My CUSTOM Screen
My CUSTOM Screen
Hello everyone, just thought I would post a pic of my custom screen I created! Special Thanks to Curt Binders info wich can be found her: http://curtbinder.info/ragen/docs/RA_Cu ... Screen.pdf Also give shout out to Roberto for helping me tweak it a lil.......Thanks!
- MYMENU.JPG (49.4 KiB) Viewed 9672 times
Re: My CUSTOM Screen
Had to resize my image!! lol here is the code I did: Roberto please put in right format if need be, Thanks
//The following features are enabled for this File:
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define WDT
#define SIMPLE_MENU
#define NUMBERS_8x16
byte x = 6;
byte y = 2;
byte t;
ReefAngel.LCD.DrawDate(6, 2);
ReefAngel.LCD.DrawLargeText(COLOR_GREEN,255,12,16,"!My LiL OCEAN!", Font8x8);
ReefAngel.LCD.DrawText(COLOR_LAWNGREEN,255, 6, 102, "--------------------");
ReefAngel.LCD.DrawText(COLOR_LAWNGREEN,255, 6, 126, "--------------------");
ReefAngel.LCD.DrawText(COLOR_RED,255,56,110, "ATO");
ReefAngel.LCD.DrawText(COLOR_LAWNGREEN,255, 2, 109, "*");
ReefAngel.LCD.DrawText(COLOR_LAWNGREEN,255, 2, 121, "*");
ReefAngel.LCD.DrawText(COLOR_INDIGO,255, 45, 111, "H");
ReefAngel.LCD.DrawText(COLOR_INDIGO,255, 45, 121, "I");
ReefAngel.LCD.DrawText(COLOR_INDIGO,255, 77, 111, "L");
ReefAngel.LCD.DrawText(COLOR_INDIGO,255, 77, 121, "O");
ReefAngel.LCD.DrawText(COLOR_LAWNGREEN,255, 126, 109, "*");
ReefAngel.LCD.DrawText(COLOR_LAWNGREEN,255, 126, 121, "*");
ReefAngel.LCD.DrawText(COLOR_RED,255,10,30,"TANK");
ReefAngel.LCD.DrawLargeText(COLOR_PURPLE, 255, 10, 40, text, Num8x16);
ReefAngel.LCD.DrawText(COLOR_RED,255,100,30,"pH");
ReefAngel.LCD.DrawLargeText(COLOR_PURPLE, 255, 85, 40, text, Num8x16);
ReefAngel.LCD.DrawOutletBox(12, 77, TempRelay);
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 89, TempRelay );
ReefAngel.LCD.DrawText(COLOR_RED,255,8,58,"CABINET");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], COLOR_PURPLE, 15, 68, 10);
ReefAngel.LCD.DrawText(COLOR_RED,255,95,58,"ROOM");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], COLOR_PURPLE, 92, 68, 10);
ReefAngel.LCD.DrawText(COLOR_BLACK,255,12,110, "Moon1");
ConvertNumToString(text, ReefAngel.PWM.GetDaylightValue(), 1);
strcat(text,"% ");
ReefAngel.LCD.DrawText(COLOR_RED,255,15,119, text);
//ReefAngel.PWM.GetDaylightValue(),
ReefAngel.LCD.DrawText(COLOR_BLACK,255,88,110, "Moon2");
ConvertNumToString(text, ReefAngel.PWM.GetActinicValue(), 1);
strcat(text,"% ");
ReefAngel.LCD.DrawText(COLOR_RED,255,92,119, text);
ReefAngel.LCD.FillCircle(57,122,3,COLOR_RED);
ReefAngel.LCD.FillCircle(57,122,3,COLOR_GREEN);
ReefAngel.LCD.FillCircle(70,122,3,COLOR_RED);
ReefAngel.LCD.FillCircle(70,122,3,COLOR_GREEN);
//ReefAngel.PWM.GetActinicValue());
//ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params,
ReefAngel.AddDateTimeMenu();
ReefAngel.FeedingModePorts = Port3Bit |Port4Bit | Port7Bit | Port8Bit;
ReefAngel.FeedingModePortsE[0] = Port8Bit;
ReefAngel.WaterChangePorts = Port3Bit | Port4Bit| Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port8Bit;
ReefAngel.OverheatShutoffPorts = Port8Bit;
InternalMemory.OverheatTemp_write( 795 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port8,779,780 );
ReefAngel.StandardLights( Port1,19,0,11,0 );
ReefAngel.StandardLights( Port2,11,0,19,0 );
ReefAngel.SingleATO( true,Port3,60,0 );
ReefAngel.Relay.Off( Port3 );
ReefAngel.Relay.DelayedOn( Port4,3 );
ReefAngel.Relay.DelayedOn( Port7,5 );
ReefAngel.Relay.DelayedOn( Box1_Port8,5 );
ReefAngel.LCD.BacklightOn();
ReefAngel.WavemakerRandom1( Port5,15,45 );
ReefAngel.WavemakerRandom2( Port6,30,90 );
MyCustomWavemakerRandom1( Box1_Port5,30,60 );
MyCustomWavemakerRandom2( Box1_Port6,75,90 );
if (hour()>=19 || hour()<11)
ReefAngel.PWM.SetDaylight( 0 );
ReefAngel.PWM.SetActinic( CustomSlope(19,0,15,100,960) );
ReefAngel.Portal( "CASPAR" );
byte CustomSlope(byte startHour, byte startMinute, byte startPWM, byte endPWM, long Duration)
unsigned long Start = previousMidnight(now())+((unsigned long)NumMins(startHour, startMinute)*60);
if (hour()<startHour) Start-=86400;
unsigned long StartD = Start + (Duration*60);
if ( now() >= Start && now() <= StartD )
return constrain(map(now(), Start, StartD, startPWM, endPWM),startPWM, endPWM);
// lastly return the existing value
return 0;
int x,y;
// Relay Expansion
void MyCustomWavemakerRandom1(byte WMRelay, int MinWMTimer, int MaxWMTimer)
static time_t MyWMRTimer1=now()+MinWMTimer;
if (now()>MyWMRTimer1)
MyWMRTimer1=now()+random(MinWMTimer, MaxWMTimer);
ReefAngel.Relay.Toggle(WMRelay);
void MyCustomWavemakerRandom2(byte WMRelay, int MinWMTimer, int MaxWMTimer)
static time_t MyWMRTimer2=now()+MinWMTimer;
if (now()>MyWMRTimer2)
MyWMRTimer2=now()+random(MinWMTimer, MaxWMTimer);
#define VersionMenu
#define wifi
#define WDT
#define SIMPLE_MENU
byte x = 6;
byte y = 2;
byte t;
// Relay Expansion
strcat(text,"% ");
strcat(text,"% ");
return 0;
int x,y;
// Relay Expansion
Now if there was a way to change the whole background color of the screen that would be awesome!!!!
And this is one of my tanks mounted in-wall....
- TANK.JPG (109.77 KiB) Viewed 9671 times
Thats sweet.. Any idea on which parts I would need if I didn't have the expansion box and wanted everything else like this especially the ATO Part..
Nevermind I got it.. Very Cool Thanks for sharing.. Wifes gonna start wondering why I'm always next to the aquarium with a laptop? Lol
That's a pretty nice little screen you created there. Good job. Glad my document was helpful for you.
All thanks to Curt and Roberto.........
looking great man. I may need you to make me a custom screen 8)
