custom main and new libraries
How do I use the custom main screen I had before the library update? I tried just cutting and pasting my old code into the new one I generated with the Wizard and it won't compile. I notice there is no define section any more at the top of my ino file like before...
Re: custom main and new libraries
You should be able to just copy and paste.
Post the code and I can help.
I got it to work...I was missing a "{" at the end of one of my cuts....
However, can you look at this code: I had this working to display the time of the wavemaker in seconds, and while it worked before, it now displays a number in the thousands, like 1321, even as the wavemaker alternates back and forth in 35 to 50 seconds..
//July 7, 2012, first try with the new 1.0.0 libraries
ReefAngel.LCD.DrawDate(6, 120);
ReefAngel.LCD.DrawLargeText(COLOR_DARKTURQUOISE, COLOR_WHITE, 4, 4 , "ROB'S REEF ANGEL");
ReefAngel.LCD.Clear(COLOR_MAROON, 1, 13, 132, 13);
ReefAngel.LCD.Clear(COLOR_MAROON, 10, 75, 119, 75);
ReefAngel.LCD.Clear(COLOR_MAROON, 10, 59, 119, 59);
ReefAngel.LCD.DrawLargeText(COLOR_GOLDENROD, COLOR_WHITE, 8, 15, "Big Tank");
char text[7];
ReefAngel.LCD.DrawLargeText(COLOR_GOLDENROD, DefaultBGColor, 18, 28, text);
ReefAngel.LCD.DrawText(COLOR_RED, COLOR_WHITE,8,48,"Frag:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], COLOR_RED, 40, 48, 10);
ReefAngel.LCD.DrawText(COLOR_DARKORCHID, COLOR_WHITE,8,39,"Room:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], T2TempColor, 40, 39, 10);
ReefAngel.LCD.DrawLargeText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 92, 15, "pH");
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, 88, 28, text);
ReefAngel.LCD.DrawText(DPColor,DefaultBGColor, 5, 64,"WAVE FLOW:");
if (bitRead(ReefAngel.Relay.RelayData,Port5-1)==1) ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 67, 64,"----->"); //port 5 on
else if (bitRead(ReefAngel.Relay.RelayData,Port6-1)==1) ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 67, 64,"<-----"); //port 6 on
//else ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 67, 64," 00000 "); //port5 and port 6 off, wavemaker delay: taken away for the moonlights July 2nd
//show the timer for wavemaker
int t=ReefAngel.Timer[1].Trigger-now();
if (t>=0)
ReefAngel.LCD.Clear(255,105,64,135,74);
ReefAngel.LCD.DrawText(APColor, COLOR_KHAKI,110,64,t);
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,10,79,"Actinic");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,10,89,"FragLt");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,10,99,"WM RT");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,10,109,"Fan");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,79,"ATO");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,89,"DayLts");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,99,"WM LFT");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,109,"Heater");
ReefAngel.LCD.DrawCircleOutletBox(60, 81, TempRelay, true);
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port7Bit;
ReefAngel.DayLights( Port1 );
ReefAngel.ActinicLights( Port2 );
ReefAngel.DayLights( Port3 );
ReefAngel.DayLights( Port4 );
//ReefAngel.Wavemaker1( Port5 );
//ReefAngel.Wavemaker1( Port6 );
ReefAngel.StandardFan( Port8 );
if ( (hour()>=7 && hour()<22))
ReefAngel.WavemakerRandom(Port5,35,50); // Turn Port5 on/off random cycles that lasts from 36 to 50 secs
ReefAngel.Relay.Set(Port6,!ReefAngel.Relay.Status(Port5)); // Turn Port6 on/off on opposite cycle as Port 5
// Port 5 and 6 are synchronized.
// They work in opposing motion of each other at random times.
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.Off(Port6);
} //Wavemaker on from 7 am to 10 pm, Off there after
ReefAngel.Portal( "psyrob" );
Oh, it's been a while since we don't use the Timer[1] anymore.
Try this:
Try this:
time_t WMRTimer=now();
char text[7];
//else ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 67, 64," 00000 "); //port5 and port 6 off, wavemaker delay: taken away for the Moonlights July 2nd
int t=WMRTimer-now();
if (t>=0)
MyWavemakerRandom(Port5,35,50); // Turn Port5 on/off random cycles that lasts from 36 to 50 secs
void MyWavemakerRandom(byte WMRelay, int MinWMTimer, int MaxWMTimer)
if (now()>WMRTimer)
WMRTimer=now()+random(MinWMTimer, MaxWMTimer);
ReefAngel.Relay.Toggle(WMRelay);
This works Roberto, thanks...One other question? My old code used to have a "slow down" for the wave makers at night, with one wavemaker going on for 20 seconds, then a one minute interval with no wavemaker on, then the second went on for 20 seconds, etc. This was the code, I took it out with the last upgrade of libraries, because I was afraid it wouldn't work...How can I get this back in there?
if ((hour() >= 21) || (hour() <= 8)) //from 9p-8a
if (wmdelay)
ReefAngel.Timer[1].SetInterval(60); // wm night delay
ReefAngel.Timer[1].Start();
if (wmport==Port5) wmport=Port6;
else wmport=Port5;
wmdelay=false;
ReefAngel.Timer[1].SetInterval(20); // short wave
ReefAngel.Relay.On(wmport);
wmdelay=true;
//8a-9p normal wave settings
//ReefAngel.WavemakerRandom(Port5,35,50);
// Turn Port5 on/off random cycles that lasts from 35 to 50 secs
//ReefAngel.Relay.Set(Port6,!ReefAngel.Relay.Status(Port5));
ReefAngel.Timer[1].SetInterval(random(35,50));
if bitRead(ReefAngel.Relay.RelayData,Port5-1) ReefAngel.Relay.Off(Port6);
else ReefAngel.Relay.On(Port6);
Try this:
boolean wmdelay=false;
byte wmport=Port5;
char text[7];
//Moonlights July 2nd
if (t>=0)
MyWavemakerRandom(Port5,Port6,35,50); // Turn Port5 on/off random cycles that lasts from 36 to 50 secs
void MyWavemakerRandom(byte WMRelay1, byte WMRelay2, int MinWMTimer, int MaxWMTimer)
if (now()>WMRTimer)
if (wmdelay)
WMRTimer=now()+60;
ReefAngel.Relay.Off(WMRelay1);
ReefAngel.Relay.Off(WMRelay2);
else wmport=Port5;
wmdelay=false;
WMRTimer=now()+20;
wmdelay=true;
ReefAngel.Relay.Toggle(WMRelay1);
ReefAngel.Relay.Set(WMRelay2,!ReefAngel.Relay.Status(WMRelay1)); // Turn Port6 on/off on opposite cycle as Port 5
