// Autogenerated file by RAGen (v1.0.4.92), (08/10/2011 10:52)
// RA_081011_1052.pde
#define DisplayImages
#define WavemakerSetup
#define DateTimeSetup
#define VersionMenu
#define ATOSetup
#define DirectTempSensor
#define SingleATOSetup
#define StandardLightSetup
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#include <Phillips6610LCDInv.h>
#include <avr/pgmspace.h>
Phillips6610LCDInv e;
void ConvertNumToString(char* string, int num, byte decimal)
char temptxt[3];
int Temp = num;
if (Temp==0xFFFF) Temp=0;
itoa(Temp/decimal,string,10);
if (decimal>1)
itoa(Temp%decimal,temptxt,10);
strcat(string, ".");
if (Temp%decimal<10 && decimal==100) strcat(string, "0");
strcat(string, temptxt);
byte x = 6;
byte y = 2;
byte t;
ReefAngel.LCD.DrawDate(6, 2);
x = 12;
y += MENU_START_ROW+1;
ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, "Temp pH");
char text[7];
ReefAngel.LCD.Clear(DefaultBGColor, x+16, y+65, x+65, y+16);
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+75, y+18, text,
Font8x16);
y += MENU_START_ROW*2;
x = 10;
x += (16*4) + 8;
ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor,x+8,y+25,"Temp2:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp2, T2TempColor,
x+24, y+35, 10);
ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor,x+8,y+50,"Temp3:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp3, T3TempColor,
x+24, y+60, 10);
y += 39*2;
x = 13;
ReefAngel.Relay.On(Port8);
ReefAngel.Relay.On(Port7);
ReefAngel.Relay.On(Port6);
// Specific functions
ReefAngel.StandardLights(Port1, 13, 30, 00, 30);
ReefAngel.StandardATO(Port2, 2400); //Quantidade de segundos para reposição, se desligar pelo timer, led vermelho do RA acende e bloqueia a reposição
ReefAngel.StandardFan(Port3, 270, 264); // Turn fan/chiller on at 270C and off at 264C
ReefAngel.StandardHeater(Port4, 260, 266); // Turn heater on at 260C and off at 266C
I need to change this file (PDE) as follows:
Output 1: LED lighting
Output 2: Vortech pump
Output 3: heating
Output 4: Cooling
Output 5: safety valve for the reverse osmosis
Output 6: recirculation pump
Output 7: unused
Output 8: skimmer (with delay of 2 minutes)
For the "Output 5" I must call it 40 minutes every two hours and if the level sensor trigger "the Angel Reef" off the Output 5.
Need to eliminate the third number after the decimal point .
I will not use PWM and wave-maker, I would take everything that is not necessary.
Can anyone help me?
Tanks guys
