Posts: 111 Joined: Thu Jun 28, 2012 1:46 pm
 Posted: Thu Jul 23, 2015 7:58 pm
lnevo wrote:Your error is coming from somewhere else. It's a syntax error. Whats the tide code your trying to add? Post your before and after code in full.
Yeah, it is a compile or type-o on my part for sure. I removed it and added a if statement to slow them down after lights out. That appeared to work ok. At this point and time it is more of a learning / reading threads to understand how the libraries work that I want to use. I see the tidal simulation and also found the weather pattern based on location. Both of which sound super cool but not sure how to implement  Also am trying to understand what the various power head modes do. I have reef crest implemented now and saw a graph somewhere, not sure where now, but it looked cool. Not sure how the sync anti-sync work though. My original post was to make them alternate so they don't always go the same direction - thus tide/high/low. Does the library automatically sync-anti-sync or change directions based on a set time? Anyway - they are working now and slow down at night. That was the first hurdle. Now it is just playing and learning. Like why Daylight is 41% vs. Actinic at 69% (they change all the time) but I have power set to 55%? Even if it is plus 10, I am over and seen it higher. Thanks - searching and reading  Good stuff and love the additions. - Code: Select all
#include <ReefAngel_Features.h> #include <Globals.h> #include <RA_Wifi.h> #include <Wire.h> #include <OneWire.h> #include <Time.h> #include <DS1307RTC.h> #include <InternalEEPROM.h> #include <RA_NokiaLCD.h> #include <RA_ATO.h> #include <RA_Joystick.h> #include <LED.h> #include <RA_TempSensor.h> #include <Relay.h> #include <RA_PWM.h> #include <Timer.h> #include <Memory.h> #include <InternalEEPROM.h> #include <RA_Colors.h> #include <RA_CustomColors.h> #include <Salinity.h> #include <RF.h> #include <IO.h> #include <ORP.h> #include <AI.h> #include <PH.h> #include <WaterLevel.h> #include <Humidity.h> #include <DCPump.h> #include <PAR.h> #include <ReefAngel.h> #include <Tide.h> // testing for tide control
////// Place global variable code below here Tide tide; // testing for tide control
void setup() { // This must be the first line ReefAngel.Init(); //Initialize controller ReefAngel.Use2014Screen(); // Let's use 2014 Screen ReefAngel.AddPHExpansion(); // pH Expansion Module // Ports toggled in Feeding Mode ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit; // Ports toggled in Water Change Mode ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit; // Ports toggled when Lights On / Off menu entry selected ReefAngel.LightsOnPorts = 0; // Ports turned off when Overheat temperature exceeded ReefAngel.OverheatShutoffPorts = Port2Bit; // Use T1 probe as temperature and overheat functions ReefAngel.TempProbe = T1_PROBE; ReefAngel.OverheatProbe = T1_PROBE; // Set the Overheat temperature setting InternalMemory.OverheatTemp_write( 869 );
// Feeeding and Water Change mode speed ReefAngel.DCPump.FeedingSpeed=0; ReefAngel.DCPump.WaterChangeSpeed=0;
// Ports that are always on ReefAngel.Relay.On( Port1 ); // skimmer // ReefAngel.Relay.On( Port4 ); // LED Fans ReefAngel.Relay.On( Port5 ); // RW 4 left side facing tank ReefAngel.Relay.On( Port6 ); // RW 4 right side facing tank
////// Place additional initialization code above here }
void loop() { ReefAngel.StandardLights( Port2,9,0,21,0 ); // power to LED power supply ReefAngel.StandardLights( Port4,9,0,21,0 ); // LED fans // ReefAngel.WavemakerRandom( Port5,5,90 ); // Not sure what these are for now // ReefAngel.WavemakerRandom( Port6,5,90 ); // Not sure what these are for now // ReefAngel.StandardLights( Port7,9,0,21,0 ); // ReefAngel.StandardLights( Port8,9,0,21,0 );
// Channel 0 (1000mA max) - 5 Neutral White // Channel 1 (1000mA max) - 6 Royal Blue + 5 Blue // Channel 2 (700mA max) - 12 Lime // Channel 3 (700mA max) - 5 Violet UV + 4 Deep Red (660nm) ReefAngel.PWM.SetChannel( 0, PWMParabola(10,0,21,0,0,65,0) ); ReefAngel.PWM.SetChannel( 1, PWMParabola(10,0,21,0,0,75,0) ); ReefAngel.PWM.SetChannel( 2, PWMParabola(10,0,21,0,0,65,0) ); ReefAngel.PWM.SetChannel( 3, PWMParabola(10,0,21,0,0,65,0) );
ReefAngel.DCPump.UseMemory = false; // ReefAngel.DCPump.SetMode( ReefCrest,55,10 ); ReefAngel.DCPump.DaylightChannel = Sync; ReefAngel.DCPump.ActinicChannel = AntiSync;
// ReefAngel.DCPump.ExpansionChannel[0] = None; // ReefAngel.DCPump.ExpansionChannel[1] = None; // ReefAngel.DCPump.ExpansionChannel[2] = None; // ReefAngel.DCPump.ExpansionChannel[3] = None; // ReefAngel.DCPump.ExpansionChannel[4] = None; // ReefAngel.DCPump.ExpansionChannel[5] = None; ////// Place your custom code below here
if (hour()>=21 || hour()<10) { // Sleep mode - slow things down ReefAngel.DCPump.SetMode( ReefCrest,25,10 ); } else { // Normal power ReefAngel.DCPump.SetMode( ReefCrest,55,10 ); }
// This should always be the last line ReefAngel.Portal( "saf1" ); ReefAngel.DDNS( "saf1-dns.myreefangel.com" ); // Your DDNS is saf1-saf1-dns.myreefangel.com.myreefangel.com ReefAngel.ShowInterface(); }
