Here is my code:
ReefAngel.FeedingModePorts = Port4Bit | Port5Bit;
ReefAngel.WaterChangePorts = Port4Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port6Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.DayLights( Port1 );
ReefAngel.ActinicLights( Port2 );
ReefAngel.ActinicLights( Port3 );
ReefAngel.StandardHeater( Port6 );
ReefAngel.StandardATO( Port7 );
ReefAngel.Portal( "alexwbush" );
Watchdog Timer
Version Menu
Dimming Signal
Wifi Attachment
Simple Menu
C:\Users\On a boat\Documents\Arduino\libraries\OneWire\OneWire.cpp:66:24: error: WConstants.h: No such file or directory
C:\Users\On a boat\Documents\Arduino\libraries\OneWire\OneWire.cpp: In constructor 'OneWire::OneWire(uint8_t)':
C:\Users\On a boat\Documents\Arduino\libraries\OneWire\OneWire.cpp:75: error: 'digitalPinToPort' was not declared in this scope
C:\Users\On a boat\Documents\Arduino\libraries\OneWire\OneWire.cpp:76: error: 'digitalPinToBitMask' was not declared in this scope
C:\Users\On a boat\Documents\Arduino\libraries\OneWire\OneWire.cpp:77: error: 'portOutputRegister' was not declared in this scope
C:\Users\On a boat\Documents\Arduino\libraries\OneWire\OneWire.cpp:78: error: 'portInputRegister' was not declared in this scope
C:\Users\On a boat\Documents\Arduino\libraries\OneWire\OneWire.cpp:79: error: 'portModeRegister' was not declared in this scope
C:\Users\On a boat\Documents\Arduino\libraries\OneWire\OneWire.cpp: In member function 'uint8_t OneWire::reset()':
C:\Users\On a boat\Documents\Arduino\libraries\OneWire\OneWire.cpp:97: error: 'INPUT' was not declared in this scope
C:\Users\On a boat\Documents\Arduino\libraries\OneWire\OneWire.cpp:97: error: 'pinMode' was not declared in this scope
C:\Users\On a boat\Documents\Arduino\libraries\OneWire\OneWire.cpp:100: error: 'delayMicroseconds' was not declared in this scope
C:\Users\On a boat\Documents\Arduino\libraries\OneWire\OneWire.cpp:101: error: 'digitalRead' was not declared in this scope
C:\Users\On a boat\Documents\Arduino\libraries\OneWire\OneWire.cpp:103: error: 'digitalWrite' was not declared in this scope
C:\Users\On a boat\Documents\Arduino\libraries\OneWire\OneWire.cpp:104: error: 'OUTPUT' was not declared in this scope
C:\Users\On a boat\Documents\Arduino\libraries\OneWire\OneWire.cpp:105: error: 'delayMicroseconds' was not declared in this scope
C:\Users\On a boat\Documents\Arduino\libraries\OneWire\OneWire.cpp: In member function 'void OneWire::write_bit(uint8_t)':
C:\Users\On a boat\Documents\Arduino\libraries\OneWire\OneWire.cpp:125: error: 'delayMicroseconds' was not declared in this scope
C:\Users\On a boat\Documents\Arduino\libraries\OneWire\OneWire.cpp: In member function 'uint8_t OneWire::read_bit()':
C:\Users\On a boat\Documents\Arduino\libraries\OneWire\OneWire.cpp:140: error: 'delayMicroseconds' was not declared in this scope
C:\Users\On a boat\Documents\Arduino\libraries\OneWire\OneWire.cpp: In member function 'void OneWire::write(uint8_t, uint8_t)':
C:\Users\On a boat\Documents\Arduino\libraries\OneWire\OneWire.cpp:163: error: 'INPUT' was not declared in this scope
C:\Users\On a boat\Documents\Arduino\libraries\OneWire\OneWire.cpp:163: error: 'pinMode' was not declared in this scope
C:\Users\On a boat\Documents\Arduino\libraries\OneWire\OneWire.cpp:164: error: 'digitalWrite' was not declared in this scope
C:\Users\On a boat\Documents\Arduino\libraries\OneWire\OneWire.cpp: In member function 'void OneWire::depower()':
C:\Users\On a boat\Documents\Arduino\libraries\OneWire\OneWire.cpp:203: error: 'INPUT' was not declared in this scope
C:\Users\On a boat\Documents\Arduino\libraries\OneWire\OneWire.cpp:203: error: 'pinMode' was not declared in this scope
