My code - now with RAnet
PostPosted: Wed May 01, 2013 5:02 pm
Thank you both. Will try it out.
PostPosted: Thu May 30, 2013 3:59 pm
I would like my mp10s to go into feeding mode when I choose feeding mode from the menu...how would I go about doing that?
PostPosted: Thu May 30, 2013 4:04 pm
it does it automatically.
PostPosted: Thu May 30, 2013 4:10 pm
rimai wrote:it does it automatically.
oh. cool. didn't know that. I'm on 1.03, haven't updated for awhile...it will still do that?
PostPosted: Fri May 31, 2013 6:59 am
yes it does, just tried it out. very cool!
PostPosted: Fri Jun 28, 2013 12:04 pm
ok, so feeding mode isn't strong enough flow. How do I tell it to go to short pulse 53% @ 25 duration when I go into feeding mode?
PostPosted: Fri Jun 28, 2013 12:48 pm
You can change the feeding mode speed on the Ecotech driver without having to do any code change. I believe it keeps the mode that you are in.
You can adjust the speed and duration for this mode using the EcoSmart Configuration mode. See Section 4.5: Configuration Mode for instructions on how to do this. The default speed is set to 50% slower than the lowest speed of the pump for a duration of 10 minutes.
PostPosted: Fri Jun 28, 2013 12:55 pm
Setting 1: Barely Spinning
Setting 2: 50% lower than lowest speed of pump
Setting 3: lowest speed of pump
Setting 4: 25% speed of pump
Setting 5: 50% speed of pump
PostPosted: Fri Jun 28, 2013 12:57 pm
The only reason I suggest this route is that I like to see my drivers blinking in feeding mode :) You could certainly set it in code, but then you lose the nice light show :D
PostPosted: Sat Jun 29, 2013 5:44 am
ok, I'll look into that possibility. thank you.
Return to My PDE/INO file
