Lee's Feature Complete PDE
PostPosted: Fri Aug 28, 2015 11:57 pm
Where did you post the code? The only one I could find was from 2013. I've been dying to steal some of your coding! ;)
Thanks.
PostPosted: Sat Aug 29, 2015 4:08 am
Its in the 2nd post. It may say its from 2013 but I edit it. It may say the time I edited in small print
PostPosted: Wed Feb 10, 2016 7:39 pm
Auto Water Change and Revamped mixing station.
PostPosted: Wed Feb 10, 2016 7:40 pm
Tanks looking good tonight
PostPosted: Tue Mar 15, 2016 5:09 am
I am having trouble finding all the code needed for your coral acclimation mode. Can you advise on how to implement this?
PostPosted: Tue Mar 15, 2016 5:15 am
Which part do you want? The photoperiod or the dimming or both? Are you using SunLocation? Can you point me to your current code?
PostPosted: Tue Mar 15, 2016 5:36 am
both photoperiod and dimming if possible. I don't use the sun location at this time because i have just never implemented it.
        int DaylightPWMValue=0;        // For cloud code
        ReefAngel.FeedingModePorts = Port1Bit | Port4Bit;
        ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit;
        ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit;
        ReefAngel.Relay.On( Port1 );   //return pump
        ReefAngel.Relay.On( Port4 );   //skimmer
        ReefAngel.StandardHeater( Port2 );  //heater 1
    if ( ReefAngel.Params.Temp[T1_PROBE] < (InternalMemory.HeaterTempOn_read() - 10)) { ReefAngel.Relay.On(Port3); };  //heater 2 on
    if ( ReefAngel.Params.Temp[T1_PROBE] > (InternalMemory.HeaterTempOff_read() - 5)) { ReefAngel.Relay.Off(Port3); };  //heater 2 off
        ReefAngel.SingleATOLow( Port5 );  //ATO pump
            DaylightPWMValue=PWMSlopeHighRes(10,00,20,0,0,55,60,0);  //daylights
         CheckCloud();
         ReefAngel.PWM.SetChannelRaw(1,DaylightPWMValue);
        ReefAngel.PWM.SetChannelRaw(0,PWMSlopeHighRes(9,00,21,00,0,50,90,0));  // Blues
        ReefAngel.PWM.SetChannelRaw(2,PWMSlopeHighRes(9,30,20,30,0,55,60,0));  // spectrum
        ReefAngel.StandardLights(Port6,18,0,10,0);  // Fuge light from 1800 to 1000
        if ( ReefAngel.PWM.GetChannelValueRaw(0) < 16 ||ReefAngel.PWM.GetChannelValue(0)>100)
            ReefAngel.PWM.SetChannelRaw(0,16) ;  //moonlight value
        ReefAngel.DosingPumpRepeat1( Port7 );  //ALK doser
        ReefAngel.DosingPumpRepeat2( Port8 );  //Cal doser
        ReefAngel.Portal( "MDB1029" );
        ReefAngel.DDNS( "Reef" ); // Your DDNS is MDB1029-Reef.myreefangel.com
          void CheckCloud()
        #define Clouds_Every_X_Days 1
        #define Cloud_Chance_per_Day 33
        #define Min_Cloud_Duration 7
        #define Max_Cloud_Duration 14
        #define Min_Clouds_per_Day 1
        #define Max_Clouds_per_Day 2
        #define Start_Cloud_After NumMins(11,00)
        #define End_Cloud_Before NumMins(19,00)
        #define Lightning_Change_per_Cloud 50
          // Add Random Lightning modes
        #define Calm 0    // No lightning
        #define Slow 1    // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
        #define Fast 2    // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
        #define Mega 3    // Lightning throughout the cloud, higher chance as it gets darker
        #define Mega2 4   // Like Mega, but with more lightning
          // Example:  { Calm, Fast, Mega, Mega2 } to randomize all four modes.
          // { Mega2 } for just Mega2.  { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
          byte LightningModes[] = {Mega,Calm,Fast};
          static byte cloudchance=255;
          static byte cloudduration=0;
          static int cloudstart=0;
          static byte numclouds=0;
          static byte cloudindex=0;
          static int LastNumMins=0;
          static byte lightningMode=0;
          static time_t DelayCounter=millis();    // Variable for lightning timing.
          static int DelayTime=random(1000);      // Variable for lightning timimg.
        #ifdef forcecloudcalculation
          if (cloudchance==255)
        #else
        #endif
              randomSeed(millis());    // Seed the random number generator
              cloudchance=random(100);
              // If we have cloud today
              if (cloudchance)
                lightningchance=random(100);
          if (cloudchance)
            //is it time for cloud yet?
              if (chooseLightning)
                chooseLightning=false;
              switch (lightningMode)
              case Calm:
                break;
              case Mega:
                // Lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
                  // Send the trigger
                  Strike();
                  DelayCounter=millis();    // If we just had a round of flashes, then lets put in a longer delay
                  DelayTime=random(1000);   // of up to a second for dramatic effect before we do another round.
                break;
              case Mega2:
                // Higher lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
                  Strike();
                break;
              case Fast:
                  Strike();
                break;
              case Slow:
                // Slow lightning for 5 seconds in the middle of the cloud.  Suitable for slower ELN style drivers
                  else lightningstatus=0;
                  if (lightningstatus)
                    DaylightPWMValue=4095;
                    DaylightPWMValue=0;
                  delay(1);
                break;
              default:
                break;
              cloudindex++;
              if (cloudindex < numclouds)
              int x=0;
              else x=17;
              else x=35;
            ReefAngel.CustomVar[7]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
            if (lightningchance)
              int x=0;
              else x=57;
              ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
              else x=75;
        void Strike()
          int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
          for (int i=0; i<a; i++)
            // Flash on
            int newdata=4095;
            Wire.beginTransmission(0x40);      // Address of the dimming expansion module
            Wire.write(0x8+(4*1));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 1.
            Wire.write(newdata&0xff);          // Send the data 8 bits at a time.  This sends the LSB
            Wire.write(newdata>>8);            // This sends the MSB
            Wire.endTransmission();
            int randy=random(20,80);    // Random number for a delay
            if (randy>71) randy=((randy-70)/2)*100;    // Small chance of a longer delay
            delay(randy);                // Wait from 20 to 69 ms, or 100-400 ms
            // Flash off.  Return to baseline.
            newdata=ReefAngel.PWM.GetChannelValueRaw(1);   // Use the channel number you're flashing here
            Wire.beginTransmission(0x40);    // Same as above
            delay(random(30,50));                // Wait from 30 to 49 ms
            wdt_reset();    // Reset watchdog timer to avoid re-boots
          cstart*=60;
          cend*=60;
PostPosted: Tue Mar 15, 2016 4:05 pm
Sorry, I have another question for you as well.
I would really like to add the moon phases. My current moonlights run off my regular dimming channel 0 which is my main Actinic/Royal Blue channel with this code,
Would i be able to implement the moon phases off of this same channel?
PostPosted: Wed Mar 16, 2016 7:46 pm
lnevo wrote:Which part do you want? The photoperiod or the dimming or both? Are you using SunLocation? Can you point me to your current code?
I have my code posted here now http://forum.reefangel.com/viewtopic.php?f=11&t=5934
PostPosted: Wed Mar 16, 2016 8:18 pm
Ok give me a little time and try to parse through your code and then see what we can do.
Return to My PDE/INO file
