Cutting down to fit on the standard RA
alexwbush
Post by alexwbush »
So I just moved and my RA+ is running my temp tank 6 hours away and I have my new tank setup on a RA standard. My new tank is much bigger (75 gallons... old tank ~30 gallons). I am running:
Standard thermometers
Standard pH
Salinity expansion
RF expansion (for radions)
Dosing pump expansion
2nd relay expansion
wifi
Is this just a pipe dream? I'd like to keep functionality of it all :lol: I guess I'll have to start cutting things down.
Here is my current code:
byte buzzer=0;
byte overheatflag=0;
byte atoflag=0;
    ReefAngel.FeedingModePorts = Port4Bit | Port7Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.WaterChangePortsE[0] = Port2Bit;
    ReefAngel.LightsOnPortsE[0] = Port1Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port7Bit;
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.DosingPumpRepeat1( Port5 );
    ReefAngel.DosingPumpRepeat2( Port6 );
    ReefAngel.Relay.DelayedOn( Port7 );
    ReefAngel.Relay.Set( Box1_Port1, !ReefAngel.Relay.Status( Port8 ) );
    ReefAngel.SingleATOLow( Box1_Port2 );
    ReefAngel.RF.ChannelWhiteParabola();
    ReefAngel.RF.ChannelRoyalBlueParabola();
    ReefAngel.RF.ChannelRedParabola();
    ReefAngel.RF.ChannelGreenParabola();
    ReefAngel.RF.SetChannel( Radion_Blue, MoonPhase() );
    ReefAngel.RF.ChannelIntensityParabola();
    if ( second()==0 ) ReefAngel.RF.RadionWrite();
    buzzer = overheatflag + atoflag;
    if ( buzzer >= 1 ) buzzer = 100;
    ReefAngel.Portal( "wolfpack" );
    int x,y;
    // Parameters
    ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params,
    ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params );
    // Salinity
    ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,54, "SAL:" );
    ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,54, ReefAngel.Params.Salinity );
    // Main Relay Box
    ReefAngel.LCD.DrawOutletBox( 12, 76, TempRelay );
    // Relay Expansion
    ReefAngel.LCD.DrawOutletBox( 12, 98, TempRelay );
    // Date and Time
alexwbush
Re: Cutting down to fit on the standard RA
Post by alexwbush »
well, I removed the RF module in the wizard and that fit... any ideas that might get me running with it until I get my RA+ back?
I'm afraid it is going to be too much for the standard RA :(
alexwbush
Post by alexwbush »
rimai wrote::(
say it aint so! That's ok, I should have my RA+ in the next couple months. I can let the radions run the ecotech light cycle for now.
alexwbush
Post by alexwbush »
My original RA board won't work with the expansion modules, will they? I remember having to play with jumpers, but I think maybe that was on the second board.
If you got jumpers you can
