I was acclimating some corals today and noticed that one of the outlets on the #1 box cycles off every ten minutes or so. It stays off for a few minutes then turns back on. It's outlet #7 on box-1. Can you take a look at the file and see if you notice what is causing it?
ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit;
// The T3 probe is tank temperature and overheat functions
// Overheat temperature setting
InternalMemory.OverheatTemp_write( 840 );
// Ports that are always on Pump-8 Wavemakers-5&6
ReefAngel.StandardHeater( Port1,751,761 );
ReefAngel.StandardATO( Port2,390 );
ReefAngel.StandardLights( Port3,21,0,9,0 );
//ReefAngel.Wavemaker( Port5,60 );
//ReefAngel.Wavemaker( Port6,60 );
ReefAngel.Relay.DelayedOn( Port7,3 );
//Actinic Lights
ReefAngel.StandardLights( Box1_Port1,11,0,22,0 );
//Moon Light Driver
ReefAngel.StandardLights( Box1_Port2,22,0,8,0 );
//Morning Lights
ReefAngel.StandardLights( Box1_Port3,11,30,21,30 );
//High Noon Lights
ReefAngel.StandardLights( Box1_Port4,12,0,21,0 );
// This next line will run cooling fans for the tank
ReefAngel.StandardFan( Box1_Port5,790,805 );
//Moon Light 9V
ReefAngel.StandardLights( Box1_Port8,21,59,8,1 );
ReefAngel.PWM.SetDaylight( PWMSlope(12,0,21,0,10,100,240,10) );
ReefAngel.PWM.SetActinic( PWMSlope(11,0,22,0,10,100,60,10) );
if (ReefAngel.Params.Temp[T1_PROBE]>0)
if (ReefAngel.Params.Temp[T1_PROBE] >= 860) ReefAngel.Relay.On(Box1_Port7);
if (ReefAngel.Params.Temp[T1_PROBE] <= 820) ReefAngel.Relay.Off(Box1_Port7);
ReefAngel.Portal( "grafspee1217" );
int x,y;
// Parameters
// Main Relay Box
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 106, TempRelay );
// Date and Time
