);
InternalMemory.PWMSlopeDuration2_write(60);
InternalMemory.PWMSlopeStart3_write(15);
InternalMemory.PWMSlopeEnd3_write(100);
InternalMemory.PWMSlopeDuration3_write(60);
InternalMemory.PWMSlopeStart4_write(15);
InternalMemory.PWMSlopeEnd4_write(100);
InternalMemory.PWMSlopeDuration4_write(60);
InternalMemory.PWMSlopeStart5_write(15);
InternalMemory.PWMSlopeEnd5_write(100);
InternalMemory.PWMSlopeDuration5_write(60);
// display success screen
e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*5, " RA code file");
delay(5000);
// Autogenerated file by RAGen (v1.2.1.158), (02/17/2012 22:55)
// Current Prod Code
#define wifi
#define SIMPLE_MENU
#define RelayExp
#define IOEXPANSION
ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port8Bit; // Turn off Port 5, Port 6, Port8 when feeding mode is activated
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port7Bit | Port8Bit; // Turn off Port5, Port6, Port7 and Port8 when water change mode is activated
ReefAngel.TempProbe = T2_PROBE; // Set the 1st plug (which acts like the 2nd plug)
ReefAngel.OverheatProbe = T2_PROBE; // to monitor the overheat and temperatures
ReefAngel.Relay.On(Port8); // Turn on Pump
// Specific functions
ReefAngel.StandardLights(Port2,8,00,23,00); // Regular Lights on at 8:00am and off at 11:00pm
ReefAngel.StandardLights(Port3,00,30,03,30); // Moon Lights on at 12:30am and off at 3:30am
ReefAngel.StandardLights(Port4,23,30,14,30); //Refugium schedule 11:30pm - 2:30pm
ReefAngel.Wavemaker1(Port5);
ReefAngel.Wavemaker2(Port6);
ReefAngel.WavemakerRandom(Port5,15,60); // Turn Port5 on/off random cycles that lasts from 15 to 60 secs
ReefAngel.Relay.Set(Port6,!ReefAngel.Relay.Status(Port5)); // Turn Port6 on/off on opposite cycle as Port 5
// Port 5 and 6 are synchronized.
// They work in opposing motion of each other at random times.
// turn on port 7 when temp falls below 76.0 and turn off when temp gets above 80.0
if (ReefAngel.Params.Temp[T2_PROBE] <= 780 && ReefAngel.Params.Temp[T2_PROBE] > 0) ReefAngel.Relay.On(Port7);
if (ReefAngel.Params.Temp[T2_PROBE] >= 791) ReefAngel.Relay.Off(Port7);
if (ReefAngel.Params.Temp[T1_PROBE] <= 780 && ReefAngel.Params.Temp[T1_PROBE] > 0) ReefAngel.Relay.On(Port1);
if (ReefAngel.Params.Temp[T1_PROBE] >= 791) ReefAngel.Relay.Off(Port1);
ReefAngel.Portal("rossbryant1956");
What am I missing. Thx
