need custom PDE help
PostPosted: Tue Jun 11, 2013 12:07 pm
You just gotta play with the x and y's now. You don't define x and y in your DrawCustomMain I believe so you shouldn't have them in your DrawText and stuff... for the 4 lines you added, just start changing the x and y values to what works...
Now it's just a matter of moving things aroudn where you want them.
PostPosted: Tue Jun 11, 2013 12:16 pm
ok still have a problem with the temp and ph showing up correctly. the big numbers overlap the words temp and ph. how do you offset the words from the numbers in each set of coding is that what the x+80,y+10 are for?
PostPosted: Tue Jun 11, 2013 12:18 pm
Yes, exactly. So just play around with it. You could always take out the x+ and y+ and just put hard coded numbers. It's odd that the temp and ph are offset though because the placement of the labels and variables should all be relative to each other, but not sure what's going on.
Either way you're on the right track.
PostPosted: Tue Jun 11, 2013 12:24 pm
heres my code
#define NUMBERS_8x16
ReefAngel.LCD.DrawText(COLOR_INDIGO, COLOR_WHITE,25,5, "Jeremy's Reef");
DrawStatus (20,80);
DrawParams (5,40);
DrawParamsa (0,10);
    ReefAngel.WaterChangePorts = Port1Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit;
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.StandardATO( Port1,60 );
    ReefAngel.StandardLights( Port3,18,0,10,0 );
    ReefAngel.WavemakerRandom( Port5,30,100 );
    ReefAngel.WavemakerRandom( Port6,30,100 );
    ReefAngel.StandardHeater( Port7,752,755 );
    ReefAngel.PWM.SetChannel( 0, PWMSlope(7,0,22,0,0,40,180,0) );
    ReefAngel.PWM.SetChannel( 1, PWMSlope(7,30,21,30,0,35,180,0) );
    ReefAngel.PWM.SetChannel( 2, PWMSlope(7,0,22,0,0,40,180,0) );
    ReefAngel.PWM.SetChannel( 3, PWMSlope(7,30,21,30,0,35,180,0) );
    ReefAngel.PWM.SetChannel( 4, PWMSlope(7,0,22,0,0,40,180,0) );
    ReefAngel.PWM.SetChannel( 5, PWMSlope(7,30,21,30,0,35,180,0) );
    if (hour()>=8 && hour()<12)
  ReefAngel.PWM.SetDaylight( ReefCrestMode(100,20,true) ); // ReefCrest at 100% +/- 20% on sync mode
  ReefAngel.PWM.SetActinic( ReefCrestMode(100,20,false) ); // ReefCrest at 100% +/- 20% on anti-sync mode
else if (hour()>=12 && hour()<18)
  ReefAngel.PWM.SetDaylight( ShortPulseMode(0,100,200,true) ); // Short pulse at 100% with 200ms pulse on sync mode
  ReefAngel.PWM.SetActinic( ShortPulseMode(0,100,200,false) ); // Short pulse at 100% with 200ms pulse on anti-sync mode
  ReefAngel.PWM.SetDaylight( LongPulseMode(0,100,10,true) ); // Long pulse at 100% with 10s pulse on sync mode
  ReefAngel.PWM.SetActinic( LongPulseMode(0,100,10,false) ); // Long pulse at 6100% with 10s pulse on anti-sync mode
if( ReefAngel.DisplayedMenu==FEEDING_MODE )
   ReefAngel.PWM.SetActinic(0);
   ReefAngel.PWM.SetDaylight(0);
    ReefAngel.Portal( "jjdezek" );
void DrawParamsa(int x, int y){
char buf[16];
  ReefAngel.LCD.DrawText(DPColor,DefaultBGColor,x+60,y+10,"WP40L:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), DPColor, x+78, y+10,1);
ReefAngel.LCD.DrawText(APColor,DefaultBGColor,x+60,y+20,"WP40R:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),APColor, x+78, y+20,1);
  char buf[16];
  // Temp and PH
  y+=10;
  y+=5;
  int t=x;
PostPosted: Tue Jun 11, 2013 12:37 pm
Here is the screen
PostPosted: Tue Jun 11, 2013 12:45 pm
Looking good. Looks like the only thing left is to move the WP40R and WP40L labels over to the left. Something to keep in mind is that characters are 8pixels wide and you replaced two characters (AP and DP) with 5. That should tell you a bit how much to move them over.
PostPosted: Tue Jun 11, 2013 2:02 pm
For the wp40 I have it set at 0,10 and that's where it placed it. It's acting like the temp 1,2,and3 are still there.
PostPosted: Tue Jun 11, 2013 2:49 pm
Lets see the code. Its acting like the temps are still there because that was there default location when i copied the code for you. I suspect its not 0 and 10 as you think
PostPosted: Tue Jun 11, 2013 3:48 pm
I posted the code above the last screen shot
PostPosted: Tue Jun 11, 2013 4:07 pm
I see that! Kudos on creating your own function!!!!
You are indeed passing in 0,10 to your DrawParamsa function but inside that function the first draw is x+60!!!
So now go into your new function and adjust the values. You are well on your way!!
I feel like a proud poppa :D
Return to My PDE/INO file
