wavemaker question
PostPosted: Thu Jan 31, 2013 8:37 pm
I have two tanks, each with two power heads, on separate relays. Because I want flow in each tank should the power go off, each tank has a powerhead on both relays. What I am trying to do is have them to run opposite of each other. I wrote this code:
ReefAngel.WavemakerRandom( Port5,60,100 );
    ReefAngel.Relay.Set( Box1_Port5, !ReefAngel.Relay.Status( Port5 ) ); //Randomize DT powerheads
    ReefAngel.WavemakerRandom( Port6,60,100 );
    ReefAngel.Relay.Set( Box1_Port6, !ReefAngel.Relay.Status( Port6 ) ); //Randomize GT powerheads
What happens is tank DT (Display Tank) works fine, while tank GT (grow tank) port 6 doesn't come on at all and box1_port6 comes on and stays on. I probably can't have two WavemakerRandoms. How can I change this up to do what I want?
PostPosted: Thu Jan 31, 2013 9:43 pm
Yeah, you can't use WavemakerRandom twice. It messes with the timers... :(
But there are 2 more to use :)
Just change the second WavemakerRandom to WavemakerRandom1 or WavemakerRandom2.
PostPosted: Fri Feb 01, 2013 5:54 pm
worked like a charm...thank you.
Return to My PDE/INO file
