Pre loaded code
Re: Pre loaded code
I got the same results.
That code is so old and has not been updated with everything that has been developed since.
It's got to be something that has been updated on the new Arduino IDE or our libraries and I'm not going to even try to find what the problem is.
I have a compiled version of that code that will work though.
Unzip the file and open the file loadReefAngelSimple.bat on notepad.
Change the COM3 to whatever serial port you are using.
Save the file and double-click to execute it.
Let me know if you have problems.
- ReefAngelSimple.zip
- (437.31 KiB) Downloaded 483 times
Re: Pre loaded code
Sorry to be a pain. Cant load it. Im getting "The program can't start because libusb0.dll is missing from your computer. Try reinstalling the program to fix this problem."
Re: Pre loaded code
I guess you need an older version of avrdude too.
Try this one.
Try this one.
- (601.51 KiB) Downloaded 444 times
Re: Pre loaded code
I think the only way is to use an older release of everything.
http://www.reefangel.com/files/reefangelinstaller.exe
The current preloaded code has almost everything the other one had it though.
Why do you want to use the old code?
Re: Pre loaded code
The one I loaded from Arduino has almost nothing the old one had. I just liked the ability to adjust my light intensity from the main menu. Plus it just looked better. I plan on writing my own anyway, I just liked the idea I could fall back on the old code until I can devote enough time to learn how to write my own.
Re: Pre loaded code
The current preloaded code has it too.
Download the user manual which explains each menu. It would be Lights->LED PWM
Re: Pre loaded code
I couldnt figure that out, but I will try again. Thanks for all your help.
Re: Pre loaded code
Should I do that through the Arduino program, or the RAgen?
Re: Pre loaded code
Great thanks again Roberto.
