Smotz Code
PostPosted: Wed May 29, 2013 11:40 am
To save it somewhere else ... :D
////  Port 1         Heater
////  Port 2         ATO pump
////  Port 3         Reactor Pump
////  Port 4         Protien Skimmer
////  Port 5         Return Pump
////  Port 6         Wavemaker
////  Port 7                    UV Sterilizer
////  Port 8                    Fuge Light
////  Always on - Lights & Salinity Module
#define Heater Port1
#define Topoff Port2
#define Reactor Port3
#define Skimmer Port4
#define Return Port5
#define Wave Port6
#define UVlight Port7
#define Fugelight Port8
#define FugelightBit   1<<7
#define UVlightBit   1<<6
#define WaveBit   1<<5
#define ReturnBit   1<<4
#define SkimmerBit   1<<3
#define ReactorBit   1<<2
#define TopoffBit   1<<1
#define HeaterBit   1<<0
static byte wpMode;
static byte wpWavStr;
static byte wpWavOff;
  ReefAngel.FeedingModePorts = TopoffBit | ReactorBit | SkimmerBit | ReturnBit | UVlightBit;
  ReefAngel.WaterChangePorts = HeaterBit | TopoffBit | ReactorBit | SkimmerBit | ReturnBit | WaveBit | UVlightBit;
  ReefAngel.LightsOnPorts = FugelightBit;
  ReefAngel.OverheatShutoffPorts = HeaterBit | TopoffBit | ReactorBit | SkimmerBit | ReturnBit | WaveBit | UVlightBit;
  // Use T1 (SUMP) probe as temperature and overheat functions
  ReefAngel.Relay.On( Return );
  ReefAngel.Relay.On( Reactor );
  ReefAngel.Relay.On( Wave );
  ReefAngel.StandardHeater( Heater );
  ReefAngel.StandardATO( Topoff );
  ReefAngel.MoonLights( Fugelight );
  ReefAngel.LCD.DrawText(0,255,20,80,"Joe's Reef Tank");
  ReefAngel.Relay.DelayedOn(Skimmer,2);
  ReefAngel.Relay.DelayedOn(UVlight,1);
  ReefAngel.PWM.SetActinic(100);
  //Feeding Mode set the Waves to 30%
  if (ReefAngel.DisplayedMenu==FEEDING_MODE) {
    ReefAngel.PWM.SetDaylight(30);
    ReefAngel.PWM.SetActinic(30);
  // IF not in feeding mode
  else {
    wpWavOff=12;      //Set the Wave OffSet
    // Set Wave Str
    if (wpMode=1) wpWavStr=45;
    if (wpMode=2) wpWavStr=50;
    if (wpMode=3) wpWavStr=55;
    ReefAngel.PWM.SetDaylight( ReefCrestMode(wpWavStr,wpWavOff,false) );
    if ( (hour() >= 5) && (hour() < 8) ) wpMode=1;       // from 5a - 8a
    if ( (hour() >= 8) && (hour() < 11) ) wpMode=2;      // from 8a - 11a
    if ( (hour() >= 11) && (hour() < 14) ) wpMode=3;     // from 11a - 2pm
    if ( (hour() >= 14) && (hour() < 17) ) wpMode=2;      // from 2pm - 5pm
    if ( (hour() >= 17) && (hour() < 20) ) wpMode=1;     // from 5pm - 8pm
    if ( (hour() >= 20) && (hour() < 23) ) wpMode=2;     // from 8pm - 11p
    if ( (hour() >= 23) && (hour() < 2) ) wpMode=3;      // from 11pm - 2am
    if ( (hour() >= 2) && (hour() < 5) ) wpMode=2;       // from 2am - 5am
  //  Only turn on UV Sterilizer between 11pm and 5am
  if ( (hour() >= 5) && (hour() < 23) )  // from 5a - 11p
    ReefAngel.Relay.Off(UVlight);
  else {
    ReefAngel.Relay.On(UVlight);
  ReefAngel.Portal( "Smotz" );
  int x,y;
  char buf[16];
  sprintf(buf,"RC %d% +/-%d%",wpWavStr,wpWavOff);
  // WP40 Mode
  x = 15;
  y = 52;
  ReefAngel.LCD.DrawText(0,255,x,y,"RF:");
  ReefAngel.LCD.Clear(DefaultBGColor,x,y,128-x,y+8);
  if (wpMode == 0) ReefAngel.LCD.DrawText(COLOR_GREEN,255,x,y,"Feeding");
  else ReefAngel.LCD.DrawText(0,255,x,y,buf);
  // Parameters
  // Salinity
  ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,66, "SAL:" );
  ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,66, ReefAngel.Params.Salinity );
  // Main Relay Box
  // Date and Time
Return to My PDE/INO file
