updated my libraries, now having problems
Posted: Mon Apr 29, 2013 7:10 pm
Hello,
I updated my libraries today and now my tunze functions wont upload. any ideas? Below is the error message
Simple Menu
Globals\Globals.cpp.o: In function `LongPulseMode(unsigned char, unsigned char, int, unsigned char)':
C:\Users\Nick\Documents\Arduino\libraries\Globals/Globals.cpp:265: multiple definition of `LongPulseMode(unsigned char, unsigned char, int, unsigned char)'
_4_12_13_working_code.cpp.o:C:\Users\Nick\AppData\Local\Temp\build2656171354780407722.tmp/_4_12_13_working_code.cpp:133: first defined here
Globals\Globals.cpp.o: In function `SineMode(unsigned char, unsigned char, int, unsigned char)':
C:\Users\Nick\Documents\Arduino\libraries\Globals/Globals.cpp:278: multiple definition of `SineMode(unsigned char, unsigned char, int, unsigned char)'
_4_12_13_working_code.cpp.o:C:\Users\Nick\AppData\Local\Temp\build2656171354780407722.tmp/_4_12_13_working_code.cpp:144: first defined here
Globals\Globals.cpp.o: In function `TidalSwellMode(unsigned char, unsigned char)':
C:\Users\Nick\Documents\Arduino\libraries\Globals/Globals.cpp:405: multiple definition of `TidalSwellMode(unsigned char, unsigned char)'
_4_12_13_working_code.cpp.o:C:\Users\Nick\AppData\Local\Temp\build2656171354780407722.tmp/_4_12_13_working_code.cpp:262: first defined here
Globals\Globals.cpp.o: In function `NutrientTransportMode(unsigned char, unsigned char, int, unsigned char)':
C:\Users\Nick\Documents\Arduino\libraries\Globals/Globals.cpp:322: multiple definition of `NutrientTransportMode(unsigned char, unsigned char, int, unsigned char)'
_4_12_13_working_code.cpp.o:C:\Users\Nick\AppData\Local\Temp\build2656171354780407722.tmp/_4_12_13_working_code.cpp:181: first defined here
Globals\Globals.cpp.o: In function `ShortPulseMode(unsigned char, unsigned char, int, unsigned char)':
C:\Users\Nick\Documents\Arduino\libraries\Globals/Globals.cpp:252: multiple definition of `ShortPulseMode(unsigned char, unsigned char, int, unsigned char)'
_4_12_13_working_code.cpp.o:C:\Users\Nick\AppData\Local\Temp\build2656171354780407722.tmp/_4_12_13_working_code.cpp:122: first defined here
Globals\Globals.cpp.o: In function `ReefCrestMode(unsigned char, unsigned char, unsigned char)':
C:\Users\Nick\Documents\Arduino\libraries\Globals/Globals.cpp:304: multiple definition of `ReefCrestMode(unsigned char, unsigned char, unsigned char)'
_4_12_13_working_code.cpp.o:C:\Users\Nick\AppData\Local\Temp\build2656171354780407722.tmp/_4_12_13_working_code.cpp:165: first defined here
Globals\Globals.cpp.o: In function `TideMode(unsigned char, unsigned char, unsigned char)':
C:\Users\Nick\Documents\Arduino\libraries\Globals/Globals.cpp:530: multiple definition of `TideMode(unsigned char, unsigned char, unsigned char)'
_4_12_13_working_code.cpp.o:C:\Users\Nick\AppData\Local\Temp\build2656171354780407722.tmp/_4_12_13_working_code.cpp:385: first defined here
Simple Menu
