Lee's Feature Complete PDE
PostPosted: Tue Jul 28, 2015 6:01 pm
Lnevo,
How would I go about using your gap fill-in code for moonlights with my LEDs on the Daylight and actinic PWM outputs? My ver 2.1 code can be found on bottom of page....thanks for looking.
viewtopic.php?f=11&t=4731
PostPosted: Wed Aug 05, 2015 5:16 am
What ports are your moonlights on?
PostPosted: Wed Aug 05, 2015 5:22 am
I don't have them on ports. I use the moonphase coding on my actinic pwm channel.
Sent from my Samsung Galaxy Note 3
PostPosted: Thu Aug 06, 2015 8:58 pm
I'm not sure I'm following.
My LEDs don't go below a certain effective %. After around 7% any lower there is no change in PAR or brightness and it is still pretty bright. I have my moonlights come on at 100% and ramp down to 0% to make up for that. I turn the moonlights on right before my main lights go off.
Since your moonlights are on the same channel as your LED there's nothing that can be "filled in"
PostPosted: Fri Aug 21, 2015 6:11 am
Roberto, were you able to up the character count at all? Is it possible?
PostPosted: Fri Aug 21, 2015 9:08 am
Which count?
PostPosted: Fri Aug 21, 2015 11:54 am
lnevo wrote:Roberto,
I can no longer post my code. It's > 60,000 characters. I'm at 69k :)
PostPosted: Fri Aug 21, 2015 11:56 am
Ahhh.
Try again. Increased to 100K
If it doesn't work, I may need to reboot the forum app.
PostPosted: Fri Aug 21, 2015 1:19 pm
Cool. I'll give it a try shortly.
PostPosted: Fri Aug 21, 2015 2:23 pm
Ok the code is now up to date. It worked :) A few bug fixes since July, especially on the third dosing pump.
Return to My PDE/INO file
