need custom PDE help
PostPosted: Tue Jun 11, 2013 6:11 am
I would do the second but either would work. The first one You would have a problem because x and y are not defined in the drawcustommain, so you'd have to edit that bit.
I think your starting to get the hang of it :)
PostPosted: Tue Jun 11, 2013 6:19 am
with this it didnt turn out. pic to follow.
ReefAngel.LCD.DrawMonitor(15, 10, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor(15, 10, ReefAngel.Params.);
#endif // defined DisplayLEDPWM && ! defined RemoveAllLig
DrawStatus (20,80);
DrawParams (15,50);
PostPosted: Tue Jun 11, 2013 6:20 am
PostPosted: Tue Jun 11, 2013 6:28 am
with this code set up
DrawStatus (20,80);
DrawParams (15,50);
PostPosted: Tue Jun 11, 2013 6:29 am
I get this
PostPosted: Tue Jun 11, 2013 7:07 am
Sorry, you need to add this to get the large numbers. This goes right after the // Place global variable code below here. Not inside the functions.
#define NUMBERS_8x16
As far as the alignment if it doesn't get fixed after that, try changing the x to 5.
PostPosted: Tue Jun 11, 2013 7:21 am
all that did was make the text bigger still have the smaller numbers overlapping and those numbers a glitching.
PostPosted: Tue Jun 11, 2013 7:22 am
it looks like the word temp and ph are behind the numbers instead of above them. I also noticed that when i removed the old params codes i removed the pwm block. is there away i can keep the pwm on the screen and remove the old params?
PostPosted: Tue Jun 11, 2013 7:45 am
Lets address the pwm values after. That will be easy. Can you post your current code and screenshot.
PostPosted: Tue Jun 11, 2013 7:48 am
well while i was waiting for your response i did a little playing with the code. i got my name displayed across the top and put the params back in. so right now this is what i have.
ReefAngel.LCD.DrawText(COLOR_INDIGO, COLOR_WHITE,20,5, "Jeremy's Reef");
ReefAngel.LCD.DrawMonitor(15, 30, ReefAngel.Params,
DrawStatus (20,80);
DrawParams (5,60);
    ReefAngel.WaterChangePorts = Port1Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit;
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.StandardATO( Port1,60 );
    ReefAngel.StandardLights( Port3,18,0,10,0 );
    ReefAngel.WavemakerRandom( Port5,30,100 );
    ReefAngel.WavemakerRandom( Port6,30,100 );
    ReefAngel.StandardHeater( Port7,752,755 );
    ReefAngel.PWM.SetChannel( 0, PWMSlope(7,0,22,0,0,40,180,0) );
    ReefAngel.PWM.SetChannel( 1, PWMSlope(7,30,21,30,0,35,180,0) );
    ReefAngel.PWM.SetChannel( 2, PWMSlope(7,0,22,0,0,40,180,0) );
    ReefAngel.PWM.SetChannel( 3, PWMSlope(7,30,21,30,0,35,180,0) );
    ReefAngel.PWM.SetChannel( 4, PWMSlope(7,0,22,0,0,40,180,0) );
    ReefAngel.PWM.SetChannel( 5, PWMSlope(7,30,21,30,0,35,180,0) );
    if (hour()>=8 && hour()<12)
  ReefAngel.PWM.SetDaylight( ReefCrestMode(100,20,true) ); // ReefCrest at 100% +/- 20% on sync mode
  ReefAngel.PWM.SetActinic( ReefCrestMode(100,20,false) ); // ReefCrest at 100% +/- 20% on anti-sync mode
else if (hour()>=12 && hour()<18)
  ReefAngel.PWM.SetDaylight( ShortPulseMode(0,100,200,true) ); // Short pulse at 100% with 200ms pulse on sync mode
  ReefAngel.PWM.SetActinic( ShortPulseMode(0,100,200,false) ); // Short pulse at 100% with 200ms pulse on anti-sync mode
  ReefAngel.PWM.SetDaylight( LongPulseMode(0,100,10,true) ); // Long pulse at 100% with 10s pulse on sync mode
  ReefAngel.PWM.SetActinic( LongPulseMode(0,100,10,false) ); // Long pulse at 6100% with 10s pulse on anti-sync mode
if( ReefAngel.DisplayedMenu==FEEDING_MODE )
   ReefAngel.PWM.SetActinic(0);
   ReefAngel.PWM.SetDaylight(0);
    ReefAngel.Portal( "jjdezek" );
  char buf[16];
  // Temp and PH
  y+=2;
  y+=5;
  int t=x;
Return to My PDE/INO file
