Page 6 of 7
Re: Weather Simulation for Dimming expansion module
Posted: Tue Mar 11, 2014 2:33 pm
by Sacohen
Lee;
So your Moon class will simulate the actual moon cycles, where the MoonPhase() will just do a moon rise and set according to the time I set, correct?
Posted: Tue Mar 11, 2014 3:47 pm
Correct the Moon class gives you rise and set times based on the gos coordinate. I dont think it lines up right because we dont adjust for timezone and RA thinks it is GMT. But otherwise provides a very nice rhythm of moon rise and set.
Posted: Tue May 27, 2014 11:01 am
by morn623
I just wanted to confirm this simulation will not work on the newer version of the dimming expansion and has not yet been coded for the head unit? Thanks!
Posted: Tue May 27, 2014 1:05 pm
Correct.
It should not be that much work to port it to the head unit. I don't have a dimming setup where I could try though.
Posted: Wed May 27, 2015 12:58 am
by JoelIreland
Hey all
I have just got a retro kit from Steve's LEDs for my Red Sea Max 650.
I have installed the kit and now want to add the dimmer expansion module to control sunrise sunset ( in Australia )
I already have the module and have been following this thread. The issue I am having is when i plug the module in to the PC to upload the code, it comes up with either faulty or unknown USB Device.
I run an IT company so this sort of thing is second nature but still having issues with it.
Am i meant to be plugging into the mini usb port or opening up the controller and plugging in there as there no instructions on this.
Thanks all
Joel
Posted: Wed May 27, 2015 5:52 am
by Sacohen
What are you trying to load the code to, the dimming module of the RA head unit?
Code only get uploaded to the RA head unit all other devices receive their commands from the head unit.
Instructions for all the devices can be found on the RA website.
Choose Downloads and then manuals.
http://www.reefangel.com/download.aspx)
Posted: Wed May 27, 2015 6:54 am
by JoelIreland
Sorry I was reading about how some load the sunrise sunset direct to dimmer module. Have had RA for few years so know the basic, just first time working with dimmer side. I have it working using the PWN function with parabola but for some weird reason say 100 will turn LEDs off but -100 will make bring and -150 brighter so seems to be in reverse. Wires are in correct place too.
Posted: Sun Jul 12, 2015 11:25 am
by saf1
morn623 wrote:I just wanted to confirm this simulation will not work on the newer version of the dimming expansion and has not yet been coded for the head unit? Thanks!
Oh, this code / library no longer works? Not sure what the newer version of the dimming expansion is though. I just installed one about a month back but not tried the weather module. Was looking at it this morning when I came across this note so figured I'd ask.
Posted: Sun Jul 12, 2015 4:14 pm
This has pretty much been replaced by the SunLocation class plus the Cloud and Lightning effects. I just realized if we add the seasonal temperature code, we'd be in a really cool position. Plus I just thought of something awesome... I have to look at the temp one to see if it makes sense. I think we can make that one much easier to implement and customize.
Posted: Sun Jul 12, 2015 4:28 pm
by Rodasphoto
lnevo wrote:This has pretty much been replaced by the SunLocation class plus the Cloud and Lightning effects. I just realized if we add the seasonal temperature code, we'd be in a really cool position. Plus I just thought of something awesome... I have to look at the temp one to see if it makes sense. I think we can make that one much easier to implement and customize.
So how would one code for cloud, lightening, etc. ?
Posted: Sun Jul 12, 2015 4:32 pm
by Sacohen
The latest Cloud and Lightning code is here.
This is the original code for fast drivers and the dimming ports on the relay.
http://forum.reefangel.com/viewtopic.php?f=12&t=4783
Then it was modified to work on slower drivers and the dimming expansion module.
http://forum.reefangel.com/viewtopic.php?f=12&t=5460
Posted: Thu Jul 23, 2015 8:25 pm
by saf1
Does the weather simulation pick a random day and time of the month to actually fire or is it every day or set in code based on us?
What I am wondering is if it is possible to switch the DC pump(s) to full during the storm then reset back to normal mode. I wouldn't want this happening every day but one or twice a month would be pretty cool to swoosh stuff around. May even be better than my turkey baster
Posted: Fri Jul 24, 2015 4:46 am
It should be fairly easy to add some powerhead action. Was thinking about this yesterday actually. If I get to add it, I'll post my results.
Posted: Wed Sep 02, 2015 11:49 am
by saf1
Hate to ask this, but does the weather simulation library also simulate lighting?
I added the code this morning and have been toying with it when about an hour into post loading the code lights dimmed, assuming cloud, then all of a sudden flashed several quick successions with my blue channels being mostly called. Threw me for a loop but figured I'd ask.
I'm going to assume it does but wanted to be sure in case my multi chip can't handle it or I have to edit a value somewhere that maybe I missed.
The example I was using as a reference had it called as:
Global variable:
byte PWMChannel[6];
CheckCloud();
ReefAngel.PWM.SetChannel(0,PWMChannel[0]);
ReefAngel.PWM.SetChannel(1,PWMChannel[1]);
ReefAngel.PWM.SetChannel(2,PWMChannel[2]);
ReefAngel.PWM.SetChannel(3,PWMChannel[3]);
Posted: Sat Sep 05, 2015 6:22 am
Yes. You can modify the lightning chance and frequency in the defines above the CheckCloud function you added
Posted: Mon Sep 07, 2015 7:56 am
by saf1
lnevo wrote:Yes. You can modify the lightning chance and frequency in the defines above the CheckCloud function you added
Thanks. That got me to the correct location and I was able to modify. Also found an error in the code that was causing the RW's to run at 100% rather than the 40 like I thought.
Thanks for the information.
Posted: Tue Apr 19, 2016 8:31 am
by troylong45
saf1 wrote:Does the weather simulation pick a random day and time of the month to actually fire or is it every day or set in code based on us?
has this been done yet the full power overide for storm chance for dc pump
Posted: Thu Apr 21, 2016 5:24 pm
by troylong45
lnevo wrote:It should be fairly easy to add some powerhead action. Was thinking about this yesterday actually. If I get to add it, I'll post my results.
lee did you guys find out to add the powerheads into the storm deal?
Posted: Thu Apr 21, 2016 5:25 pm
by troylong45
Posted: Thu Apr 21, 2016 9:21 pm
Colin was looking at it
