Here are the errors:
Watchdog Timer
Version Menu
Dimming Signal
Salinity Expansion Module
Wifi Attachment
Custom Main Screen
Exceed Flagging
Relay Expansion Module
Simple Menu
Binary sketch size: 30,286 bytes (of a 30,720 byte maximum)
C:\Program Files\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P\\.\COM6 -b57600 -D -Uflash:w:C:\Users\ONABOA~1\AppData\Local\Temp\build362447910769804697.tmp\sketch_sep16b.cpp.hex:i
System wide configuration file is "C:\Program Files\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf"
Using Port : \\.\COM6
Using Programmer : stk500v1
Overriding Baud Rate : 57600
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x0c
avrdude done. Thank you.
byte buzzer=0;
byte overheatflag=0;
byte atoflag=0;
ReefAngel.FeedingModePorts = Port4Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port5Bit | Port6Bit;
ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port7Bit;
ReefAngel.Relay.On( Port1 ); //left radion
ReefAngel.Relay.On( Port2 ); //right radion
ReefAngel.Relay.On( Port5 ); //ATO
ReefAngel.Relay.On( Port8 ); //return
ReefAngel.Relay.On( Box1_Port7 ); //TBD
ReefAngel.Relay.On( Box1_Port8 ); //TBD
//ReefAngel.SingleATOLow( Port5 );
ReefAngel.Relay.DelayedOn( Port7 );
ReefAngel.DosingPumpRepeat1( Box1_Port5 );
ReefAngel.DosingPumpRepeat2( Box1_Port6 );
buzzer = overheatflag + atoflag;
if ( buzzer >= 1 ) buzzer = 100;
ReefAngel.PWM.SetDaylight( buzzer );
/* Auto feeding mode starts.
Feeder set for 17:30, start feeding more at 17:35. */
if ( hour() == 17 && minute() == 25 && second() ==0 ) //if time is 17:25:00
ReefAngel.FeedingModeStart(); //start feeding mode
// Run Vortech during day only. Vortech is on from 09:00-20:00.
ReefAngel.StandardLights(Port4,9,0,20,0);
ReefAngel.Portal( "wolfpack" );
byte x = 6;
byte y = 2;
byte t;
char text[7];
static byte vtechmode=0;
/* Drawing this:
01/01/12 00:00:00 AM
Disp 79.9 pH 8.00
Sump 79.9 Sal 0.60
Room 77.7
1 2 3 4 5 6 7 8
1 2 3 4 5 6 7 8
Moon Waning Crescent
Intensity 88%
Sunrise 06:15
Sunset 18:12
ReefAngel.LCD.DrawDate(6, 2);
ReefAngel.LCD.Clear(COLOR_BLACK, 1, 11, 128, 11);
//ReefAngel.LCD.DrawText(fcolor,bcolor,x,y,"text");
//Line 1 - Display Temp & pH
x = 8;
y = 15;
ReefAngel.LCD.DrawText(0,255,x,y,"Disp");
x += 30;
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T1_PROBE], COLOR_CORNFLOWERBLUE, x, y, 10);
x = 64;
ReefAngel.LCD.DrawText(0,255,x,y,"pH");
x += 30;
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.PH, COLOR_CORNFLOWERBLUE, x, y, 100);
//Line 2 - Sump & Salinity
x = 8;
y += 10;
ReefAngel.LCD.DrawText(0,255,x,y,"Sump");
x += 30;
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], COLOR_CORNFLOWERBLUE, x, y, 10);
x = 64;
ReefAngel.LCD.DrawText(0,255,x,y,"Sal");
x += 30;
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Salinity, COLOR_CORNFLOWERBLUE, x, y, 100);
//Line 3 - Room
x = 8;
y += 10;
ReefAngel.LCD.DrawText(0,255,x,y,"Room");
x += 30;
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], COLOR_CORNFLOWERBLUE, x, y, 10);
//Lines 4 and 5 - Relays
x = 12;
y += 15;
// draw main relay
#ifdef RelayExp
// draw 1st expansion relay
y += 12 ;
#endif // RelayExp
//Line 6 - Moon
x = 8;
y += 17;
ReefAngel.LCD.DrawText(0,255,x,y,"Moon");
//Line 7 - Intensity
x = 8;
y += 10;
ReefAngel.LCD.DrawText(0,255,x,y,"Intensity");
//Line 8 - Sunrise
x = 8;
y += 10;
ReefAngel.LCD.DrawText(0,255,x,y,"Sunrise");
//Line 9 - Sunset
x = 8;
y += 10;
ReefAngel.LCD.DrawText(0,255,x,y,"Sunset");
