Posts: 151 Joined: Wed Mar 13, 2013 5:36 pm
 Posted: Wed Mar 20, 2013 7:02 pm
This post will always be my most current code
09/24/2015 - Code: Select all
#include <SoftwareSerial.h> #include <ReefAngel_Features.h> #include <Globals.h> #include <RA_Wifi.h> #include <Wire.h> #include <OneWire.h> #include <Time.h> #include <DS1307RTC.h> #include <InternalEEPROM.h> #include <RA_NokiaLCD.h> #include <RA_ATO.h> #include <RA_Joystick.h> #include <LED.h> #include <RA_TempSensor.h> #include <Relay.h> #include <RA_PWM.h> #include <Timer.h> #include <Memory.h> #include <RA_Colors.h> #include <RA_CustomColors.h> #include <Salinity.h> #include <RF.h> #include <IO.h> #include <ORP.h> #include <AI.h> #include <PH.h> #include <WaterLevel.h> #include <Humidity.h> #include <DCPump.h> #include <PAR.h> #include <ReefAngel.h> /* #define Heater 1 #define Return 2 #define 3 #define Skimmer 4 #define Vortech1 5 #define Vortech2 6 #define ATO 7 #define Sump Light 8 */ ////// Place global variable code below here byte vtechmode, vtSpeed, vtDuration; ////// Place global variable code above here
void setup() { // This must be the first line ReefAngel.Init(); //Initialize controller // Ports toggled in Feeding Mode ReefAngel.FeedingModePorts = 0; ReefAngel.FeedingModePortsE[0] = Port2Bit; // Ports toggled in Water Change Mode ReefAngel.WaterChangePorts = 0; ReefAngel.WaterChangePortsE[0] = 0; // Ports toggled when Lights On / Off menu entry selected ReefAngel.LightsOnPorts = 0; ReefAngel.LightsOnPortsE[0] = 0; // Ports turned off when Overheat temperature exceeded ReefAngel.OverheatShutoffPorts = 0; ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port2Bit; // Use T1 probe as temperature and overheat functions ReefAngel.TempProbe = T1_PROBE; ReefAngel.OverheatProbe = T1_PROBE; // Set the Overheat temperature setting InternalMemory.OverheatTemp_write( 830 ); ReefAngel.AddRANet();
// Ports that are always on ReefAngel.Relay.On( Port2 ); ReefAngel.Relay.On( Port3 ); ReefAngel.Relay.On( Port4 ); ReefAngel.Relay.On( Port5 ); ReefAngel.Relay.On( Port6 ); ReefAngel.Relay.On( Port7 ); ReefAngel.Relay.On( Port8 ); ReefAngel.Relay.On( Box1_Port1 ); ReefAngel.Relay.On( Box1_Port2 ); ReefAngel.Relay.On( Box1_Port3 ); ReefAngel.Relay.On( Box1_Port4 ); ReefAngel.Relay.On( Box1_Port5 ); ReefAngel.Relay.On( Box1_Port6 ); ReefAngel.Relay.On( Box1_Port7 ); ReefAngel.Relay.On( Box1_Port8 );
////// Place additional initialization code below here // Hardcode calibrations ReefAngel.PHMin=576; // PH7.0 ReefAngel.PHMax=842; // PH10.0 // ReefAngel.SalMax=3300; // 35ppt ////// Place additional initialization code above here }
void loop() { vtechmode=InternalMemory.RFMode_read(); vtSpeed=InternalMemory.RFSpeed_read(); vtDuration=InternalMemory.RFDuration_read();
static unsigned long feeding; ReefAngel.StandardHeater( Port1,778,782 ); // ReefAngel.WaterLevelATO( Port7,180,71,74 ); // ReefAngel.StandardLights( Port8,15,0,2,0 ); ReefAngel.PWM.SetChannel( 0,PWMSlope(13,40,21,00,0,0,40,0) ); //LIME ReefAngel.PWM.SetChannel( 1,PWMSlope(13,40,22,00,15,100,30,0) ); //RB ReefAngel.PWM.SetChannel( 2,PWMSlope(13,40,21,00,15,100,30,0) ); //WHITE ReefAngel.PWM.SetChannel( 3,PWMSlope(13,40,21,00,15,80,30,0) ); //BLUE&CYAN ReefAngel.PWM.SetChannel( 4,PWMSlope(13,40,21,00,15,80,30,0) ); //UV if ( ReefAngel.HighATO.IsActive()) { ReefAngel.Relay.On(Port2); } else { ReefAngel.Relay.Off(Port2); } if (now() % 10800 == 0 ) while(1); if (hour() >=12 && hour() < 21) { // if (ReefAngel.RF.Mode==Night) ReefAngel.RF.SetMode(Feeding_Stop,0,0); ReefAngel.RF.UseMemory=true; // ReefAngel.RF.SetMode(ReefCrest,60,20); if (ReefAngel.DisplayedMenu==FEEDING_MODE) { feeding=now(); } if (now()-feeding<5400) { // if (now()-feeding > 1 && now()-feeding < 5400) { // 1 second after feeding mode until 90 minutes after feeding mode. ReefAngel.RF.UseMemory=false; ReefAngel.RF.SetMode(Smart_NTM,75,10); } } else { ReefAngel.RF.UseMemory=false; ReefAngel.RF.SetMode(Constant,10,0); } if (vtechmode!=InternalMemory.RFMode_read()) InternalMemory.RFMode_write(vtechmode); if (vtSpeed!=InternalMemory.RFSpeed_read()) InternalMemory.RFSpeed_write(vtSpeed); if (vtDuration!=InternalMemory.RFDuration_read()) InternalMemory.RFDuration_write(vtDuration);
// This should always be the last line ReefAngel.Portal( "bencollinz" ); ReefAngel.ShowInterface(); } void DrawCustomMain() { char text[7]; // Date and Time ReefAngel.LCD.DrawDate( 6, 2 ); ReefAngel.LCD.Clear(COLOR_BLACK, 1, 11, 132, 11); pingSerial();
ReefAngel.LCD.DrawText(0,255,18,12,"EcoSmart Vortech"); ReefAngel.LCD.Clear(255, 1, 19, 128, 29); if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,21,"Constant"); else if (vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,21,"Lagoon"); else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,21,"Reef Crest"); else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,21,"Short Pulse"); else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,21,"Long Pulse"); else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,21,"Nutrient Trnsp."); else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,21,"Tidal Swell"); else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,21,"Night");
ReefAngel.LCD.DrawText(0,255,4,30,"RF Speed:"); ReefAngel.LCD.Clear(255,59,29,128,39); ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,71,31,vtSpeed); ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,90,31,"/"); ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,100,31,vtDuration); ReefAngel.LCD.DrawText(0,255,10,40,"Salt"); ConvertNumToString(text, ReefAngel.Params.Temp[T1_PROBE], 10); ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 50, text, Num8x8); pingSerial();
ReefAngel.LCD.DrawText(0,255,100,40,"pH"); ConvertNumToString(text, ReefAngel.Params.PH, 100); ReefAngel.LCD.DrawLargeText(COLOR_PLUM, 255, 85, 50, text, Num8x8); pingSerial();
ReefAngel.LCD.DrawText(0,255,13,58,"Salinity"); ConvertNumToString(text, ReefAngel.Params.Salinity, 10); ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 13, 68, text, Num8x8); pingSerial();
// water level ReefAngel.LCD.DrawText(0,255,68,58,"WL"); ReefAngel.LCD.DrawText( COLOR_CORNFLOWERBLUE,255, 68, 68, ReefAngel.WaterLevel.GetLevel() ); pingSerial();
// Main Relay Box byte TempRelay = ReefAngel.Relay.RelayData; TempRelay &= ReefAngel.Relay.RelayMaskOff; TempRelay |= ReefAngel.Relay.RelayMaskOn; ReefAngel.LCD.DrawOutletBox( 12, 108, TempRelay ); pingSerial(); // Relay Expansion TempRelay = ReefAngel.Relay.RelayDataE[0]; TempRelay &= ReefAngel.Relay.RelayMaskOffE[0]; TempRelay |= ReefAngel.Relay.RelayMaskOnE[0]; ReefAngel.LCD.DrawOutletBox( 12, 120, TempRelay ); pingSerial(); } void DrawCustomGraph() { }
