I am having trouble with the ATO floats. I am currently using standard ATO and have the high float with the wires down and the low float with the wires up. The only current way I can get it to work is with both floats having the wires up.
As the water level drops the high ato->IsActive then as the water level drops further the low ato->IsActive this will bring on the pump. The low float will then rise with the pump still running. When the high float rises the pump shuts off. This is my code.... any ideas?
ReefAngel.FeedingModePorts = Port2Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port2Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardHeater( Port1,751,761 );
ReefAngel.StandardATO( Port2,60 );
ReefAngel.Wavemaker( Port5,60 );
ReefAngel.Wavemaker( Port6,50 );
ReefAngel.Relay.DelayedOn( Port7,3 );
ReefAngel.PWM.SetDaylight( PWMSlope(8,0,21,0,0,100,60,0) );
ReefAngel.PWM.SetActinic( PWMSlope(7,0,22,0,0,100,60,0) );
