I am using the random synch example code (ino below) and the wavemaker is spazzing out:
Port 5 goes on for 35-50 seconds, then switches off and back on really fast and stays on for another 8 seconds...then port 6 goes on for 35-50 seconds, then it switches off and back on really fast, stays on for another 8 or so seconds, then port 5 goes on for 35-50 seconds and so on and so on....
I just want it to be in synch, port 5 on for 35-50, then off while port 6 goes on for 35 to 50 while 5 is off...
thanks
//July 7, 2012, first try with the new 1.0.0 libraries
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port7Bit;
ReefAngel.DayLights( Port1 );
ReefAngel.ActinicLights( Port2 );
ReefAngel.DayLights( Port3 );
ReefAngel.DayLights( Port4 );
ReefAngel.Wavemaker1( Port5 );
ReefAngel.Wavemaker1( Port6 );
ReefAngel.StandardFan( Port8 );
ReefAngel.WavemakerRandom(Port5,35,50); // Turn Port5 on/off random cycles that lasts from 36 to 50 secs
ReefAngel.Relay.Set(Port6,!ReefAngel.Relay.Status(Port5)); // Turn Port6 on/off on opposite cycle as Port 5
// Port 5 and 6 are synchronized.
// They work in opposing motion of each other at random times.
ReefAngel.Portal( "psyrob" );
random wavemaker spazzing out
Re: random wavemaker spazzing out
Remove these lines:
they are affecting the WavemakerRandom() function calls.
thanks curt...that did it...
awesome.psyrob wrote:thanks curt...that did it...
