custom main and new libraries
psyrob
Post by psyrob »
How do I use the custom main screen I had before the library update? I tried just cutting and pasting my old code into the new one I generated with the Wizard and it won't compile. I notice there is no define section any more at the top of my ino file like before...
Re: custom main and new libraries
You should be able to just copy and paste.
Post the code and I can help.
psyrob
Post by psyrob »
I got it to work...I was missing a "{" at the end of one of my cuts....
However, can you look at this code: I had this working to display the time of the wavemaker in seconds, and while it worked before, it now displays a number in the thousands, like 1321, even as the wavemaker alternates back and forth in 35 to 50 seconds..
//July 7, 2012, first try with the new 1.0.0 libraries
    ReefAngel.LCD.DrawDate(6, 120);
  ReefAngel.LCD.DrawLargeText(COLOR_DARKTURQUOISE, COLOR_WHITE, 4, 4 , "ROB'S REEF ANGEL");
  ReefAngel.LCD.Clear(COLOR_MAROON, 1, 13, 132, 13);
  ReefAngel.LCD.Clear(COLOR_MAROON, 10, 75, 119, 75);
  ReefAngel.LCD.Clear(COLOR_MAROON, 10, 59, 119, 59);
  ReefAngel.LCD.DrawLargeText(COLOR_GOLDENROD, COLOR_WHITE, 8, 15, "Big Tank");
  char text[7];
  ReefAngel.LCD.DrawLargeText(COLOR_GOLDENROD, DefaultBGColor, 18, 28, text);
  ReefAngel.LCD.DrawText(COLOR_RED, COLOR_WHITE,8,48,"Frag:");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], COLOR_RED, 40, 48, 10);
  ReefAngel.LCD.DrawText(COLOR_DARKORCHID, COLOR_WHITE,8,39,"Room:");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], T2TempColor, 40, 39, 10);
  ReefAngel.LCD.DrawLargeText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 92, 15, "pH");
  ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, 88, 28, text);
      ReefAngel.LCD.DrawText(DPColor,DefaultBGColor, 5, 64,"WAVE FLOW:");
        if (bitRead(ReefAngel.Relay.RelayData,Port5-1)==1) ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 67, 64,"----->"); //port 5 on
        else if (bitRead(ReefAngel.Relay.RelayData,Port6-1)==1) ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 67, 64,"<-----");  //port 6 on
        //else ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 67, 64," 00000 "); //port5 and port 6 off, wavemaker delay: taken away for the moonlights July 2nd
        //show the timer for wavemaker
        int t=ReefAngel.Timer[1].Trigger-now();
        if (t>=0)
        ReefAngel.LCD.Clear(255,105,64,135,74);
        ReefAngel.LCD.DrawText(APColor, COLOR_KHAKI,110,64,t);
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,10,79,"Actinic");
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,10,89,"FragLt");
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,10,99,"WM RT");
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,10,109,"Fan");
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,79,"ATO");
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,89,"DayLts");
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,99,"WM LFT");
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,109,"Heater");
  ReefAngel.LCD.DrawCircleOutletBox(60, 81, TempRelay, true);
    ReefAngel.WaterChangePorts = Port5Bit | Port6Bit;
    ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port7Bit;
    ReefAngel.DayLights( Port1 );
    ReefAngel.ActinicLights( Port2 );
    ReefAngel.DayLights( Port3 );
    ReefAngel.DayLights( Port4 );
    //ReefAngel.Wavemaker1( Port5 );
    //ReefAngel.Wavemaker1( Port6 );
    ReefAngel.StandardFan( Port8 );
    if ( (hour()>=7 && hour()<22))
          ReefAngel.WavemakerRandom(Port5,35,50); // Turn Port5 on/off random cycles that lasts from 36 to 50 secs
          ReefAngel.Relay.Set(Port6,!ReefAngel.Relay.Status(Port5)); // Turn Port6 on/off on opposite cycle as Port 5
        // Port 5 and 6 are synchronized.
         // They work in opposing motion of each other at random times.
          ReefAngel.Relay.Off(Port5);
          ReefAngel.Relay.Off(Port6);
         } //Wavemaker on from 7 am to 10 pm, Off there after
    ReefAngel.Portal( "psyrob" );
Oh, it's been a while since we don't use the Timer[1] anymore.
Try this:
time_t WMRTimer=now();
  char text[7];
  //else ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 67, 64," 00000 "); //port5 and port 6 off, wavemaker delay: taken away for the Moonlights July 2nd
  int t=WMRTimer-now();
  if (t>=0)
    MyWavemakerRandom(Port5,35,50); // Turn Port5 on/off random cycles that lasts from 36 to 50 secs
void MyWavemakerRandom(byte WMRelay, int MinWMTimer, int MaxWMTimer)
  if (now()>WMRTimer)
    WMRTimer=now()+random(MinWMTimer, MaxWMTimer);
    ReefAngel.Relay.Toggle(WMRelay);
psyrob
Post by psyrob »
This works Roberto, thanks...One other question? My old code used to have a "slow down" for the wave makers at night, with one wavemaker going on for 20 seconds, then a one minute interval with no wavemaker on, then the second went on for 20 seconds, etc. This was the code, I took it out with the last upgrade of libraries, because I was afraid it wouldn't work...How can I get this back in there?
    if ((hour() >= 21) || (hour() <= 8)) //from 9p-8a
      if (wmdelay)
        ReefAngel.Timer[1].SetInterval(60); // wm night delay
        ReefAngel.Timer[1].Start();
        if (wmport==Port5) wmport=Port6;
        else wmport=Port5;
        wmdelay=false;
        ReefAngel.Timer[1].SetInterval(20); // short wave
        ReefAngel.Relay.On(wmport);
        wmdelay=true;
      //8a-9p normal wave settings
                        //ReefAngel.WavemakerRandom(Port5,35,50);
                        // Turn Port5 on/off random cycles that lasts from 35 to 50 secs
                        //ReefAngel.Relay.Set(Port6,!ReefAngel.Relay.Status(Port5));
      ReefAngel.Timer[1].SetInterval(random(35,50));
      if bitRead(ReefAngel.Relay.RelayData,Port5-1) ReefAngel.Relay.Off(Port6);
      else ReefAngel.Relay.On(Port6);
Try this:
boolean wmdelay=false;
byte wmport=Port5;
  char text[7];
  //Moonlights July 2nd
  if (t>=0)
  MyWavemakerRandom(Port5,Port6,35,50); // Turn Port5 on/off random cycles that lasts from 36 to 50 secs
void MyWavemakerRandom(byte WMRelay1, byte WMRelay2, int MinWMTimer, int MaxWMTimer)
  if (now()>WMRTimer)
      if (wmdelay)
        WMRTimer=now()+60;
        ReefAngel.Relay.Off(WMRelay1);
        ReefAngel.Relay.Off(WMRelay2);
        else wmport=Port5;
        wmdelay=false;
        WMRTimer=now()+20;
        wmdelay=true;
      ReefAngel.Relay.Toggle(WMRelay1);
      ReefAngel.Relay.Set(WMRelay2,!ReefAngel.Relay.Status(WMRelay1)); // Turn Port6 on/off on opposite cycle as Port 5
