I set the offset to -13 hours so that it would match the longest light cycle you had which was your DayLight PWM... typically this is your Actinics btw.. if you ever wanted to use the Memory locations and utilize the ActinicOffset, you'd need to reverse your setup.
This will put your light's on tomorrow at 6:56am and off at 8:47pm with your Actinic's on one hour after sunrise and one hour before sunset. Keep in mind that we are currently in the "long" days in GBR time... so as we get to summer, your light cycle will shrink.... The difference between winter and summer at GBR though is only 2hours... not as big as here in the US
Anyway, here's your code, verified in Arduino. I added comments as well for what I added and why.
Let me know if you have any questions and I can explain further.
Lee
#define Return pump Port1
#define ATS pump Port2
#define Scrubber light Port3
#define Fuge light Port4
#define Calcium doser Port5
#define Alk doser Port6
#define Food doser Port7
#define Main LED fan Port8
#include <SunLocation.h>
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
// We declare this here so we can use it in multiple functions
SunLocation sl;
ReefAngel.FeedingModePorts = Port1Bit;
ReefAngel.WaterChangePorts = Port1Bit;
ReefAngel.LightsOnPorts = Port3Bit | Port4Bit | Port8Bit;
// Since we only need to set OffSet once, then it can go in setup()
// Great Barrier reef is currently +15 hours from us.
// Current GBR Rise/Set is 4:56am/6:47am
// Instead of subtracing the 15 hours, I only subtracted 13.
// This will make it close to your 7am-9pm light cycle.
sl.SetOffset(-13,472,-13,506); // The 472/506 were corrections I made to the formula, you can leave them or set them to 0 if you want.
ReefAngel.Relay.On( Port2 );
ReefAngel.StandardLights( Port3,20,0,8,0 );
ReefAngel.StandardLights( Port4,18,0,12,0 );
ReefAngel.DosingPumpRepeat( Port5,0,60,60 );
ReefAngel.DosingPumpRepeat( Port6,30,60,60 );
ReefAngel.DosingPumpRepeat( Port7,0,30,60 );
ReefAngel.StandardLights( Port8,6,0,22,0 );
// Each day we're going to update Sunrise/Sunset, so it's part of the loop() function
sl.CheckAndUpdate();
// We've replaced the 7,0,21,0 with the Rise/Set Hour/Minute. Current GBR Rise/Set is 4:56am/6:47am
DaylightPWMValue=PWMParabola(sl.GetRiseHour(),sl.GetRiseMinute(),sl.GetSetHour(),sl.GetSetMinute(),12,100,12);
// We've replaced the 8,0,20,0 with the Rise/Set Hour/Minute +1/-1 to from GBR Rise/Set
ActinicPWMValue=PWMParabola(sl.GetRiseHour()+1,sl.GetRiseMinute(),sl.GetSetHour()-1,sl.GetSetMinute(),12,80,12) ;
CheckCloud();
ReefAngel.Portal("jedimasterben");
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 30
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 3
#define Lightning_Change_per_Cloud 25
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
ActinicPWMValue=100;
DaylightPWMValue=0;
ActinicPWMValue=0;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
int x=0;
if (lightningchance)
int x=0;
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
