JerkyJunky's Starter Screen
Posted: Fri Nov 16, 2012 6:37 pm
by jerkyjunky
Been a fun couple days programming in a new screen for my RA. Here is what I have so far:
http://i.imgur.com/9UVk9.jpg
The wavemaker stuff is filler until I get an actual unit, but the rest is legit. Here is the code:
#define FONT_8x16
    ReefAngel.AddStandardMenu();  // Add Standard Menu
    ReefAngel.FeedingModePorts = Port5Bit;
    ReefAngel.WaterChangePorts = Port5Bit | Port8Bit;
    ReefAngel.Relay.On( Port5 );
    ReefAngel.Relay.On( Port7 );
    ReefAngel.StandardLights( Port1,19,45,8,15 );
    ReefAngel.StandardLights( Port3,19,59,8,1 );
    ReefAngel.StandardLights( Port4,7,59,20,1 );
    ReefAngel.PWM.SetDaylight( PWMSlope(8,0,20,0,15,100,60,0) );
    ReefAngel.PWM.SetActinic( PWMSlope(20,0,8,0,15,100,60,0) );
    byte offset = 3;
    byte waterLevel = ReefAngel.WaterLevel.GetLevel();
    byte dispLights = ReefAngel.PWM.GetDaylightValue();
    byte sumpLights = ReefAngel.PWM.GetActinicValue();
    byte atoPort = 3;
    // Header = Title + Date and Time
    ReefAngel.LCD.DrawText(COLOR_GREEN, DefaultBGColor, 15, offset, "JerkyJunky's Reef");
    ReefAngel.LCD.DrawDate(6, offset + 10);
    ReefAngel.LCD.Clear(COLOR_GREEN, 1, offset + 20, 128, offset + 20);
    offset = 26;
    // Main Relay Box & Parameters
    ReefAngel.LCD.DrawCircleOutletBoxHorizontal(2, offset, TempRelay);
    ReefAngel.LCD.DrawText(COLOR_BLACK, DefaultBGColor, 50, offset, "Temp:");
    ReefAngel.LCD.DrawLargeText(COLOR_PURPLE, 255, 49, offset + 9, text, Font8x16);
    ReefAngel.LCD.DrawText(COLOR_BLACK, DefaultBGColor, 101, offset, "pH:");
    ReefAngel.LCD.DrawLargeText(COLOR_ORANGE, 255, 93, offset + 9, text, Font8x16);
    ReefAngel.LCD.Clear(COLOR_GREEN, 1, offset + 23, 128, offset + 23);
    offset = offset + 27;
    // Lights
    if (dispLights > 0)
      ReefAngel.LCD.DrawText(COLOR_GREEN, DefaultBGColor, 10, offset, "Display");
      ReefAngel.LCD.DrawText(COLOR_RED, DefaultBGColor, 10, offset, "Display");
    if (sumpLights > 0)
      ReefAngel.LCD.DrawText(COLOR_GREEN, DefaultBGColor, 72, offset, "Refugium");
      ReefAngel.LCD.DrawText(COLOR_RED, DefaultBGColor, 72, offset, "Refugium");
    ConvertNumToString(text, dispLights, 1);
    strcat(text, "%");
    ReefAngel.LCD.DrawLargeText(COLOR_BLUE, DefaultBGColor, 15, offset + 9, text, Font8x16);
    ConvertNumToString(text, sumpLights, 1);
    strcat(text, "%");
    ReefAngel.LCD.DrawLargeText(COLOR_BLUE, DefaultBGColor, 95, offset + 9, text, Font8x16);
    ReefAngel.LCD.Clear(COLOR_GREEN, 1, offset + 24, 128, offset + 24);
    // Water Level & ATO
    if (waterLevel >= 100)
    ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor, 5, offset, "Tank Level");
    ReefAngel.LCD.DrawLargeText(COLOR_BLUE, DefaultBGColor, 25, offset + 9, "Full", Font8x16);
    else if (waterLevel >= 50)
    ReefAngel.LCD.DrawText(COLOR_ORANGE, DefaultBGColor, 5, offset, "Tank Level");
    ConvertNumToString(text, waterLevel, 1);
    strcat(text, "%");
    ReefAngel.LCD.Clear(DefaultBGColor, 1, offset + 9, 128, offset + 18);
    ReefAngel.LCD.DrawLargeText(COLOR_ORANGE, DefaultBGColor, 25, offset + 9, text, Font8x16);
    ReefAngel.LCD.DrawText(COLOR_RED, DefaultBGColor, 5, offset, "Tank Level");
    strcat(text, "%");
    ReefAngel.LCD.DrawLargeText(COLOR_RED, DefaultBGColor, 25, offset + 9, text, Font8x16);
    ReefAngel.LCD.DrawText(COLOR_BLACK, DefaultBGColor, 70, offset + 2, "ATO:");
    	ReefAngel.LCD.DrawText(COLOR_GREEN, DefaultBGColor, 95, offset + 2, "Avail");
    	ReefAngel.LCD.DrawText(COLOR_RED, DefaultBGColor, 95, offset + 2, "Empty");
    ReefAngel.LCD.DrawText(COLOR_BLACK, DefaultBGColor, 72, offset + 12, "Pump:");
    if ((TempRelay&(1<<(atoPort - 1)))==1<<(atoPort - 1))
        ReefAngel.LCD.Clear(DefaultBGColor, 102, offset + 12, 128, offset + 21);
    	ReefAngel.LCD.DrawText(COLOR_GREEN, DefaultBGColor, 102, offset + 12, "On");
    	ReefAngel.LCD.DrawText(COLOR_RED, DefaultBGColor, 102, offset + 12, "Off");
    // Wavemaker
    ReefAngel.LCD.DrawText(COLOR_BLACK, DefaultBGColor, 8, offset, "Vortech Mode");
    ReefAngel.LCD.DrawText(COLOR_BLACK, DefaultBGColor, 95, offset, "Speed");
    ReefAngel.LCD.DrawLargeText(COLOR_ORANGE, DefaultBGColor, 5, offset + 9, "Reef Crest", Font8x16);
    ReefAngel.LCD.DrawLargeText(COLOR_GREEN, DefaultBGColor, 98, offset + 9, "XX%", Font8x16);
Now to add in the cloud logic, the sunrise by location code, the ATO controls, and the heater settings. WHEW! Going to be a fun weekend. :D
Posted: Fri Nov 16, 2012 6:42 pm
Looks great!
Re: JerkyJunky's Starter Screen
Posted: Fri Nov 16, 2012 6:50 pm
by jerkyjunky
Thanks! Still some errors that will pop up I already know of. I'm not clearing everything that needs to be so I'll get some artifacts I'm sure. Sucks the tank is still cycling and I can't play fully with the lights and cloud settings for a bit. Darn bacteria refusing to breed! :(
Posted: Fri Nov 16, 2012 8:14 pm
by binder
nice and busy screen. it has all the stuff you need. Looking good!
Posted: Tue Nov 20, 2012 9:23 pm
by jerkyjunky
Here is the next version of my display:
http://i.imgur.com/7zyND.jpg
As you can see, I have completed the Event Previewer area, and have it accurately (or so it seems) predicting the next lighting effect be it sunrise, sunset, dawn, dusk, cloud, or sunlight. It also should be saying the correct ETA as well. The bottom diag numbers are time of dawn tomorrow.
Here is the code I used to get it. I also have heavily modified cloud code. I've added in a min/max cloud fade chance. It also no longer used the ReversePWMSlope. Any feedback would be welcome! :-)
#include <SunLocation.h>
#define FONT_8x16
SunLocation sl;
time_t nextEvent = 0, timeSunRise, timeSunSet, nextCloud = 0;
String nextEventName;
boolean isCloudy = false;
//Cloud Defines:
#define Clouds_Every_X_Days 1
#define Cloud_Chance_per_Day 50
  // Minimum number of minutes for cloud duration.  Don't use max duration of less than 6
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 30
#define Min_Clouds_per_Day 2
#define Max_Clouds_per_Day 5
	// Time in minutes for the fade of a cloud to take affect
#define Cloud_Fade_Duration 3
	// Minimum fade of cloud
#define Min_Cloud_Fade 20
	// Maximum fade of cloud
#define Max_Cloud_Fade 70
//#define Start_Cloud_After NumMins(10,30)
//#define End_Cloud_Before NumMins(17,30)
#define Lightning_Chance_per_Cloud 0
byte cloudChance=0;
byte cloudDuration=0;
time_t cloudStart=0;
byte numClouds=0;
byte lightningChance=0;
byte cloudIndex=0;
byte lightningStatus=0;
byte cloudFade = 0;
    ReefAngel.Relay.On( Port2 );
    if (nextEvent == 0) {GetNextEvent();}
	//Moonlights
    ReefAngel.StandardLights(Port1, hour(timeSunSet - 900), minute(timeSunSet - 900), hour(timeSunRise + 900), minute(timeSunRise + 900));
	//Sump Lights
    ReefAngel.StandardLights(Port3, hour(timeSunSet - 60), minute(timeSunSet - 60), hour(timeSunRise + 60), minute(timeSunRise + 60));
	//Display Lights
    ReefAngel.StandardLights(Port4, hour(timeSunRise - 60), minute(timeSunRise - 60), hour(timeSunSet + 60), minute(timeSunSet + 60));
    //Sun Pattern for Display
    ReefAngel.PWM.SetDaylight(PWMSlope(hour(timeSunRise), minute(timeSunRise), hour(timeSunSet), minute(timeSunSet), 15, 100, 30, 0));
    //Sun Pattern for Sump
    ReefAngel.PWM.SetActinic(PWMSlope(hour(timeSunSet), minute(timeSunSet), hour(timeSunRise), minute(timeSunRise), 15, 100, 30, 0));
    if (now() >= nextEvent) { GetNextEvent(); }
    if (isCloudy)
    	ReefAngel.PWM.SetDaylight(PWMSlope(hour(cloudStart), minute(cloudStart), hour(cloudStart + cloudDuration), minute(cloudStart + cloudDuration), 100, cloudFade, 3, 100));
    ReefAngel.Portal("jerkyjunky");
void GetNextEvent()
		if (nextEvent == 0)
			sl.CalSun();
			timeSunRise = sl.GetSunRise();
			timeSunSet = sl.GetSunSet();
		if (now() < timeSunRise - 1800)
			nextEventName = "Dawn";
			nextEvent = timeSunRise - 1800;
		else if (now() < timeSunRise)
			sl.CalSun();
			cloudChance = 255;
			GetNextCloud();
			nextEventName = "Sunrise";
			nextEvent = timeSunRise;
		else if (now() >= timeSunSet + 1800)
                        sl.GetTomorrowSunRise(&timeSunRise);
		else if (now() >= timeSunSet)
			nextEventName = "Dusk";
			nextEvent = timeSunSet + 1800;
			if ((now() > nextCloud) && (nextCloud > 0))
				nextEventName = "Cloud";
				nextEvent = nextCloud;
			else if ((now() >= nextCloud) && (nextCloud > 0))
				isCloudy = true;
				cloudFade = random(Min_Cloud_Fade, Max_Cloud_Fade);
				nextEventName = "Sun";
				nextEvent = nextCloud + cloudDuration;
			else if (isCloudy)
				isCloudy = false;
				cloudIndex++;
				GetNextCloud();
				if (nextCloud > 0)
					nextEventName = "Sunset";
					nextEvent = timeSunSet;
void GetNextCloud()
		//Init - Ran by GetNextEvent() at Dawn once per day by setting cloudChance to 255
		if (cloudChance == 255)
			//is today cloudy?
			cloudChance = random(100);
			if ((cloudChance > Cloud_Chance_per_Day) || ((day() % Clouds_Every_X_Days) != 0))
				cloudChance = 0;
				time_t t = now();
				numClouds = random(Min_Clouds_per_Day, Max_Clouds_per_Day);
				cloudStart = t - ((hour(t) * 3600) + (minute(t) * 60) + second(t));
				cloudStart += (random(timeSunRise, timeSunRise + ((timeSunSet - timeSunRise) / (numClouds * 2)))) * 60;
				cloudDuration = (random(Min_Cloud_Duration, Max_Cloud_Duration)) * 60;
				lightningChance = random(100);
				if (lightningChance > Lightning_Chance_per_Cloud) lightningChance = 0;
			if (cloudIndex < numClouds)
				time_t t = now();
				cloudStart += (random(timeSunRise + (((timeSunSet - timeSunRise) / (numClouds * 2)) * cloudIndex * 2), (timeSunRise + (((timeSunSet - timeSunRise) / (numClouds * 2)) * cloudIndex * 2)) + ((timeSunSet - timeSunRise) / (numClouds * 2)))) * 60;
				cloudStart = 0;
				cloudDuration = 0;
				cloudIndex = 0;
    byte offset = 3;
    byte atoPort = 3;
    offset = 26;
    ReefAngel.LCD.Clear(DefaultBGColor, 1, offset, 45, offset + 21);
    offset = offset + 23;
    ReefAngel.LCD.DrawText(COLOR_BLACK, DefaultBGColor, 5, offset, "Tank Level");
    ReefAngel.LCD.DrawLargeText(COLOR_BLUE, DefaultBGColor, 19, offset + 9, "Full", Font8x16);
    strcat(text, "%");
    ReefAngel.LCD.Clear(DefaultBGColor, 1, offset + 9, 60, offset + 22);
    ReefAngel.LCD.DrawLargeText(COLOR_ORANGE, DefaultBGColor, 23, offset + 9, text, Font8x16);
    strcat(text, "%");
    ReefAngel.LCD.DrawLargeText(COLOR_RED, DefaultBGColor, 23, offset + 9, text, Font8x16);
    // Lights
    if (dispLights > 0)
    if (sumpLights > 0)
    ReefAngel.LCD.Clear(DefaultBGColor, 1, offset + 9, 128, offset + 22);
    strcat(text, "%");
    if (strlen(text) == 5)
      ReefAngel.LCD.DrawLargeText(COLOR_BLUE, DefaultBGColor, 10, offset + 9, text, Font8x16);
    else if (strlen(text) == 4)
      ReefAngel.LCD.DrawLargeText(COLOR_BLUE, DefaultBGColor, 14, offset + 9, text, Font8x16);
    else if (strlen(text) == 3)
      ReefAngel.LCD.DrawLargeText(COLOR_BLUE, DefaultBGColor, 18, offset + 9, text, Font8x16);
      ReefAngel.LCD.DrawLargeText(COLOR_BLUE, DefaultBGColor, 22, offset + 9, text, Font8x16);
    strcat(text, "%");
      ReefAngel.LCD.DrawLargeText(COLOR_BLUE, DefaultBGColor, 80, offset + 9, text, Font8x16);
      ReefAngel.LCD.DrawLargeText(COLOR_BLUE, DefaultBGColor, 84, offset + 9, text, Font8x16);
      ReefAngel.LCD.DrawLargeText(COLOR_BLUE, DefaultBGColor, 88, offset + 9, text, Font8x16);
      ReefAngel.LCD.DrawLargeText(COLOR_BLUE, DefaultBGColor, 92, offset + 9, text, Font8x16);
    offset = offset + 25;
    ReefAngel.LCD.Clear(DefaultBGColor, 1, offset, 128, offset + 17);
    ReefAngel.LCD.DrawText(COLOR_BLACK, DefaultBGColor, 2, offset, "Next Event:");
    nextEventName.toCharArray(text, 10);
    ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor, 70, offset, text);
    ReefAngel.LCD.DrawText(COLOR_BLACK, DefaultBGColor, 2, offset + 9, "Time Until:");
    if (nextEvent > now())
      ConvertNumToString(text, hour(nextEvent - now()), 1);
      strcat(text, ":");
      ReefAngel.LCD.DrawText(COLOR_BLACK, DefaultBGColor, 75, offset + 9, text);
      ConvertNumToString(text, minute(nextEvent - now()), 1);
      ReefAngel.LCD.DrawText(COLOR_BLACK, DefaultBGColor, 95, offset + 9, text);
      ReefAngel.LCD.DrawText(COLOR_BLACK, DefaultBGColor, 75, offset + 9, "NOW!");
    ConvertNumToString(text, hour(timeSunSet) , 1);
    ReefAngel.LCD.DrawText(COLOR_BLACK, DefaultBGColor, 2, offset + 18, text);
    ConvertNumToString(text, minute(timeSunSet) , 1);
    ReefAngel.LCD.DrawText(COLOR_BLACK, DefaultBGColor, 70, offset + 18, text);
Posted: Wed Nov 21, 2012 11:21 am
Pretty cool :)
Posted: Thu Nov 29, 2012 9:25 pm
by psyrob
Like it! I especially like how you tucked the relay circles up in the corner...
Posted: Wed Dec 05, 2012 3:53 pm
by jerkyjunky
Thanks! The code for it should be in the other how do I area if you wanted just that how to bit. :-)
I've edited a bit more and fixed some issues with the clouds not processing correctly. Also added in the ATO bit. I have a bucket on the side of my stand with RODI water in it and a pump. The pump has a float switch on it so I know if I'm about to suck air or not (LowATO). There is also an emergency float in the sump to act as a redundant check to the water sensor kit (HighATO). Other than that cleaned it up a bit and added better comments here and there.
#define FONT_8x16
SunLocation sl;
boolean isATOAvail = false;
byte atoPort = 0;;
//Cloud Defines:
#define Cloud_Chance_per_Day 25
byte cloudChance=0;
byte numClouds=0;
byte cloudIndex=0;
byte cloudFade = 0;
	//This must be the first line
	//Ports toggled in Feeding Mode
	ReefAngel.FeedingModePorts = Port7Bit;
	//Ports toggled in Water Change Mode
	ReefAngel.WaterChangePorts = Port8Bit;
	//Ports toggled when Lights On / Off menu entry selected
	//Ports turned off when Overheat temperature exceeded
	//Use T1 probe as temperature and overheat functions
	//Set the Overheat temperature setting
	InternalMemory.OverheatTemp_write(800);
	//Set the port ATO is on numerically
	atoPort = 6;
	//Enable LED driver board fan
	//Enable heater port - Currently not used
	//Enable skimmer
	//Enable return pump
	//Get an event at startup
	//Moonlights
	ReefAngel.StandardLights(Port1, hour(timeSunSet - 90), minute(timeSunSet - 90), hour(timeSunRise + 90), minute(timeSunRise + 90));
	//Sump Lights
	//Display Lights
	ReefAngel.StandardLights(Port4, hour(timeSunRise - 1860), minute(timeSunRise - 1860), hour(timeSunSet + 1860), minute(timeSunSet + 1860));
	if (isCloudy)
		ReefAngel.PWM.SetDaylight(PWMSlope(hour(nextCloud), minute(nextCloud), hour(nextCloud + cloudDuration), minute(nextCloud + cloudDuration), 100, cloudFade, 3, 100));
		ReefAngel.PWM.SetDaylight(PWMSlope(hour(timeSunRise - 1800), minute(timeSunRise - 1800), hour(timeSunSet + 1800), minute(timeSunSet + 1800), 15, 100, 30, 0));
	//ATO code
	//check emergency float switch detector in sump for overfilling
		ReefAngel.Relay.Off(Port6);
	//else check status of top off bucket
	//check if bucket level is too low to pump from or if water in sump is getting too high
	else if ((ReefAngel.LowATO.IsActive() == false) || (ReefAngel.WaterLevel.GetLevel() > 90))
	//check if pump should be enabled
	else if ((ReefAngel.LowATO.IsActive()) && (ReefAngel.WaterLevel.GetLevel() <= 80))
		ReefAngel.Relay.On(Port6);
	//Event logic
	//if we just past the current event, go get another
void GetNextEvent()
	//check if called from setup and if so establish current day's params
	if (nextEvent == 0)
		sl.CalSun();
	//WHEN IS IT?!?!?
	//Before the sun starts peeking over the horizon?
	//Is the sun rising?
	//Use this time to figure out if today will be cloudy since we can kind of see the sky now
		sl.CalSun();
		cloudChance = 255;
		GetNextCloud();
	//Is it after the sun has fully set?
	//Is the sun starting to descend?
	//Sun is up.  What now?  Clouds perhaps?
		//If clouds today, are we before a cloud?
		if ((now() < nextCloud) && (nextCloud > 0))
		//We have just entered a cloud zone
			isCloudy = true;
		//We are leaving a cloud zone, but are there more?  Find out.
		else if (isCloudy)
			isCloudy = false;
			cloudIndex++;
			GetNextCloud();
			if (nextCloud > 0)
		//Nope, no clouds today.  Get ready for sunset.
void GetNextCloud()
			//Is today cloudy?
			if (cloudChance <= Cloud_Chance_per_Day)
				time_t t = now();
				int minSunRise = 0, minSunSet = 0;
				minSunRise = (hour(timeSunRise) * 60) + minute(timeSunRise);
				minSunSet = (hour(timeSunSet) * 60) + minute(timeSunSet);
				nextCloud = t - ((hour(t) * 3600) + (minute(t) * 60) + second(t));
				nextCloud += (random(minSunRise, minSunRise + ((minSunSet - minSunRise) / (numClouds * 2)))) * 60;
		//We must have picked a cloudy day, but are there more?
				time_t t = now();
				nextCloud += (random(minSunRise + (((minSunSet - minSunRise) / (numClouds * 2)) * cloudIndex * 2), (minSunRise + (((minSunSet - minSunRise) / (numClouds * 2)) * cloudIndex * 2)) + ((minSunSet - minSunRise) / (numClouds * 2)))) * 60;
			//Nope, out of clouds for today
				nextCloud = 0;
				cloudDuration = 0;
				cloudIndex = 0;
    byte offset = 3;																					//Display offset vertically
    byte waterLevel = ReefAngel.WaterLevel.GetLevel();				//Percentage of water height based off sensor (aprox 3-5 inches off top of sump height)
    byte dispLights = ReefAngel.PWM.GetDaylightValue();				//Percentage of lights on display
    byte sumpLights = ReefAngel.PWM.GetActinicValue();				//Percentage of lights on sump
    byte TempRelay = ReefAngel.Relay.RelayData;								//--------------------
    TempRelay &= ReefAngel.Relay.RelayMaskOff;								//Setup for relay info
    TempRelay |= ReefAngel.Relay.RelayMaskOn;									//--------------------
    //Header Section - Title + Date and Time
    offset = 26;
    //Main Relay Box & Main Parameters
    //Water Level
    strcat(text, "%");
    else if (waterLevel >= 90)
	    ReefAngel.LCD.DrawLargeText(COLOR_BLUE, DefaultBGColor, 23, offset + 9, text, Font8x16);
    else if ((waterLevel < 90) && (waterlevel >=80))
    //ATO - Avail?
    //ATO - Pump?
    //Lights
    if (dispLights > 0)
    if (sumpLights > 0)
    strcat(text, "%");
    strcat(text, "%");
    //Events Viewer
      strcat(text, ":");
    //Diag
    ConvertNumToString(text, hour(nextCloud) , 1);
    ConvertNumToString(text, cloudChance , 1);
Posted: Sat Dec 08, 2012 4:47 pm
by alexwbush
where is the ReefAngel.LCD.DrawCircleOutletBoxHorizontal() function?
Posted: Sat Dec 08, 2012 5:01 pm
It's not there yet :(
Maybe in the next libraries release
Posted: Sun Jan 06, 2013 6:36 pm
by psyrob
So how does jerkyjunky get the horizontal box on his screen? Did he add the function to the libraries himself, in NokiaLCD?
Posted: Sun Jan 06, 2013 6:49 pm
Probably. Its not in his PDE. I know he wasn't shy editing SunLocation for some things he needed.
Posted: Sun Jan 06, 2013 7:11 pm
It's in the queue of things to be updated and released in next libraries updates.
https://github.com/reefangel/Libraries/issues/56
