Page 7 of 9
Re: Lee's Feature Complete PDE
Posted: Tue Jul 28, 2015 6:01 pm
by 89delta
Lnevo,
How would I go about using your gap fill-in code for moonlights with my LEDs on the Daylight and actinic PWM outputs? My ver 2.1 code can be found on bottom of page....thanks for looking.
http://forum.reefangel.com/viewtopic.php?f=11&t=4731
Posted: Wed Aug 05, 2015 5:16 am
What ports are your moonlights on?
Posted: Wed Aug 05, 2015 5:22 am
by 89delta
I don't have them on ports. I use the moonphase coding on my actinic pwm channel.
Sent from my Samsung Galaxy Note 3
Posted: Thu Aug 06, 2015 8:58 pm
I'm not sure I'm following.
My LEDs don't go below a certain effective %. After around 7% any lower there is no change in PAR or brightness and it is still pretty bright. I have my moonlights come on at 100% and ramp down to 0% to make up for that. I turn the moonlights on right before my main lights go off.
Since your moonlights are on the same channel as your LED there's nothing that can be "filled in"
Posted: Fri Aug 21, 2015 6:11 am
Roberto, were you able to up the character count at all? Is it possible?
Posted: Fri Aug 21, 2015 9:08 am
Which count?
Posted: Fri Aug 21, 2015 11:54 am
lnevo wrote:Roberto,
I can no longer post my code. It's > 60,000 characters. I'm at 69k :)
Posted: Fri Aug 21, 2015 11:56 am
Ahhh.
Try again. Increased to 100K
If it doesn't work, I may need to reboot the forum app.
Posted: Fri Aug 21, 2015 1:19 pm
Cool. I'll give it a try shortly.
Posted: Fri Aug 21, 2015 2:23 pm
Ok the code is now up to date. It worked :) A few bug fixes since July, especially on the third dosing pump.
Posted: Fri Aug 28, 2015 11:57 pm
by ritz
Where did you post the code? The only one I could find was from 2013. I've been dying to steal some of your coding! ;)
Thanks.
Posted: Sat Aug 29, 2015 4:08 am
Its in the 2nd post. It may say its from 2013 but I edit it. It may say the time I edited in small print
Posted: Wed Feb 10, 2016 7:39 pm
Auto Water Change and Revamped mixing station.
Posted: Wed Feb 10, 2016 7:40 pm
Tanks looking good tonight
Posted: Tue Mar 15, 2016 5:09 am
by MDB1029
I am having trouble finding all the code needed for your coral acclimation mode. Can you advise on how to implement this?
Posted: Tue Mar 15, 2016 5:15 am
Which part do you want? The photoperiod or the dimming or both? Are you using SunLocation? Can you point me to your current code?
Posted: Tue Mar 15, 2016 5:36 am
by MDB1029
both photoperiod and dimming if possible. I don't use the sun location at this time because i have just never implemented it.
        int DaylightPWMValue=0;        // For cloud code
        ReefAngel.FeedingModePorts = Port1Bit | Port4Bit;
        ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit;
        ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit;
        ReefAngel.Relay.On( Port1 );   //return pump
        ReefAngel.Relay.On( Port4 );   //skimmer
        ReefAngel.StandardHeater( Port2 );  //heater 1
    if ( ReefAngel.Params.Temp[T1_PROBE] < (InternalMemory.HeaterTempOn_read() - 10)) { ReefAngel.Relay.On(Port3); };  //heater 2 on
    if ( ReefAngel.Params.Temp[T1_PROBE] > (InternalMemory.HeaterTempOff_read() - 5)) { ReefAngel.Relay.Off(Port3); };  //heater 2 off
        ReefAngel.SingleATOLow( Port5 );  //ATO pump
            DaylightPWMValue=PWMSlopeHighRes(10,00,20,0,0,55,60,0);  //daylights
         CheckCloud();
         ReefAngel.PWM.SetChannelRaw(1,DaylightPWMValue);
        ReefAngel.PWM.SetChannelRaw(0,PWMSlopeHighRes(9,00,21,00,0,50,90,0));  // Blues
        ReefAngel.PWM.SetChannelRaw(2,PWMSlopeHighRes(9,30,20,30,0,55,60,0));  // spectrum
        ReefAngel.StandardLights(Port6,18,0,10,0);  // Fuge light from 1800 to 1000
        if ( ReefAngel.PWM.GetChannelValueRaw(0) < 16 ||ReefAngel.PWM.GetChannelValue(0)>100)
            ReefAngel.PWM.SetChannelRaw(0,16) ;  //moonlight value
        ReefAngel.DosingPumpRepeat1( Port7 );  //ALK doser
        ReefAngel.DosingPumpRepeat2( Port8 );  //Cal doser
        ReefAngel.Portal( "MDB1029" );
        ReefAngel.DDNS( "Reef" ); // Your DDNS is MDB1029-Reef.myreefangel.com
          void CheckCloud()
        #define Clouds_Every_X_Days 1
        #define Cloud_Chance_per_Day 33
        #define Min_Cloud_Duration 7
        #define Max_Cloud_Duration 14
        #define Min_Clouds_per_Day 1
        #define Max_Clouds_per_Day 2
          // In this example, start cloud after noon
        #define Start_Cloud_After NumMins(11,00)
        #define End_Cloud_Before NumMins(19,00)
        #define Lightning_Change_per_Cloud 50
          // Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes
          // of effects or unforseen result could happen.
          // In our example, we have 510 minutes between Start_Cloud_After and End_Cloud_Before, so double the
          // 250 minutes (or 500 minutes) can fit in that 510 minutes window.
          // Add Random Lightning modes
        #define Calm 0    // No lightning
        #define Slow 1    // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
        #define Fast 2    // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
        #define Mega 3    // Lightning throughout the cloud, higher chance as it gets darker
        #define Mega2 4   // Like Mega, but with more lightning
          // Example:  { Calm, Fast, Mega, Mega2 } to randomize all four modes.
          // { Mega2 } for just Mega2.  { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
          byte LightningModes[] = {Mega,Calm,Fast};
          static byte cloudchance=255;
          static byte cloudduration=0;
          static int cloudstart=0;
          static byte numclouds=0;
          static byte cloudindex=0;
          static int LastNumMins=0;
          static byte lightningMode=0;
          static time_t DelayCounter=millis();    // Variable for lightning timing.
          static int DelayTime=random(1000);      // Variable for lightning timimg.
        #ifdef forcecloudcalculation
          if (cloudchance==255)
        #else
        #endif
              randomSeed(millis());    // Seed the random number generator
              cloudchance=random(100);
              // If we have cloud today
              if (cloudchance)
                lightningchance=random(100);
          if (cloudchance)
            //is it time for cloud yet?
              DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue/40.95,0,180)*40.95;
              if (chooseLightning)
                chooseLightning=false;
              switch (lightningMode)
              case Calm:
                break;
              case Mega:
                // Lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
                  // Send the trigger
                  Strike();
                  DelayCounter=millis();    // If we just had a round of flashes, then lets put in a longer delay
                  DelayTime=random(1000);   // of up to a second for dramatic effect before we do another round.
                break;
              case Mega2:
                // Higher lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
                  Strike();
                break;
              case Fast:
                  Strike();
                break;
              case Slow:
                // Slow lightning for 5 seconds in the middle of the cloud.  Suitable for slower ELN style drivers
                  else lightningstatus=0;
                  if (lightningstatus)
                    DaylightPWMValue=4095;
                    DaylightPWMValue=0;
                  delay(1);
                break;
              default:
                break;
              cloudindex++;
              if (cloudindex < numclouds)
            /*ReefAngel.LCD.Clear(255,0,120,132,132);
             ReefAngel.LCD.DrawText(0,255,51,120,"00:00"); */
              int x=0;
              else x=17;
              //ReefAngel.LCD.DrawText(0,255,x,120,(cloudstart/60));
              ReefAngel.CustomVar[3]=cloudstart/60; // Write the hour of the next cloud to custom variable for Portal reporting
              else x=35;
              //ReefAngel.LCD.DrawText(0,255,x,120,(cloudstart%60));
              ReefAngel.CustomVar[4]=cloudstart%60; // Write the minute of the next cloud to custom variable for Portal reporting
            //ReefAngel.LCD.DrawText(0,255,90,120,cloudduration);
            ReefAngel.CustomVar[7]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
            if (lightningchance)
              int x=0;
              if (((cloudstart+(cloudduration/2))/60)>=10) x=51;
              else x=57;
              //ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))/60));
              ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
              if (((cloudstart+(cloudduration/2))%60)>=10) x=69;
              else x=75;
              //ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60)); // Write the minute of the next lightning to a custom variable for the Portal
                ReefAngel.CustomVar[6]=(cloudstart+(cloudduration/2))%60;
        void Strike()
          int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
          for (int i=0; i<a; i++)
            // Flash on
            int newdata=4095;
            Wire.beginTransmission(0x40);      // Address of the dimming expansion module
            Wire.write(0x8+(4*1));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 1.
            Wire.write(newdata&0xff);          // Send the data 8 bits at a time.  This sends the LSB
            Wire.write(newdata>>8);            // This sends the MSB
            Wire.endTransmission();
            int randy=random(20,80);    // Random number for a delay
            if (randy>71) randy=((randy-70)/2)*100;    // Small chance of a longer delay
            delay(randy);                // Wait from 20 to 69 ms, or 100-400 ms
            // Flash off.  Return to baseline.
            newdata=ReefAngel.PWM.GetChannelValueRaw(1);   // Use the channel number you're flashing here
            Wire.beginTransmission(0x40);    // Same as above
            delay(random(30,50));                // Wait from 30 to 49 ms
            wdt_reset();    // Reset watchdog timer to avoid re-boots
          cstart*=60;
          cend*=60;
          if (n>cend) return (int) PWMStart;
Posted: Tue Mar 15, 2016 4:05 pm
by MDB1029
Sorry, I have another question for you as well.
I would really like to add the moon phases. My current moonlights run off my regular dimming channel 0 which is my main Actinic/Royal Blue channel with this code,
Would i be able to implement the moon phases off of this same channel?
Posted: Wed Mar 16, 2016 7:46 pm
by MDB1029
lnevo wrote:Which part do you want? The photoperiod or the dimming or both? Are you using SunLocation? Can you point me to your current code?
I have my code posted here now http://forum.reefangel.com/viewtopic.php?f=11&t=5934
Posted: Wed Mar 16, 2016 8:18 pm
Ok give me a little time and try to parse through your code and then see what we can do.
Posted: Wed Mar 16, 2016 10:10 pm
by MDB1029
lnevo wrote:Ok give me a little time and try to parse through your code and then see what we can do.
No problem. I appreciate any help you can give me.
Posted: Sun Mar 20, 2016 7:49 am
Ok, definitely need to think about how I'm going to best do this... are you looking to acclimate all 3 spectrums? I think I have to abstract the code a bit so you can pass some parameters to how each channel is being acclimated. It may be an improvement on my code as well. Give me some more time.
Posted: Sun Mar 20, 2016 7:53 am
by MDB1029
I usually run my red/green/uv lights with my actinic channel. So i would just need to make sure they aren't at 100% when the rest of the lights are at 50%. If it makes it easier to add the sunlocation code to get this to work it can be added, I have been planning on using that code, just haven't had a chance to get it coded in yet.
Posted: Tue Apr 05, 2016 7:33 am
by 89delta
I ran my 6-channel LEDs on the pwm channels. I ran my reds and greens with the white channel and UV with my blues. Sunrise location is within my code.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Posted: Tue May 03, 2016 4:02 pm
by dansonamission
Hi,
Im new to RA but not so new to Arduinos.
Running the Mac Arduino IDE from the RA website, 1.0.1, with Lee's code and I am receiving many errors when i try to verify the sketch. All the library folders have been copied into place.
I've also tried many other codes from the forums and receive many errors on them too. Maybe I'm missing something for setting the RA software initially?
Can some one point me in the right direction of RA's sample code? I don't see it anywhere to download and its not included in the mac download.
Many thanks
Number of Relay Expansion Modules: 3
Number of Menu Options: 9
Reef_Angel_Lee.cpp: In function 'void setup()':
Reef_Angel_Lee:256: error: 'class ReefAngelClass' has no member named 'InitMenu'
Reef_Angel_Lee:281: error: 'class ReefAngelClass' has no member named 'RF'
Reef_Angel_Lee.cpp: In function 'void CheckPower()':
Reef_Angel_Lee:341: error: 'class RelayClass' has no member named 'IsRelayPresent'
Reef_Angel_Lee:354: error: 'class ReefAngelClass' has no member named 'RF'
Reef_Angel_Lee:359: error: 'class RelayClass' has no member named 'IsRelayPresent'
Reef_Angel_Lee.cpp: In function 'void SetSun()':
Reef_Angel_Lee:434: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:439: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:440: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:442: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:443: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:448: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:449: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:451: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:452: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:457: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:458: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:460: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:461: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:466: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:467: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:469: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:470: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:475: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:476: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:478: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:479: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee.cpp: In function 'void SetMoon()':
Reef_Angel_Lee:517: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:518: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:523: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:524: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:528: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:529: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:533: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:534: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:538: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:539: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee.cpp: In function 'void FillInMoon()':
Reef_Angel_Lee:554: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:557: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:558: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:559: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:560: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:562: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:563: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee.cpp: In function 'void AcclimateLED()':
Reef_Angel_Lee:575: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:577: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:579: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:581: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee.cpp: In function 'void LEDPresets()':
Reef_Angel_Lee:604: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:605: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:606: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:607: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:608: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:609: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee.cpp: In function 'void UpdateLED()':
Reef_Angel_Lee:732: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:733: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:734: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:735: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:736: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:737: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:741: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:742: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:743: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:744: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee.cpp: In function 'void SetTide()':
Reef_Angel_Lee:759: error: 'class ReefAngelClass' has no member named 'CustomVar'
Reef_Angel_Lee.cpp: In function 'void SetRF()':
Reef_Angel_Lee:769: error: 'class ReefAngelClass' has no member named 'RF'
Reef_Angel_Lee:770: error: 'class ReefAngelClass' has no member named 'RF'
Reef_Angel_Lee:786: error: 'class ReefAngelClass' has no member named 'RF'
Reef_Angel_Lee:787: error: 'class ReefAngelClass' has no member named 'RF'
Reef_Angel_Lee:797: error: 'class ReefAngelClass' has no member named 'RF'
Reef_Angel_Lee.cpp: In function 'void RFCustom()':
Reef_Angel_Lee:839: error: 'class ReefAngelClass' has no member named 'CustomVar'
Reef_Angel_Lee:843: error: 'class ReefAngelClass' has no member named 'RF'
Reef_Angel_Lee:848: error: 'class ReefAngelClass' has no member named 'RF'
Reef_Angel_Lee:853: error: 'class ReefAngelClass' has no member named 'RF'
Reef_Angel_Lee:858: error: 'class ReefAngelClass' has no member named 'RF'
Reef_Angel_Lee:863: error: 'class ReefAngelClass' has no member named 'RF'
Reef_Angel_Lee:868: error: 'class ReefAngelClass' has no member named 'RF'
Reef_Angel_Lee:924: error: 'class ReefAngelClass' has no member named 'RF'
Reef_Angel_Lee:925: error: 'class ReefAngelClass' has no member named 'RF'
Reef_Angel_Lee.cpp: In function 'void CheckATO()':
Reef_Angel_Lee:936: error: 'class ReefAngelClass' has no member named 'WaterLevel'
Reef_Angel_Lee:942: error: 'class ReefAngelClass' has no member named 'CustomVar'
Reef_Angel_Lee.cpp: In function 'void RefillATO()':
Reef_Angel_Lee:965: error: 'class ReefAngelClass' has no member named 'WaterLevel'
Reef_Angel_Lee.cpp: In function 'void LogFeedings()':
Reef_Angel_Lee:1026: error: 'class ReefAngelClass' has no member named 'CustomVar'
Reef_Angel_Lee.cpp: In function 'void adjustAlk()':
Reef_Angel_Lee:1152: error: 'class ReefAngelClass' has no member named 'CustomVar'
Reef_Angel_Lee:1153: error: 'class ReefAngelClass' has no member named 'CustomVar'
Reef_Angel_Lee:1158: error: 'class ReefAngelClass' has no member named 'CustomVar'
Reef_Angel_Lee:1166: error: 'class ReefAngelClass' has no member named 'CustomVar'
Reef_Angel_Lee.cpp: In function 'void LogDosingPumps()':
Reef_Angel_Lee:1193: error: 'class ReefAngelClass' has no member named 'CustomVar'
Reef_Angel_Lee:1199: error: 'class ReefAngelClass' has no member named 'CustomVar'
Reef_Angel_Lee.cpp: In function 'void LockPorts()':
Reef_Angel_Lee:1301: error: 'class ReefAngelClass' has no member named 'OverridePortsE'
Reef_Angel_Lee:1302: error: 'class ReefAngelClass' has no member named 'OverridePortsE'
Reef_Angel_Lee:1304: error: 'class ReefAngelClass' has no member named 'OverridePortsE'
Reef_Angel_Lee:1305: error: 'class ReefAngelClass' has no member named 'OverridePortsE'
Reef_Angel_Lee.cpp: In function 'void DailyReport()':
Reef_Angel_Lee:1332: error: 'class ReefAngelClass' has no member named 'WaterLevel'
Reef_Angel_Lee.cpp: In function 'void MenuEntry8()':
Reef_Angel_Lee:1402: error: 'class ReefAngelClass' has no member named 'SetupCalibrateWaterLevel'
Reef_Angel_Lee.cpp: In function 'void DrawParams(int, int)':
Reef_Angel_Lee:1467: error: 'class RA_NokiaLCD' has no member named 'DrawLargeText'
Reef_Angel_Lee:1469: error: 'class RA_NokiaLCD' has no member named 'DrawLargeText'
Reef_Angel_Lee.cpp: In function 'void DrawStatus(int, int)':
Reef_Angel_Lee:1478: error: 'class RA_NokiaLCD' has no member named 'DrawLargeText'
Reef_Angel_Lee:1479: error: 'class RA_NokiaLCD' has no member named 'DrawLargeText'
Reef_Angel_Lee:1496: error: 'class ReefAngelClass' has no member named 'WaterLevel'
Reef_Angel_Lee:1497: error: 'class ReefAngelClass' has no member named 'WaterLevel'
Reef_Angel_Lee:1504: error: 'class RA_NokiaLCD' has no member named 'DrawLargeText'
Reef_Angel_Lee:1505: error: 'class RA_NokiaLCD' has no member named 'DrawLargeText'
Reef_Angel_Lee:1506: error: 'class RA_NokiaLCD' has no member named 'DrawLargeText'
Reef_Angel_Lee:1507: error: 'class RA_NokiaLCD' has no member named 'DrawLargeText'
Reef_Angel_Lee:1508: error: 'class RA_NokiaLCD' has no member named 'DrawLargeText'
Reef_Angel_Lee:1509: error: 'class RA_NokiaLCD' has no member named 'DrawLargeText'
Reef_Angel_Lee:1510: error: 'class RA_NokiaLCD' has no member named 'DrawLargeText'
Reef_Angel_Lee:1511: error: 'class RA_NokiaLCD' has no member named 'DrawLargeText'
Reef_Angel_Lee:1512: error: 'class RA_NokiaLCD' has no member named 'DrawLargeText'
Reef_Angel_Lee:1513: error: 'class RA_NokiaLCD' has no member named 'DrawLargeText'
Reef_Angel_Lee.cpp: In function 'void DrawSunMoon(int, int)':
Reef_Angel_Lee:1562: error: 'MoonPhaseLabel' was not declared in this scope
Reef_Angel_Lee:1567: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:1568: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee.cpp: In function 'void DrawRelays(int, int)':
Reef_Angel_Lee:1580: error: 'class RelayClass' has no member named 'RelayDataE'
Reef_Angel_Lee:1581: error: 'class RelayClass' has no member named 'RelayMaskOffE'
Reef_Angel_Lee:1582: error: 'class RelayClass' has no member named 'RelayMaskOnE'
Reef_Angel_Lee:1586: error: 'class RelayClass' has no member named 'RelayDataE'
Reef_Angel_Lee:1587: error: 'class RelayClass' has no member named 'RelayMaskOffE'
Reef_Angel_Lee:1588: error: 'class RelayClass' has no member named 'RelayMaskOnE'
Reef_Angel_Lee.cpp: In function 'void Strike()':
Reef_Angel_Lee:1899: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:1906: error: 'class ReefAngelClass' has no member named 'PWM'
Posted: Tue May 03, 2016 7:06 pm
It looks like it's not finding the libraries. You copied them to ~/Documents/Arduino?
The example code should be visible in the menus if the folder is in the right spot.
Posted: Wed May 04, 2016 1:58 am
by dansonamission
lnevo wrote:It looks like it's not finding the libraries. You copied them to ~/Documents/Arduino?
They are in the correct library folder. I've looked through the library folders and none of them contain example files.
Going to try the windows software next.
Posted: Wed May 04, 2016 2:01 am
Something is either wrong in your arduino gui settings, i would check the preferences, as you said you arent new to arduino so maybe its referencing a different folder in your prefs. The arduino folder that comes on the mac image should contain the examples, wizard, and the feature directory not just the libraries. The errors you are getting are 100% telling me its not finding the libraries.
Posted: Wed May 04, 2016 2:08 am
by dansonamission
lnevo wrote:Something is either wrong in your arduino gui settings, i would check the preferences, as you said you arent new to arduino so maybe its referencing a different folder in your prefs. The arduino folder that comes on the mac image should contain the examples, wizard, and the feature directory not just the libraries. The errors you are getting are 100% telling me its not finding the libraries.
Maybe I'm looking in the wrong place here, I downloaded the libraries from GitHub as there were no libraries included in the mac img download. Just a help doc, wifi utility and Arduino IDE. Which when run was using my library folder in my documents. I can see the libraries listed when going to sketch, include library....
Posted: Wed May 04, 2016 2:10 am
Yeah thats the problem if you only downloaded the libraries. In the dmg file there should be an Arduino folder that you're supposed to drag to Documents. If you already had that folder then maybe it dropped into there. Either way check the dmg again and grab the contents of the Arduino folder and make sure they are in the documents/arduino folder.
You may also want to remove the prefernces file for the arduino ide just to make sure nothing was lingering.
