error compiling
ryanmell
error compiling
Post by ryanmell »
so i stole this wavemaker code from a guy on my local reef club board but am getting an error when trying to compile,
// Autogenerated file by RAGen (v1.1.0.127), (02/06/2012 22:15)
// RA_020612_2215.pde
#define DateTimeSetup
#define VersionMenu
#define DirectTempSensor
#define wifi
#define SaveRelayState
#define WDT
#define SIMPLE_MENU
#define ENABLE_ATO_LOGGING
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#include <avr/pgmspace.h>
// Labels for the web banner
prog_char id_label[] PROGMEM = "rimai";
prog_char probe1_label[] PROGMEM = "Water";
prog_char probe2_label[] PROGMEM = "Not%20Used";
prog_char probe3_label[] PROGMEM = "Not%20Used";
prog_char relay1_label[] PROGMEM = "ATO";
prog_char relay2_label[] PROGMEM = "Actinic";
prog_char relay3_label[] PROGMEM = "12,000K";
prog_char relay4_label[] PROGMEM = "Skimmer";
prog_char relay5_label[] PROGMEM = "Powerhead%201";
prog_char relay6_label[] PROGMEM = "Powerhead%202";
prog_char relay7_label[] PROGMEM = "Heater";
prog_char relay8_label[] PROGMEM = "Sump";
// Initialize and start the web banner timer
ReefAngel.Timer[4].Start();
ReefAngel.FeedingModePorts = B10100000;
ReefAngel.WaterChangePorts = B10111000;
ReefAngel.OverheatShutoffPorts = B00000110;
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.On(Port8);
// Specific functions
ReefAngel.StandardATO(Port1);
ReefAngel.StandardLights(Port3);
ReefAngel.Wavemaker1(Port5);
ReefAngel.Wavemaker2(Port6);
// Web Banner stuff
ReefAngel.WebBanner();
static unsigned long nexttoggle=now();
static boolean state=false;
int cycle=nexttoggle-now();
ReefAngel.Relay.Set(Port5,state);
ReefAngel.Relay.Set(Port6,!ReefAngel.Relay.Status(Port5));
if ( (hour()>=9 && hour()<15))
if (cycle<0)
nexttoggle+=random(35,45);
state=!state;
if (cycle<5)
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port6);
else if ( (hour()>=15 && hour()<21) )
if (cycle<0)
nexttoggle+=random(15,20);
state=!state;
if (cycle<8)
else if ( (hour()>=21 && hour()<24) )
if (cycle<0)
state=!state;
if (cycle<5)
if (cycle<0)
nexttoggle+=random(60,90);
state=!state;
if (cycle<30)
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.on(Port6);
here is the error
RA_020612_2215.cpp: In function 'void loop()':
RA_020612_2215:92: error: 'class ReefAngel_RelayClass' has no member named 'Set'
RA_020612_2215:93: error: 'class ReefAngel_RelayClass' has no member named 'Set'
RA_020612_2215:93: error: 'class ReefAngel_RelayClass' has no member named 'Status'
RA_020612_2215:144: error: 'class ReefAngel_RelayClass' has no member named 'on'
any help would be appreciated, I am a cut and paste programmer
Re: error compiling
Try this:
#define VersionMenu
#define wifi
#define WDT
#define SIMPLE_MENU
if (cycle<0)
state=!state;
if (cycle<5)
if (cycle<0)
state=!state;
if (cycle<8)
if (cycle<0)
state=!state;
if (cycle<5)
if (cycle<0)
state=!state;
if (cycle<30)
Have you tried creating a new code with the Reef Angel Wizard??
Give it a try :)
Opne Arduino and go to menu Tools->Reef Angel Wizard.
ryanmell
Re: error compiling
Post by ryanmell »
yes that to threw an error, i looked for the reef angel wizard and couldn't find it
Re: error compiling
You need to download the newest RA installer, but hold on until tomorrow.
I'm trying to push a new release today.
