My code - now with RAnet
PostPosted: Wed Jan 07, 2015 3:00 pm
so after adding the RAnet into my code the "clear ATO" from the menu no longer functions and just stays stuck on the click to continue screen (after clicking clear ato)
    #include <SoftwareSerial.h>
    #define Heater      1
    #define Return      2
    #define HeaterTk2   3
    #define Skimmer     4
    #define Vortech1    5
    #define Vortech2    6
    #define ATO         7
    #define Sump Light  8
byte vtechmode, vtSpeed, vtDuration;
        ReefAngel.FeedingModePorts = Port2Bit;
        // ReefAngel.FeedingModePortsE[0] = 0;
        // ReefAngel.WaterChangePorts = Port7Bit | Port4Bit | Port5Bit | Port6Bit;
        // ReefAngel.WaterChangePortsE[0] = 0;
        // ReefAngel.LightsOnPorts = 0;
        // ReefAngel.LightsOnPortsE[0] = 0;
        // ReefAngel.OverheatShutoffPortsE[0] = 0;
        ReefAngel.AddRANet();
        ReefAngel.Relay.On( Port2 );
        ReefAngel.Relay.On( Port3 );
        ReefAngel.Relay.On( Port4 );
        ReefAngel.Relay.On( Port5 );
        // Hardcode calibrations
        ReefAngel.PHMin=576; // PH7.0
        ReefAngel.PHMax=842; // PH10.0
        ReefAngel.SalMax=3300; // 35ppt
    vtechmode=InternalMemory.RFMode_read();
    vtSpeed=InternalMemory.RFSpeed_read();
    vtDuration=InternalMemory.RFDuration_read();
    static unsigned long feeding;
    ReefAngel.StandardHeater( Port1,778,782 );
        ReefAngel.WaterLevelATO( Port7,180,71,74 );
        ReefAngel.StandardLights( Port8,15,0,2,0 );
        ReefAngel.PWM.SetChannel( 0,PWMSlope(19,00,21,00,15,51,20,0) );  //MOON
        ReefAngel.PWM.SetChannel( 1,PWMSlope(12,30,20,00,15,50,30,0) );  //RB
        ReefAngel.PWM.SetChannel( 2,PWMSlope(12,20,20,00,15,95,30,0) ); //WHITE
        ReefAngel.PWM.SetChannel( 3,PWMSlope(12,15,20,00,15,70,30,0) );  //BLUE&CYAN
        ReefAngel.PWM.SetChannel( 4,PWMSlope(12,00,20,30,15,70,30,0) ); //UV
        if ( ReefAngel.HighATO.IsActive())
          ReefAngel.Relay.On(Port2);
          ReefAngel.Relay.Off(Port2);
if (hour() >=13 && hour() < 20)
        // if (ReefAngel.RF.Mode==Night) ReefAngel.RF.SetMode(Feeding_Stop,0,0);
        ReefAngel.RF.UseMemory=true;
        // ReefAngel.RF.SetMode(ReefCrest,60,20);
             feeding=now();
             if (now()-feeding<5400) {
            // if (now()-feeding > 1 && now()-feeding < 5400) { // 1 second after feeding mode until 60 minutes after feeding mode.
  ReefAngel.RF.UseMemory=false;
    ReefAngel.RF.SetMode(Smart_NTM,75,10);
        ReefAngel.RF.SetMode(Constant,10,0);
         if (vtechmode!=InternalMemory.RFMode_read())
          InternalMemory.RFMode_write(vtechmode);
         if (vtSpeed!=InternalMemory.RFSpeed_read())
          InternalMemory.RFSpeed_write(vtSpeed);
         if (vtDuration!=InternalMemory.RFDuration_read())
          InternalMemory.RFDuration_write(vtDuration);
        ReefAngel.Portal( "bencollinz" );
      char text[7];
        ReefAngel.LCD.DrawDate( 6, 2 );
    ReefAngel.LCD.DrawText(0,255,18,12,"EcoSmart Vortech");
  ReefAngel.LCD.Clear(255, 1, 19, 128, 29);
  if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,21,"Constant");
  else if (vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,21,"Lagoon");
  else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,21,"Reef Crest");
  else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,21,"Short Pulse");
  else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,21,"Long Pulse");
  else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,21,"Nutrient Trnsp.");
  else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,21,"Tidal Swell");
  else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,21,"Night");
  ReefAngel.LCD.DrawText(0,255,4,30,"RF Speed:");
  ReefAngel.LCD.Clear(255,59,29,128,39);
  ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,71,31,vtSpeed);
  ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,90,31,"/");
  ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,100,31,vtDuration);
  ReefAngel.LCD.DrawText(0,255,10,40,"Salt");
  ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 50, text, Num8x8);
 /* ReefAngel.LCD.DrawText(0,255,50,40,"Fresh");
  ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 50, 50, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,100,40,"pH");
  ReefAngel.LCD.DrawLargeText(COLOR_PLUM, 255, 85, 50, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,13,58,"Salinity");
  ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 13, 68, text, Num8x8);
  // water level
    ReefAngel.LCD.DrawText(0,255,68,58,"WL");
    ReefAngel.LCD.DrawText( COLOR_CORNFLOWERBLUE,255, 68, 68, ReefAngel.WaterLevel.GetLevel() );
        ReefAngel.LCD.DrawOutletBox( 12, 108, TempRelay );
         // Relay Expansion
       ReefAngel.LCD.DrawOutletBox( 12, 120, TempRelay );
    /* void Heater2(byte HeaterRelay, int LowTemp, int HighTemp)
    if (ReefAngel.Params.Temp[T2_PROBE] == 0) return; // Don't turn the heater on if the temp is reading 0
    if (ReefAngel.Params.Temp[T2_PROBE] <= LowTemp && ReefAngel.Params.Temp[T2_PROBE] > 0) ReefAngel.Relay.On(HeaterRelay); // If sensor 2 temperature <= LowTemp - turn on heater
    if (ReefAngel.Params.Temp[T2_PROBE] >= HighTemp) ReefAngel.Relay.Off(HeaterRelay); // If sensor 2 temperature >= HighTemp - turn off heater
    void Heater1(byte HeaterRelay, int LowTemp, int HighTemp)
    if (ReefAngel.Params.Temp[T1_PROBE] == 0) return; // Don't turn the heater on if the temp is reading 0
    if (ReefAngel.Params.Temp[T1_PROBE] <= LowTemp && ReefAngel.Params.Temp[T1_PROBE] > 0) ReefAngel.Relay.On(HeaterRelay); // If sensor 2 temperature <= LowTemp - turn on heater
    if (ReefAngel.Params.Temp[T1_PROBE] >= HighTemp) ReefAngel.Relay.Off(HeaterRelay); // If sensor 2 temperature >= HighTemp - turn off heater
any advice?
clear ato works fine from the android app though
PostPosted: Thu Jan 08, 2015 9:51 am
I was able to replicate the issue.
It's related to the RANet code indeed.
This will be fixed in the next update.
https://github.com/reefangel/Libraries/issues/202
PostPosted: Thu Jan 08, 2015 5:45 pm
rimai wrote:I was able to replicate the issue.
there's also a bug when it exits feeding mode it changes the vortechs to 100% constant.
well, in my code after it exists the smart_ntm part of it after 5400 seconds it then changes the vortechs to 100% constant. and again, i need to reboot to fix it.
PostPosted: Fri Jan 09, 2015 4:24 pm
I confirmed this again after tonight's feeding.
PostPosted: Fri Jan 09, 2015 4:46 pm
I think that's your code doing that. Can you comment out your feeding routine section in full and verify that it exists as a bug.
PostPosted: Sat Jan 10, 2015 11:31 am
lnevo wrote:I think that's your code doing that. Can you comment out your feeding routine section in full and verify that it exists as a bug.
I commented this out
             feeding=now();
and it did reoccur.
PostPosted: Sat Jan 10, 2015 12:12 pm
There was more that needed commenting. It would make no sense for your ra to put it into any particular mode after the 5400 seconds. Can you post the full code and I'll revert with the correct change.
PostPosted: Sat Jan 10, 2015 12:34 pm
lnevo wrote:There was more that needed commenting. It would make no sense for your ra to put it into any particular mode after the 5400 seconds. Can you post the full code and I'll revert with the correct change.
    #define Heater      1
    #define Return      2
    #define             3
    #define Skimmer     4
    #define Vortech1    5
    #define Vortech2    6
    #define ATO         7
       // ReefAngel.PHMin=576; // PH7.0
       // ReefAngel.PHMax=842; // PH10.0
      //  ReefAngel.SalMax=3300; // 35ppt
       /*     if (ReefAngel.DisplayedMenu==FEEDING_MODE)
             feeding=now();
            // if (now()-feeding > 1 && now()-feeding < 5400) { // 1 second after feeding mode until 90 minutes after feeding mode.
      char text[7];
  // water level
         // Relay Expansion
As well as, you can no longer calibrate pH from the menu on the controller. You click OK for 7 and it skips the 10 really quickly. I tried it 6 times. As well as from the app. No go.
PostPosted: Sat Jan 10, 2015 4:04 pm
The calibration is related to the same issue.
The joystick button was not being debounced and was capturing two presses instead of one.
With the addition of the RANet, I had to disable the joystick button interrupt and make it software capture.
The new dev branch has this issue of the joystick button fixed.
If you download the latest dev branch, the joystick should work as intended.
PostPosted: Fri Jan 23, 2015 8:16 am
Sorry for the late reply. Please try this code.
    #define Heater      1
    #define Return      2
    #define             3
    #define Skimmer     4
    #define Vortech1    5
    #define Vortech2    6
    #define ATO         7
             feeding=now();
      char text[7];
  // water level
         // Relay Expansion
Return to My PDE/INO file
