byte vtechmode;
byte vtechspeed;
byte vtechpercent;
boolean bFeeding=false;
byte x = 6;
byte y = 2;
byte t;
char text[7];
//Custom Main, Graph & Menu
// ReefAngel.LCD.DrawDate(6, 2);
ReefAngel.LCD.DrawText(3,255,6,2," Reef of Low");
ReefAngel.LCD.DrawDate(7, 99);
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 90, "--------------------");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 126, "--------------------");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 93, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 103, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 113, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 123, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 93, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 103, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 113, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 123, "|");
ReefAngel.LCD.DrawText(0,255,18,21,"EcoSmart Vortech");
if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,32,"Constant");
else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,31,"Lagoon");
else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,31,"Reef Crest");
else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,31,"Short Pulse");
else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,31,"Long Pulse");
else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,31,"Nutrient Trnsp.");
else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,31,"Tidal Swell");
else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,31,"Night");
ReefAngel.LCD.DrawText(0,255,10,50,"Tank");
ReefAngel.LCD.DrawLargeText(COLOR_RED, 255, 10, 60, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,100,50,"pH");
ReefAngel.LCD.DrawLargeText(COLOR_INDIGO, 255, 85, 60, text, Num8x8);
ReefAngel.LCD.DrawOutletBox(12, 77, TempRelay);
ReefAngel.FeedingModePorts = Port4Bit | Port7Bit;
InternalMemory.OverheatTemp_write( 290 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port1,251,261 );
ReefAngel.StandardHeater( Port2,251,261 );
ReefAngel.StandardFan( Port3,271,281 );
ReefAngel.StandardLights( Port5,20,0,5,0 );
ReefAngel.StandardLights( Port6,20,0,0,0 );
/////// CHANGE MODE @ TIMES
if ( ReefAngel.RF.Mode != Feeding_Start)
if (hour()==10)
ReefAngel.RF.SetMode( ReefCrest,30,20);
else if (hour()>=6 || hour()<9)
ReefAngel.RF.SetMode(ReefCrest,20,10);
else if (hour()>=9 && hour()<10)
ReefAngel.RF.SetMode(ReefCrest,30,10);
else if (hour()>=10 && hour()<11)
ReefAngel.RF.SetMode(ReefCrest,40,10);
else if (hour()>=11 && hour()<12)
ReefAngel.RF.SetMode(Smart_NTM,50,6);
else if (hour()>=12 && hour()<13)
ReefAngel.RF.SetMode(Smart_NTM,60,10);
else if (hour()>=13 && hour()<14)
ReefAngel.RF.SetMode(Smart_NTM,70,12);
else if (hour()>=14 && hour()<15)
else if (hour()>=15 && hour()<16)
ReefAngel.RF.SetMode(Smart_NTM,50,8);
else if (hour()>=16 && hour()<17)
ReefAngel.RF.SetMode(Constant,50,10);
else if (hour()>=17 && hour()<18)
ReefAngel.RF.SetMode(Constant,40,10);
else if (hour()>=18 && hour()<19)
ReefAngel.RF.SetMode(Constant,30,10);
else if (hour()>=19 && hour()<20)
else if (hour()>=20 && hour()<21)
else if (hour()>=21 && hour()<22)
else if (hour()>=22 || hour()<23)
else if (hour()>=23 || hour()<0)
ReefAngel.RF.SetMode(ReefCrest,60,10);
else if (hour()>=0 || hour()<1)
ReefAngel.RF.SetMode(ReefCrest,50,10);
else if (hour()>=1 || hour()<3)
else if (hour()>=3 || hour()<6)
ReefAngel.Portal( "appleseed" );
I have been trying to get my display to show the mode that my vortechs are in (using code borrowed from people on here much smarter than me), the code currently only ever displays tha tthe pumps are in Constant mode but the led on the rf module shows that actual mode being not constant.
Can some one advise where I am going wrong?
cheers
Andy
