My code - now with RAnet
bencollinz
Re: My code - now with RAnet
Post by bencollinz »
lnevo wrote:Sorry for the late reply. Please try this code.
    #include <SoftwareSerial.h>
    #define Heater      1
    #define Return      2
    #define             3
    #define Skimmer     4
    #define Vortech1    5
    #define Vortech2    6
    #define ATO         7
    #define Sump Light  8
byte vtechmode, vtSpeed, vtDuration;
        ReefAngel.FeedingModePorts = Port2Bit;
        // ReefAngel.FeedingModePortsE[0] = 0;
        // ReefAngel.WaterChangePorts = Port7Bit | Port4Bit | Port5Bit | Port6Bit;
        // ReefAngel.WaterChangePortsE[0] = 0;
        // ReefAngel.LightsOnPorts = 0;
        // ReefAngel.LightsOnPortsE[0] = 0;
        // ReefAngel.OverheatShutoffPortsE[0] = 0;
        ReefAngel.AddRANet();
        ReefAngel.Relay.On( Port2 );
        ReefAngel.Relay.On( Port3 );
        ReefAngel.Relay.On( Port4 );
        ReefAngel.Relay.On( Port5 );
        // Hardcode calibrations
       // ReefAngel.PHMin=576; // PH7.0
       // ReefAngel.PHMax=842; // PH10.0
      //  ReefAngel.SalMax=3300; // 35ppt
    vtechmode=InternalMemory.RFMode_read();
    vtSpeed=InternalMemory.RFSpeed_read();
    vtDuration=InternalMemory.RFDuration_read();
    static unsigned long feeding;
    ReefAngel.StandardHeater( Port1,778,782 );
        ReefAngel.WaterLevelATO( Port7,180,71,74 );
        ReefAngel.StandardLights( Port8,15,0,2,0 );
        ReefAngel.PWM.SetChannel( 0,PWMSlope(19,00,21,00,15,51,20,0) );  //MOON
        ReefAngel.PWM.SetChannel( 1,PWMSlope(12,30,20,00,15,50,30,0) );  //RB
        ReefAngel.PWM.SetChannel( 2,PWMSlope(12,20,20,00,15,95,30,0) ); //WHITE
        ReefAngel.PWM.SetChannel( 3,PWMSlope(12,15,20,00,15,70,30,0) );  //BLUE&CYAN
        ReefAngel.PWM.SetChannel( 4,PWMSlope(12,00,20,30,15,70,30,0) ); //UV
        if ( ReefAngel.HighATO.IsActive())
          ReefAngel.Relay.On(Port2);
          ReefAngel.Relay.Off(Port2);
ReefAngel.RF.UseMemory=true;
if (hour() >=13 && hour() < 20)
        // if (ReefAngel.RF.Mode==Night) ReefAngel.RF.SetMode(Feeding_Stop,0,0);
        // ReefAngel.RF.SetMode(ReefCrest,60,20);
             feeding=now();
             if (now()-feeding<5400) {
            // if (now()-feeding > 1 && now()-feeding < 5400) { // 1 second after feeding mode until 90 minutes after feeding mode.
  ReefAngel.RF.UseMemory=false;
    ReefAngel.RF.SetMode(Smart_NTM,75,10);
        ReefAngel.RF.SetMode(Constant,10,0);
         if (vtechmode!=InternalMemory.RFMode_read())
          InternalMemory.RFMode_write(vtechmode);
         if (vtSpeed!=InternalMemory.RFSpeed_read())
          InternalMemory.RFSpeed_write(vtSpeed);
         if (vtDuration!=InternalMemory.RFDuration_read())
          InternalMemory.RFDuration_write(vtDuration);
        ReefAngel.Portal( "bencollinz" );
      char text[7];
        ReefAngel.LCD.DrawDate( 6, 2 );
    ReefAngel.LCD.DrawText(0,255,18,12,"EcoSmart Vortech");
  ReefAngel.LCD.Clear(255, 1, 19, 128, 29);
  if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,21,"Constant");
  else if (vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,21,"Lagoon");
  else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,21,"Reef Crest");
  else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,21,"Short Pulse");
  else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,21,"Long Pulse");
  else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,21,"Nutrient Trnsp.");
  else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,21,"Tidal Swell");
  else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,21,"Night");
  ReefAngel.LCD.DrawText(0,255,4,30,"RF Speed:");
  ReefAngel.LCD.Clear(255,59,29,128,39);
  ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,71,31,vtSpeed);
  ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,90,31,"/");
  ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,100,31,vtDuration);
  ReefAngel.LCD.DrawText(0,255,10,40,"Salt");
  ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 50, text, Num8x8);
 /* ReefAngel.LCD.DrawText(0,255,50,40,"Fresh");
  ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 50, 50, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,100,40,"pH");
  ReefAngel.LCD.DrawLargeText(COLOR_PLUM, 255, 85, 50, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,13,58,"Salinity");
  ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 13, 68, text, Num8x8);
  // water level
    ReefAngel.LCD.DrawText(0,255,68,58,"WL");
    ReefAngel.LCD.DrawText( COLOR_CORNFLOWERBLUE,255, 68, 68, ReefAngel.WaterLevel.GetLevel() );
        ReefAngel.LCD.DrawOutletBox( 12, 108, TempRelay );
         // Relay Expansion
       ReefAngel.LCD.DrawOutletBox( 12, 120, TempRelay );
    /* void Heater2(byte HeaterRelay, int LowTemp, int HighTemp)
    if (ReefAngel.Params.Temp[T2_PROBE] == 0) return; // Don't turn the heater on if the temp is reading 0
    if (ReefAngel.Params.Temp[T2_PROBE] <= LowTemp && ReefAngel.Params.Temp[T2_PROBE] > 0) ReefAngel.Relay.On(HeaterRelay); // If sensor 2 temperature <= LowTemp - turn on heater
    if (ReefAngel.Params.Temp[T2_PROBE] >= HighTemp) ReefAngel.Relay.Off(HeaterRelay); // If sensor 2 temperature >= HighTemp - turn off heater
    void Heater1(byte HeaterRelay, int LowTemp, int HighTemp)
    if (ReefAngel.Params.Temp[T1_PROBE] == 0) return; // Don't turn the heater on if the temp is reading 0
    if (ReefAngel.Params.Temp[T1_PROBE] <= LowTemp && ReefAngel.Params.Temp[T1_PROBE] > 0) ReefAngel.Relay.On(HeaterRelay); // If sensor 2 temperature <= LowTemp - turn on heater
    if (ReefAngel.Params.Temp[T1_PROBE] >= HighTemp) ReefAngel.Relay.Off(HeaterRelay); // If sensor 2 temperature >= HighTemp - turn off heater
Made the change, no difference.
stays at 100% until feeding mode exits
bencollinz
and I can't even remove the RAnet code without getting this error
"C:\Users\user\Documents\Arduino\libraries\Globals/Globals.h:348: error: 'SoftwareSerial' does not name a type"
Maybe need to reinstall the libraries fresh, something doesnt seem right
If you remove RANet, you must also remove the include on top "#include <SoftwareSerial.h>"
bencollinz
rimai wrote:If you remove RANet, you must also remove the include on top "#include <SoftwareSerial.h>"
How do I use
but Box1_Port1? The same way?
bencollinz
How do I use
figured it out. yes, the same way.
