My code - now with RAnet
PostPosted: Tue Mar 26, 2013 9:31 am
Are you sure you uploaded this code?
It says timeout is 600 seconds. Was your ATO pump on for 600 seconds before it turned the red led again?
PostPosted: Tue Mar 26, 2013 1:28 pm
rimai wrote:Are you sure you uploaded this code?
yes, that is the current code.
the red light comes on after 10 mins every time I 'clear ATO' from menu, regardless of the port running or not.
The port did turn itself off at the proper % finally, though.
PostPosted: Tue Mar 26, 2013 2:29 pm
So, you are getting ato timeout even when the port is supposed to be off?
You are not overriding it off, are you?
If you do, it would definitely timeout.
PostPosted: Tue Mar 26, 2013 3:19 pm
rimai wrote:So, you are getting ato timeout even when the port is supposed to be off?
so, for example, right now, the red light is on. i'll 'clear ato', the water is at 56%, so the port turned on for ATO, the red light came back on ~1-2 mins, i 'clear ato' (the port still on all the while), the port shuts off at 60%.
it's on auto via portal or reboot, not changing to off.
PostPosted: Tue Mar 26, 2013 3:26 pm
and now the red light is on again. ~10 mins after I last pressed 'clear ato'
cleared it again, got it ~2 mins later
PostPosted: Tue Mar 26, 2013 4:04 pm
I think you found a bug :)
Can you disconnect the ATO Low float switch and see if the problem is fixed?
PostPosted: Tue Mar 26, 2013 4:49 pm
rimai wrote:I think you found a bug :)
I unplugged that, rebooted RA, let it sit for 20 mins and now my return pump port 2 just shut off.
but that was also the first time i set port 2 to auto instead of on.
PostPosted: Tue Mar 26, 2013 5:13 pm
the ATO pump went on and off just as it should without the float switch! and no red light to clear.
PostPosted: Tue Mar 26, 2013 5:35 pm
Yeah, just what thought.
The libraries code is sharing the part of the code with the low float switch.
I'll have to update it.
Should be fixed in the next update.
In the mean time, you can use the high ato port for your return.
PostPosted: Tue Mar 26, 2013 5:37 pm
It's been logged.
https://github.com/reefangel/Libraries/issues/72
Return to My PDE/INO file
