Major issues
Adam
Major issues
Post by Adam »
OK, I tried to up load a new code and I get a compile error COLOR_WHITE not defined and a whole string of stuff. So I went to install the old internal memory and program, after I install it I get ( No internal memory found) on my head unit display. I tried using RA wizzard and I get the same message on the head unit. Now my tank is down and I need to get it going agin.
Re: Major issues
You need to load an internal memory code.
http://www.reefangel.com/Support.Loadin ... tings.ashx
Adam
Re: Major issues
Post by Adam »
OK that got me fixed by using the example for the internal memory. My issue was I had made a internal memory with RA Gen and thast is where I was getting the error COLOR_WHITE and so forth.
Re: Major issues
Probably designed for older libraries.
I can convert it for you if you post it here.
Adam
Re: Major issues
Post by Adam »
I think I'm gona run with what I've got for now, and I will play around with it later. I do like the new RA wizzard. I think it will let me help my dad set up his new RA it came in today and I live 3 hours away so I can probly do it over the phone.
