Vortech code problem, it works well only if...
stephy
Post by stephy »
...I manually place the pump in feed mode. It works perfectly, but everydayI have to use feed mode, or after night cycle, pump change mode (led on rf module is the right color, no blinking the vortech controller), but stays in feed mode (minimum speed). If I enter twice in feed mode, pump works until next morning...
  ReefAngel.AddDateTimeMenu();
  // ReefAngel.AddWifi ();
  InternalMemory.OverheatTemp_write( 309 );
  ReefAngel.Relay.On( Port4 );
  ReefAngel.LCD.DrawLargeText(COLOR_STEELBLUE,COLOR_WHITE,28,121,"Tinozzina"); // Display Reef Angel banner
  ReefAngel.StandardLights( Port1,10,0,22,0 );
  ReefAngel.StandardLights( Port2,11,0,21,0 );
  ReefAngel.Relay.Set( Port3, !ReefAngel.Relay.Status( Port2 ) );
  ReefAngel.StandardHeater( Port5,252,256 );
  ReefAngel.StandardFan( Port6,255,259 );
  if (hour()>=21 || hour()<11)
    ReefAngel.PWM.SetActinic( 0 );
if ( ReefAngel.RF.Mode != Feeding_Start)
if (hour()==10)
ReefAngel.RF.SetMode( Lagoon,60,10 );
else if (hour()==11 && minute()<5)
ReefAngel.RF.SetMode( Constant,90,10 );
else if (hour()==13)
ReefAngel.RF.SetMode( Smart_NTM,90,3 );
else if (hour()==19 && minute()<5)
else if (hour()==20)
else if (hour()==21)
else if (hour()>=22 || hour()<10)
ReefAngel.RF.SetMode( Night,60,10 );
ReefAngel.RF.SetMode( ReefCrest,70,10 );
  ReefAngel.Portal( "stephy" );
Stephy
stephy
Re: Vortech code problem, it works well only if...
Post by stephy »
Solved, tnx :-)
Stephy
