My code - now with RAnet
Re: My code - water level ATO help needed
I think you already figured out, but just for records...
Your reference to T1 was wrong....
It should be this:
bencollinz
Post by bencollinz »
rimai wrote:I think you already figured out, but just for records...
It should be this:
yessir! everything is working so far, have to wait and see about the ATO changes.
bencollinz
Re: My code
            if ( ReefAngel.LowATO.IsActive())
                ReefAngel.Relay.On(Port2);
                ReefAngel.Relay.Off(Port2);
for this, how do I require a clear command from RA menu when tripped?
Re: My code
Use the SingleATOLow function
SingleATOLow(Port2);
bencollinz
Re: My code
lnevo wrote:Use the SingleATOLow function
maybe I'm misunderstanding, I changed it to this:
ReefAngel.SingleATOLow(Port2);
and it doesn't turn port 2 off, just changes the status on the portal....?
My code
Did you change that whole section of code? It should go off when the switch is inactive. You may have the switch upside down. Which way is it facing?
bencollinz
Re: My code
lnevo wrote:Did you change that whole section of code? It should go off when the switch is inactive. You may have the switch upside down. Which way is it facing?
the wires are facing up. i removed
and replaced with
again, maybe I'm misunderstanding, sorry.
bencollinz
lnevo wrote:It sounds like from what you want is to use the WaterLevelATO and just increase your timeout... or reduce the high/low difference...
I would suggest something like this.. 3 minutes instead of 1.
ReefAngel.WaterLevelATO( Port7,180,52,58 ); // 180 seconds timeout, turn on at 52% and turn off at 58%
Another thing that will help to put the numbers in a better perspective is.. How long does it take to fill your sump from 52 to 58. That plus a few seconds is what you want your timeout to be.
The code you have everytime it drops to 57 it will turn on till 58 and sometimes the reported level varies from the sensor, so thats why you're seeing on / off / on / off
The other choice is making the numbers smaller. If you want it on at 52%, then leave than and reduce the 58 to something you can get to within 60 seconds.. Say 54%
ReefAngel.WaterLevelATO( Port7,60,52,54 ); // 60 seconds timeout, turn on at 52% and turn off at 54%
so i changed it back to this format
water went from 61% to now 50% and it didn't turn on even for a blip...ideas?
Re: My code
Are you sure it isn't timed out already?
Just to be sure, can you clear ATO?
bencollinz
Re: My code
rimai wrote:Are you sure it isn't timed out already?
the red light was on, I chose clear ATO it started and wouldn't stop. the red light came on again, I cleared again, it still wouldn't turn off. it's now at 61% again. I had to turn off manually.
current code:
    #define Heater      1
    #define Return      2
    #define Skimmer     3
    #define Vortech1    5
    #define Vortech2    6
    #define ATO         7
byte vtechmode;
        ReefAngel.FeedingModePorts = Port4Bit | Port5Bit | Port6Bit;
        ReefAngel.WaterChangePorts = Port7Bit | Port4Bit | Port5Bit | Port6Bit;
        ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port7Bit | Port4Bit | Port5Bit | Port6Bit;
        ReefAngel.Relay.On( Port2 );
    // Hardcode calibrations
    ReefAngel.PHMin=576; // PH7.0
    ReefAngel.PHMax=842; // PH10.0
        ReefAngel.SalMax=3000; // 35ppt
        ReefAngel.StandardHeater( Port1,796,802 );
        ReefAngel.WaterLevelATO( Port7,600,58,60 );
        // If water level less than 58, turn on auto top off relay; else, keep it off
            // if (ReefAngel.WaterLevel.GetLevel()<58) ReefAngel.Relay.On(Port7);
             // else ReefAngel.Relay.Off(Port7);
        ReefAngel.PWM.SetChannel( 0, MoonPhase() );
        ReefAngel.PWM.Channel2PWMParabola();
        ReefAngel.PWM.Channel3PWMParabola();
        ReefAngel.PWM.Channel4PWMSlope();
        // ReefAngel.SingleATOLow(Port2);
        if (hour() <= 8 && hour() >= 20)
            ReefAngel.RF.UseMemory=false;
            vtechmode = 9;
             ReefAngel.RF.UseMemory=true;
             vtechmode = InternalMemory.RFMode_read();
        ReefAngel.Portal( "bencollinz" );
        char text[7];
        ReefAngel.LCD.DrawDate( 6, 2 );
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 90, "--------------------");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 126, "--------------------");
  for (byte Left=93; Left < 133; Left+=10)
    ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, Left, "|");
    ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, Left, "|");
 ReefAngel.LCD.DrawText(0,255,18,12,"EcoSmart Vortech");
  ReefAngel.LCD.Clear(255, 1, 19, 128, 29);
  if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,21,"Constant");
  else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,21,"Lagoon");
  else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,21,"Reef Crest");
  else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,21,"Short Pulse");
  else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,21,"Long Pulse");
  else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,21,"Nutrient Trnsp.");
  else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,21,"Tidal Swell");
  else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,21,"Night");
  ReefAngel.LCD.DrawText(0,255,10,30,"Temp");
  ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 40, text, Num8x8);
  ReefAngel.LCD.DrawLargeText(COLOR_PLUM, 255, 85, 40, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,43,48,"Salinity");
  ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 49, 58, text, Num8x8);
        ReefAngel.LCD.DrawOutletBox( 12, 77, TempRelay );
// water level
    ReefAngel.LCD.DrawText(0,255,8,68,"WL:");
    ReefAngel.LCD.DrawText( COLOR_CORNFLOWERBLUE,255, 40, 68, ReefAngel.WaterLevel.GetLevel() );
Re: My code
Are you sure you uploaded this code?
It says timeout is 600 seconds. Was your ATO pump on for 600 seconds before it turned the red led again?
bencollinz
Re: My code
rimai wrote:Are you sure you uploaded this code?
yes, that is the current code.
the red light comes on after 10 mins every time I 'clear ATO' from menu, regardless of the port running or not.
The port did turn itself off at the proper % finally, though.
Re: My code
So, you are getting ato timeout even when the port is supposed to be off?
You are not overriding it off, are you?
If you do, it would definitely timeout.
bencollinz
Re: My code
rimai wrote:So, you are getting ato timeout even when the port is supposed to be off?
so, for example, right now, the red light is on. i'll 'clear ato', the water is at 56%, so the port turned on for ATO, the red light came back on ~1-2 mins, i 'clear ato' (the port still on all the while), the port shuts off at 60%.
it's on auto via portal or reboot, not changing to off.
bencollinz
Re: My code
and now the red light is on again. ~10 mins after I last pressed 'clear ato'
cleared it again, got it ~2 mins later
Re: My code
I think you found a bug :)
Can you disconnect the ATO Low float switch and see if the problem is fixed?
bencollinz
Re: My code
rimai wrote:I think you found a bug :)
I unplugged that, rebooted RA, let it sit for 20 mins and now my return pump port 2 just shut off.
but that was also the first time i set port 2 to auto instead of on.
bencollinz
Re: My code
the ATO pump went on and off just as it should without the float switch! and no red light to clear.
Re: My code
Yeah, just what thought.
The libraries code is sharing the part of the code with the low float switch.
I'll have to update it.
Should be fixed in the next update.
In the mean time, you can use the high ato port for your return.
Re: My code
bencollinz
Re: My code
just wanted to say the ATO pump went on/off as it should through the nite and it only takes ~1 min for it to go from 58% to 60%. no red light. I did not reconnect float switch yet.
My code
Awesome!
bencollinz
Re: My code
added floatswitch back with HighATO
    #define Heater      1
    #define Return      2
    #define Skimmer     3
    #define Vortech1    5
    #define Vortech2    6
    #define ATO         7
byte vtechmode;
        ReefAngel.WaterLevelATO( Port7,180,58,60 );
        if ( ReefAngel.HighATO.IsActive())
            vtechmode = 9;
      char text[7];
// water level
so far it's good.
had to use this code to get my RF working
    //#define Constant      0
    //#define Random1       1 // Lagoonal
    //#define Random2       2 // Reef Crest
    //#define ShortWave     3
    //#define LongWave      4
    //#define Smart_NTM     5 // Nutrient Transport Mode
    //#define Smart_TSM     6 // Tidal Swell Mode
    //#define Feeding_Start 7
    //#define Feeding_Stop  8
    //#define Night         9
    //#define Slave_Start   97
    //#define Slave_Stop    98
    //#define None          99
      ReefAngel.LCD.DrawText(0,255,20,50,"Assigning Slaves");
      ReefAngel.RF.SendData(Slave_Start,0,0);
      InternalMemory.RFMode_write(0);
      InternalMemory.RFSpeed_write(128);
      InternalMemory.RFDuration_write(10);
      ReefAngel.Refresh();
      if (ReefAngel.Joystick.IsButtonPressed())
        ReefAngel.RF.SendData(Slave_Stop,0,0);
        ReefAngel.LCD.DrawText(0,255,50,60,"Done");
bencollinz
Re: My code
so my vortechs are always stuck in night mode
    #define Heater      1
    #define Return      2
    #define Skimmer     3
    #define Vortech1    5
    #define Vortech2    6
    #define ATO         7
byte vtechmode;
        ReefAngel.Relay.On( Port5 );
        ReefAngel.WaterLevelATO( Port7,120,58,60 );
        ReefAngel.PWM.Channel1PWMSlope();
        ReefAngel.PWM.Channel2PWMSlope();
        ReefAngel.PWM.Channel3PWMSlope();
        if (hour() >=8 && hour() < 20)
             ReefAngel.RF.SetMode(Feeding_Stop,0,0); //Temp fix for coming out of Night mode
      char text[7];
// water level
what do I need to change?
Re: My code
First off, it looks like your Night mode is set to go during the day. Can you check and see if during the night before 8am and after 8pm if you are still in Night mode.
This bit is what says what time... right now it says greater than 8am and before 8pm be in Night mode..
This bit says when not in night mode to use Memory. Can you confirm what values you have set in the portal for your Vortechs
As I said, it looks like your in Night mode during the day...
bencollinz
Re: My code
lnevo wrote:First off, it looks like your Night mode is set to go during the day. Can you check and see if during the night before 8am and after 8pm if you are still in Night mode.
so this instead?
            if (hour() <=8 && hour() > 20)
portal is set to tidal swell. RA display shows "night" and RF is breathing white.
Re: My code
Yep, you have the time right now. Give it a try.
Re: My code
Actually that condition would never happen.
Try this:
    if (ReefAngel.RF.Mode==Night) ReefAngel.RF.SetMode(Feeding_Stop,0,0);
Re: My code
Good catch. Can't believe I missed that... the other option is to just change the && to ||
bencollinz
Re: My code
rimai wrote:Actually that condition would never happen.
Try this:
thank you very much!!
this did it!
