need custom PDE help
jjdezek
Re: need custom PDE help
Post by jjdezek »
here is how i did the code pic of screen to follow
    ReefAngel.WaterChangePorts = Port1Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit;
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.StandardATO( Port1,60 );
    ReefAngel.StandardLights( Port3,18,0,10,0 );
    ReefAngel.WavemakerRandom( Port5,30,100 );
    ReefAngel.WavemakerRandom( Port6,30,100 );
    ReefAngel.StandardHeater( Port7,752,755 );
    ReefAngel.PWM.SetChannel( 0, PWMSlope(7,0,22,0,0,40,180,0) );
    ReefAngel.PWM.SetChannel( 1, PWMSlope(7,30,21,30,0,35,180,0) );
    ReefAngel.PWM.SetChannel( 2, PWMSlope(7,0,22,0,0,40,180,0) );
    ReefAngel.PWM.SetChannel( 3, PWMSlope(7,30,21,30,0,35,180,0) );
    ReefAngel.PWM.SetChannel( 4, PWMSlope(7,0,22,0,0,40,180,0) );
    ReefAngel.PWM.SetChannel( 5, PWMSlope(7,30,21,30,0,35,180,0) );
    if (hour()>=8 && hour()<12)
  ReefAngel.PWM.SetDaylight( ReefCrestMode(100,20,true) ); // ReefCrest at 100% +/- 20% on sync mode
  ReefAngel.PWM.SetActinic( ReefCrestMode(100,20,false) ); // ReefCrest at 100% +/- 20% on anti-sync mode
else if (hour()>=12 && hour()<18)
  ReefAngel.PWM.SetDaylight( ShortPulseMode(0,100,200,true) ); // Short pulse at 100% with 200ms pulse on sync mode
  ReefAngel.PWM.SetActinic( ShortPulseMode(0,100,200,false) ); // Short pulse at 100% with 200ms pulse on anti-sync mode
  ReefAngel.PWM.SetDaylight( LongPulseMode(0,100,10,true) ); // Long pulse at 100% with 10s pulse on sync mode
  ReefAngel.PWM.SetActinic( LongPulseMode(0,100,10,false) ); // Long pulse at 6100% with 10s pulse on anti-sync mode
if( ReefAngel.DisplayedMenu==FEEDING_MODE )
   ReefAngel.PWM.SetActinic(0);
   ReefAngel.PWM.SetDaylight(0);
    ReefAngel.Portal( "jjdezek" );
  char buf[16];
  // Temp and PH
  y+=2;
  y+=5;
  int t=x;
jjdezek
Post by jjdezek »
On so right now you took both DrawCustomMain() functions out and you are getting the stock screen...
You can now follow the tutorial and add that function in...when you do that you can use my functions that you also added correctly.
The syntax would be DrawStatus(x,y);
where x and y are the coordinates you want the ato circles and DrawParams(x,y);
You will use these inside the DrawCustomMain() function.
You do already have the DrawCustomGraph() function so make sure you dont add that one again when you follow the tutorial.
jjdezek
Post by jjdezek »
ok you just confused me again. so do i put the custommenu code in the
wont that throw another error? Im trying to get a grasp on this coding stuff but everytime i think im getting the hang of it i find something that looses me.
It goes at the bottom...it's a new function...look how DrawCustomGraph() is in your code...it I'll be just like that except with code in it...
It could be where you put it last time, but that space is usually for variables...it doesn't really matter,..last time you had it in there twice ( at top and at bottom )...that was why you had an error
jjdezek wrote: Im trying to get a grasp on this coding stuff but everytime i think im getting the hang of it i find something that looses me.
Don't worry...we'll get you there...it's like learning a new language...actually it is learning a new language...
Check this tutorial it will help you understand a lot more. It really should be added as a MUST-READ!
http://forum.reefangel.com/viewtopic.php?p=27161#p27161
jjdezek
Post by jjdezek »
yeah i copied the custommenu code from the tutorial and put it in there and ran the varify and it didnt give any errors. im still not sure what to do next. I try reading the tutorial but it just makes me more cunfused. im more of a hands on learning. i can read all day and walk away not knowing what i read, not sure if it would be classified as A.D.D. it would really be helpful to see a partion of code typed out then see what that does on the screen. thanks for all the help with this.
Look at the last tutorial I posted...it's pretty much a line by line explanation of the code...
As far as the draw custom main tutorial...you had the right one that was posted earlier...
Here is an example from page 4 of the PDF from curt.
     ReefAngel.LCD.DrawGraph(5,5);
I see now why you posted it above :)
Let's look at a few lines...
What do you think that does? It draws the date at coordinates 6,112..
The pingSerial() commands are no longer needed in this function...you can ignore them...but what they used to do is manage the wifi while we were busy drawing new screens...
Ignore all the #ifdef lines for now...they are basically a way to make the screen generic for people that want to use sections of code to minimize the memory footprint...advanced topic for you...but look at this last line that I posted above...
it uses the DrawMonitor() function to print the daylight and actinic values on the screen starting at coordinates 15,60.
So to use the functions I gave you, you would just "call" one of mine inside the DrawCustomMain() with something like this.
DrawStatus(15,80);
I recommend starting by just changing around the x and y locations in the default example so you can get that hands-on feeling and make room for what you want to add. Once you start getting a feel it will become easier.
I noodled that because I didn't want you to miss the recommendation through all the code explanation.
jjdezek
Post by jjdezek »
i changed these numbers and it moved the codes up to the top. what im not understanding is how do i get the ATO to display on the screen?
ReefAngel.LCD.DrawMonitor(15, 10, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor(15, 10, ReefAngel.Params.);
You need to add DrawStatus(x,y); inside the DrawCustomMain function. with x and y being the coordinates where you want it.
jjdezek
Post by jjdezek »
so i would put something like
DrawStatus(15,50)
and just plug it in anywhere in the drawcustommain?
By Jove, I think he's got it!
Don't forget the semicolon after the last parenthesis.
jjdezek
Post by jjdezek »
haha awesome got it. ok next step. how do you make the temp 1 text larger? along with ph?
jjdezek
Post by jjdezek »
You'll need to replace the current drawing of those parameters with the other function I gave you.
DrawParams(x,y);
jjdezek
Post by jjdezek »
so i replace this
with this
  y+=5;
jjdezek
Post by jjdezek »
or just plug in the DrawParams (15,10);
I would do the second but either would work. The first one You would have a problem because x and y are not defined in the drawcustommain, so you'd have to edit that bit.
I think your starting to get the hang of it :)
jjdezek
Post by jjdezek »
with this it didnt turn out. pic to follow.
#endif // defined DisplayLEDPWM && ! defined RemoveAllLig
DrawStatus (20,80);
DrawParams (15,50);
jjdezek
Post by jjdezek »
jjdezek
Post by jjdezek »
with this code set up
DrawStatus (20,80);
DrawParams (15,50);
jjdezek
Post by jjdezek »
I get this
Sorry, you need to add this to get the large numbers. This goes right after the // Place global variable code below here. Not inside the functions.
#define NUMBERS_8x16
As far as the alignment if it doesn't get fixed after that, try changing the x to 5.
jjdezek
Post by jjdezek »
all that did was make the text bigger still have the smaller numbers overlapping and those numbers a glitching.
jjdezek
Post by jjdezek »
it looks like the word temp and ph are behind the numbers instead of above them. I also noticed that when i removed the old params codes i removed the pwm block. is there away i can keep the pwm on the screen and remove the old params?
Lets address the pwm values after. That will be easy. Can you post your current code and screenshot.
jjdezek
Post by jjdezek »
well while i was waiting for your response i did a little playing with the code. i got my name displayed across the top and put the params back in. so right now this is what i have.
ReefAngel.LCD.DrawText(COLOR_INDIGO, COLOR_WHITE,20,5, "Jeremy's Reef");
ReefAngel.LCD.DrawMonitor(15, 30, ReefAngel.Params,
DrawStatus (20,80);
DrawParams (5,60);
  char buf[16];
  // Temp and PH
  y+=2;
  y+=5;
  int t=x;
