need custom PDE help
Re: need custom PDE help
also for future issues i see everyone posting there codes in the little scroll down windows with the select code option up top. how do you do that?
going off of that link i plug the first part on the code in and run the verify and get this error
sketch_may29a.cpp: In function 'void DrawCustomMain()':
sketch_may29a:105: error: redefinition of 'void DrawCustomMain()'
sketch_may29a:30: error: 'void DrawCustomMain()' previously defined here
sketch_may29a.cpp: In function 'void DrawCustomGraph()':
sketch_may29a:144: error: redefinition of 'void DrawCustomGraph()'
sketch_may29a:48: error: 'void DrawCustomGraph()' previously defined here
When you use the editor you can highlight the text you want as code and click the Code button...jjdezek wrote:also for future issues i see everyone posting there codes in the little scroll down windows with the select code option up top. how do you do that?
otherwise you can use the BBCode tags like this:
[code]
Looks like you have two functions with the same name. DrawCustomMain and DrawCustomGraph... You can only have one function with that name...jjdezek wrote:going off of that link i plug the first part on the code in and run the verify and get this error
I noticed the code i copied and pasted from the link was both the custommain and customgraph. So i copied just the custommain and ran the verify and gave me another error and jumped to the custommain at the end of my coding. the link doesnt say anything about what to do with that part of the code.
ReefAngel.WaterChangePorts = Port1Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardATO( Port1,60 );
ReefAngel.StandardLights( Port3,18,0,10,0 );
ReefAngel.WavemakerRandom( Port5,30,100 );
ReefAngel.WavemakerRandom( Port6,30,100 );
ReefAngel.StandardHeater( Port7,752,755 );
ReefAngel.PWM.SetChannel( 0, PWMSlope(7,0,22,0,0,40,180,0) );
ReefAngel.PWM.SetChannel( 1, PWMSlope(7,30,21,30,0,35,180,0) );
ReefAngel.PWM.SetChannel( 2, PWMSlope(7,0,22,0,0,40,180,0) );
ReefAngel.PWM.SetChannel( 3, PWMSlope(7,30,21,30,0,35,180,0) );
ReefAngel.PWM.SetChannel( 4, PWMSlope(7,0,22,0,0,40,180,0) );
ReefAngel.PWM.SetChannel( 5, PWMSlope(7,30,21,30,0,35,180,0) );
if (hour()>=8 && hour()<12)
ReefAngel.PWM.SetDaylight( ReefCrestMode(100,20,true) ); // ReefCrest at 100% +/- 20% on sync mode
ReefAngel.PWM.SetActinic( ReefCrestMode(100,20,false) ); // ReefCrest at 100% +/- 20% on anti-sync mode
else if (hour()>=12 && hour()<18)
ReefAngel.PWM.SetDaylight( ShortPulseMode(0,100,200,true) ); // Short pulse at 100% with 200ms pulse on sync mode
ReefAngel.PWM.SetActinic( ShortPulseMode(0,100,200,false) ); // Short pulse at 100% with 200ms pulse on anti-sync mode
ReefAngel.PWM.SetDaylight( LongPulseMode(0,100,10,true) ); // Long pulse at 100% with 10s pulse on sync mode
ReefAngel.PWM.SetActinic( LongPulseMode(0,100,10,false) ); // Long pulse at 6100% with 10s pulse on anti-sync mode
if( ReefAngel.DisplayedMenu==FEEDING_MODE )
ReefAngel.PWM.SetActinic(0);
ReefAngel.PWM.SetDaylight(0);
ReefAngel.Portal( "jjdezek" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
Where you pasted the DrawCustomMain() is wrong... it should be at the end of your INO file... but guess what? It's already there! You already have that function defined....
You can only define it once. You can't have two DrawCustomMain() functions... same for any function and DrawCustomGraph().
Does this come already set up on the new units or something cause I never put it there? So now all I have to do is modify it the way I want it?
No. It looks like you added it as part of the dimming weather package the way its setup. So yes, you just need to start tweaking it.
ok well i removed the previous custom portion from my code and placed the one you gave me in there and it loaded with a graph on my screen.
here is how i did the code pic of screen to follow
ReefAngel.Relay.On( Port2 );
char buf[16];
// Temp and PH
y+=2;
y+=5;
int t=x;
On so right now you took both DrawCustomMain() functions out and you are getting the stock screen...
You can now follow the tutorial and add that function in...when you do that you can use my functions that you also added correctly.
The syntax would be DrawStatus(x,y);
where x and y are the coordinates you want the ato circles and DrawParams(x,y);
You will use these inside the DrawCustomMain() function.
You do already have the DrawCustomGraph() function so make sure you dont add that one again when you follow the tutorial.
ok you just confused me again. so do i put the custommenu code in the
wont that throw another error? Im trying to get a grasp on this coding stuff but everytime i think im getting the hang of it i find something that looses me.
It goes at the bottom...it's a new function...look how DrawCustomGraph() is in your code...it I'll be just like that except with code in it...
It could be where you put it last time, but that space is usually for variables...it doesn't really matter,..last time you had it in there twice ( at top and at bottom )...that was why you had an error
Don't worry...we'll get you there...it's like learning a new language...actually it is learning a new language...jjdezek wrote: Im trying to get a grasp on this coding stuff but everytime i think im getting the hang of it i find something that looses me.
Check this tutorial it will help you understand a lot more. It really should be added as a MUST-READ!
http://forum.reefangel.com/viewtopic.php?p=27161#p27161
yeah i copied the custommenu code from the tutorial and put it in there and ran the varify and it didnt give any errors. im still not sure what to do next. I try reading the tutorial but it just makes me more cunfused. im more of a hands on learning. i can read all day and walk away not knowing what i read, not sure if it would be classified as A.D.D. it would really be helpful to see a partion of code typed out then see what that does on the screen. thanks for all the help with this.
Look at the last tutorial I posted...it's pretty much a line by line explanation of the code...
As far as the draw custom main tutorial...you had the right one that was posted earlier...
Here is an example from page 4 of the PDF from curt.
I see now why you posted it above
Let's look at a few lines...
What do you think that does? It draws the date at coordinates 6,112..
The pingSerial() commands are no longer needed in this function...you can ignore them...but what they used to do is manage the wifi while we were busy drawing new screens...
Ignore all the #ifdef lines for now...they are basically a way to make the screen generic for people that want to use sections of code to minimize the memory footprint...advanced topic for you...but look at this last line that I posted above...
it uses the DrawMonitor() function to print the daylight and actinic values on the screen starting at coordinates 15,60.
So to use the functions I gave you, you would just "call" one of mine inside the DrawCustomMain() with something like this.
I recommend starting by just changing around the x and y locations in the default example so you can get that hands-on feeling and make room for what you want to add. Once you start getting a feel it will become easier.
I noodled that because I didn't want you to miss the recommendation through all the code explanation.
ReefAngel.LCD.DrawGraph(5,5);
DrawStatus(15,80);
i changed these numbers and it moved the codes up to the top. what im not understanding is how do i get the ATO to display on the screen?
ReefAngel.LCD.DrawMonitor(15, 10, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor(15, 10, ReefAngel.Params.);
You need to add DrawStatus(x,y); inside the DrawCustomMain function. with x and y being the coordinates where you want it.
so i would put something like
DrawStatus(15,50)
and just plug it in anywhere in the drawcustommain?
DrawStatus(15,50)
Don't forget the semicolon after the last parenthesis.
haha awesome got it. ok next step. how do you make the temp 1 text larger? along with ph?
You'll need to replace the current drawing of those parameters with the other function I gave you.
DrawParams(x,y);
DrawParams(x,y);
so i replace this
with this
y+=5;
or just plug in the DrawParams (15,10);
