The latest Cloud and Lightning code is here.
This is the original code for fast drivers and the dimming ports on the relay.
viewtopic.php?f=12&t=4783
Then it was modified to work on slower drivers and the dimming expansion module.
viewtopic.php?f=12&t=5460
Weather Simulation for Dimming expansion module
Does the weather simulation pick a random day and time of the month to actually fire or is it every day or set in code based on us?
What I am wondering is if it is possible to switch the DC pump(s) to full during the storm then reset back to normal mode. I wouldn't want this happening every day but one or twice a month would be pretty cool to swoosh stuff around. May even be better than my turkey baster ![]() |
It should be fairly easy to add some powerhead action. Was thinking about this yesterday actually. If I get to add it, I'll post my results.
Hate to ask this, but does the weather simulation library also simulate lighting?
I added the code this morning and have been toying with it when about an hour into post loading the code lights dimmed, assuming cloud, then all of a sudden flashed several quick successions with my blue channels being mostly called. Threw me for a loop but figured I'd ask. I'm going to assume it does but wanted to be sure in case my multi chip can't handle it or I have to edit a value somewhere that maybe I missed. The example I was using as a reference had it called as: Global variable: byte PWMChannel[6]; CheckCloud(); ReefAngel.PWM.SetChannel(0,PWMChannel[0]); ReefAngel.PWM.SetChannel(1,PWMChannel[1]); ReefAngel.PWM.SetChannel(2,PWMChannel[2]); ReefAngel.PWM.SetChannel(3,PWMChannel[3]); |
Yes. You can modify the lightning chance and frequency in the defines above the CheckCloud function you added
Thanks. That got me to the correct location and I was able to modify. Also found an error in the code that was causing the RW's to run at 100% rather than the 40 like I thought. Thanks for the information. |
has this been done yet the full power overide for storm chance for dc pump |
lee did you guys find out to add the powerheads into the storm deal? |
Colin was looking at it
