I keep getting an error:// Autogenerated file by RAGen (v1.2.2.171), (05/28/2012 19:48)
// RA_052812_1948.ino
#define DisplayImages
#define WavemakerSetup
#define DateTimeSetup
#define VersionMenu
#define ATOSetup
#define MetalHalideSetup
#define DisplayLEDPWM
#define wifi
#define StandardLightSetup
#define PWMEXPANSION
#define AI_LED
ReefAngel.Relay.On(Port8);
ReefAngel.AI.SetPort(highATOPin);
ReefAngel.StandardATO(Port1);
ReefAngel.MHLights(Port3);
ReefAngel.StandardFan(Port4);
ReefAngel.Wavemaker1(Port5);
ReefAngel.Wavemaker2(Port6);
if (hour()>=22 || hour()<10)
ReefAngel.AI.SetChannel(White,0);
ReefAngel.AI.SetChannel(Blue,MoonPhase()*0.07);
ReefAngel.AI.SetChannel(RoyalBlue,MoonPhase()*0.07);
ReefAngel.AI.SetChannel(White,PMWSlope(10,0,21,0,3,30,200,3));
ReefAngel.AI.SetChannel(Blue,PMWSlope(10,0,21,0,3,30,200,3));
ReefAngel.AI.SetChannel(RoyalBlue,PMWSlope(10,0,21,0,3,30,200,3));
// This sends all the data to the portal
// Do not add any custom code that changes any relay status after this line
// The only code after this line should be the ShowInterface function
ReefAngel.Portal("blawson", "XXXXXXXX");
Test_PMW.cpp: In function 'void loop()':
Test_PMW:81: error: 'PMWSlope' was not declared in this scope
I know I have a lot of work on this code - but want to get the slope right first. I need help with the error and then I want to understand what the parameters are for the slope:
I am decent at understanding coding but I cannot find a list of parameters for this.
Any help will be appreciated!
Brian
