My code - now with RAnet
PostPosted: Wed Mar 27, 2013 4:14 am
just wanted to say the ATO pump went on/off as it should through the nite and it only takes ~1 min for it to go from 58% to 60%. no red light. I did not reconnect float switch yet.
PostPosted: Wed Mar 27, 2013 4:36 am
Awesome!
PostPosted: Wed Mar 27, 2013 12:50 pm
added floatswitch back with HighATO
    #define Heater      1
    #define Return      2
    #define Skimmer     3
    #define Vortech1    5
    #define Vortech2    6
    #define ATO         7
byte vtechmode;
        ReefAngel.FeedingModePorts = Port4Bit | Port5Bit | Port6Bit;
        ReefAngel.WaterChangePorts = Port7Bit | Port4Bit | Port5Bit | Port6Bit;
        ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port7Bit | Port4Bit | Port5Bit | Port6Bit;
        ReefAngel.Relay.On( Port2 );
   // Hardcode calibrations
   ReefAngel.PHMin=576; // PH7.0
   ReefAngel.PHMax=842; // PH10.0
        ReefAngel.SalMax=3000; // 35ppt
        ReefAngel.StandardHeater( Port1,796,802 );
        ReefAngel.WaterLevelATO( Port7,180,58,60 );
        // If water level less than 58, turn on auto top off relay; else, keep it off
            // if (ReefAngel.WaterLevel.GetLevel()<58) ReefAngel.Relay.On(Port7);
             // else ReefAngel.Relay.Off(Port7);
        ReefAngel.PWM.SetChannel( 0, MoonPhase() );
        ReefAngel.PWM.Channel2PWMParabola();
        ReefAngel.PWM.Channel3PWMParabola();
        ReefAngel.PWM.Channel4PWMSlope();
        // ReefAngel.SingleATOLow(Port2);
        if ( ReefAngel.HighATO.IsActive())
          ReefAngel.Relay.On(Port2);
          ReefAngel.Relay.Off(Port2);
        if (hour() <= 8 && hour() >= 20)
            ReefAngel.RF.UseMemory=false;
            vtechmode = 9;
             ReefAngel.RF.UseMemory=true;
             vtechmode = InternalMemory.RFMode_read();
        ReefAngel.Portal( "bencollinz" );
      char text[7];
        ReefAngel.LCD.DrawDate( 6, 2 );
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 90, "--------------------");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 126, "--------------------");
  for (byte Left=93; Left < 133; Left+=10)
    ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, Left, "|");
    ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, Left, "|");
 ReefAngel.LCD.DrawText(0,255,18,12,"EcoSmart Vortech");
  ReefAngel.LCD.Clear(255, 1, 19, 128, 29);
  if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,21,"Constant");
  else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,21,"Lagoon");
  else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,21,"Reef Crest");
  else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,21,"Short Pulse");
  else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,21,"Long Pulse");
  else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,21,"Nutrient Trnsp.");
  else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,21,"Tidal Swell");
  else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,21,"Night");
  ReefAngel.LCD.DrawText(0,255,10,30,"Temp");
  ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 40, text, Num8x8);
  ReefAngel.LCD.DrawLargeText(COLOR_PLUM, 255, 85, 40, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,43,48,"Salinity");
  ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 49, 58, text, Num8x8);
        ReefAngel.LCD.DrawOutletBox( 12, 77, TempRelay );
// water level
    ReefAngel.LCD.DrawText(0,255,8,68,"WL:");
    ReefAngel.LCD.DrawText( COLOR_CORNFLOWERBLUE,255, 40, 68, ReefAngel.WaterLevel.GetLevel() );
so far it's good.
had to use this code to get my RF working
    //#define Constant      0
    //#define Random1       1 // Lagoonal
    //#define Random2       2 // Reef Crest
    //#define ShortWave     3
    //#define LongWave      4
    //#define Smart_NTM     5 // Nutrient Transport Mode
    //#define Smart_TSM     6 // Tidal Swell Mode
    //#define Feeding_Start 7
    //#define Feeding_Stop  8
    //#define Night         9
    //#define Slave_Start   97
    //#define Slave_Stop    98
    //#define None          99
      ReefAngel.LCD.DrawText(0,255,20,50,"Assigning Slaves");
      ReefAngel.RF.SendData(Slave_Start,0,0);
      InternalMemory.RFMode_write(0);
      InternalMemory.RFSpeed_write(128);
      InternalMemory.RFDuration_write(10);
      ReefAngel.Refresh();
      if (ReefAngel.Joystick.IsButtonPressed())
        ReefAngel.RF.SendData(Slave_Stop,0,0);
        ReefAngel.LCD.DrawText(0,255,50,60,"Done");
PostPosted: Sat Apr 06, 2013 5:14 am
so my vortechs are always stuck in night mode
    #define Heater      1
    #define Return      2
    #define Skimmer     3
    #define Vortech1    5
    #define Vortech2    6
    #define ATO         7
byte vtechmode;
        ReefAngel.Relay.On( Port5 );
        ReefAngel.WaterLevelATO( Port7,120,58,60 );
        ReefAngel.PWM.Channel1PWMSlope();
        ReefAngel.PWM.Channel2PWMSlope();
        ReefAngel.PWM.Channel3PWMSlope();
        if (hour() >=8 && hour() < 20)
             ReefAngel.RF.SetMode(Feeding_Stop,0,0); //Temp fix for coming out of Night mode
      char text[7];
// water level
what do I need to change?
PostPosted: Sat Apr 06, 2013 8:14 am
First off, it looks like your Night mode is set to go during the day. Can you check and see if during the night before 8am and after 8pm if you are still in Night mode.
This bit is what says what time... right now it says greater than 8am and before 8pm be in Night mode..
This bit says when not in night mode to use Memory. Can you confirm what values you have set in the portal for your Vortechs
As I said, it looks like your in Night mode during the day...
PostPosted: Sat Apr 06, 2013 9:03 am
lnevo wrote:First off, it looks like your Night mode is set to go during the day. Can you check and see if during the night before 8am and after 8pm if you are still in Night mode.
so this instead?
            if (hour() <=8 && hour() > 20)
portal is set to tidal swell. RA display shows "night" and RF is breathing white.
PostPosted: Sat Apr 06, 2013 9:20 am
Yep, you have the time right now. Give it a try.
PostPosted: Sat Apr 06, 2013 10:01 am
Actually that condition would never happen.
Try this:
    if (ReefAngel.RF.Mode==Night) ReefAngel.RF.SetMode(Feeding_Stop,0,0);
PostPosted: Sat Apr 06, 2013 10:07 am
Good catch. Can't believe I missed that... the other option is to just change the && to ||
PostPosted: Tue Apr 09, 2013 5:28 am
rimai wrote:Actually that condition would never happen.
Try this:
thank you very much!!
this did it!
Return to My PDE/INO file
Users browsing this forum: No registered users and 6 guests
