PaulTurner911 Code
PostPosted: Fri Jun 14, 2013 3:12 pm
First I would have to thank Lee for "helping" get this dialed in.....
AND BY HELP I MEAN PRETTY MUCH DO IT FOR ME!!
He has been a great help in this from the start.
Currently Running:
Overflow Protection- Shuts down Return Pump
ATO Low Protection- Shuts down Aqua Lifter
Moon Phase from 9pm-10am
ATO/Kalk Doser running for 50sec every 15min from 8pm-12pm
Custom Feed Mode(WP40 off for 30min, Return Pump off for 60min)
WP40 Tidal Modes (Randomized Daily)
Night Mode for the WP40
ReefAngel.FeedingModePorts = Port1Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit | Port8Bit;
ReefAngel.StandardFan( Port2 );
ReefAngel.ActinicLights( Port3 );
ReefAngel.DayLights( Port7 );
ReefAngel.DayLights( Port8 );
//Moonlight Phase 9pm-10am (CH4-CH5)
if ( (hour() >=10) && (hour() <21) )
ReefAngel.PWM.SetChannel( 4,(0) );
ReefAngel.PWM.SetChannel( 5,(0) );
//Pump Delay and Over Flow Protection
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.Off(Port1);
//ATO Protection
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.Off(Port4);
//Kalk Dose 50sec @ 8pm-12pm (every 15min)
if (hour() >=20 || hour() < 12)
ReefAngel.Relay.Set(Port4, now()%900<50);
//Feed Mode Delay on Pump
static boolean feeding=false;
static unsigned long feedingstarted = now();
  if (!feeding)
  feeding=true;
  feeding=false;
///// Place your custom code below here
//IDK Rimai Posted
#define Mem_B_RFMode           VarsStart+55
// Read memory for RF Wave Settings and use for Tunze/Jaebo
int mode=InternalMemory.RFMode_read();
int speed=InternalMemory.RFSpeed_read();
int duration=InternalMemory.RFDuration_read();
// Change this to what you want your min/max based on vortech speed
// This is for those functions that take both, but only one memory slot.
int minOffset=25;
int maxOffset=25;
int min=speed-minOffset;
int max=speed+maxOffset;
// Add random mode if we set to Mode to 12
static int rmode;
if (now()%SECS_PER_HOUR==0) {
  rmode=random(7); // Change the mode once per hour to modes 0-6
if (mode==12) {
  mode=rmode;
// keep wavemakers off for first 30 minutes of feeding mode.
if (now()-feedingstarted<=1800 && ReefAngel.DisplayedMenu==FEEDING_MODE) {
    ReefAngel.PWM.SetDaylight( 0 );
    //ReefAngel.PWM.SetActinic( 0 );
} else if (mode==Constant) {
  // Constant
    ReefAngel.PWM.SetDaylight( speed );
    //ReefAngel.PWM.SetActinic( speed );
} else if (mode==Lagoon) {
    // Lagoon
    ReefAngel.PWM.SetDaylight( SineMode(min,max,duration,true) );
    //ReefAngel.PWM.SetActinic( SineMode(min,max,duration,false) );
} else if (mode==ReefCrest) {
    // Reef Crest
    ReefAngel.PWM.SetDaylight( ReefCrestMode(speed,duration,true) );
    //ReefAngel.PWM.SetActinic( ReefCrestMode(speed,duration,false) );
} else if (mode==ShortPulse) {
    // Short Pulse
    ReefAngel.PWM.SetDaylight( ShortPulseMode(min,max,duration,true) );
    //ReefAngel.PWM.SetActinic( ShortPulseMode(min,max,duration,false) );
} else if (mode==LongPulse) {
    // Long Pulse
    ReefAngel.PWM.SetDaylight( LongPulseMode(min,max,duration,true) );
    //ReefAngel.PWM.SetActinic( LongPulseMode(min,max,duration,false) );
} else if (mode==TidalSwell) {
    // Tidal Swell
    ReefAngel.PWM.SetDaylight( TidalSwellMode(speed,true) );
    //ReefAngel.PWM.SetDaylight( TidalSwellMode(speed,false) );
} else if (mode=NutrientTransport) {
    // Smart_NTM
    ReefAngel.PWM.SetDaylight( NutrientTransportMode(min,max,duration,true) );
    //ReefAngel.PWM.SetActinic( NutrientTransportMode(min,max,duration,false) );
    // Default
    ReefAngel.PWM.SetDaylight( TideMode(speed,minOffset,maxOffset) );
    //ReefAngel.PWM.SetActinic( TideMode(speed,minOffset,maxOffset) );
// Add night mode (constant 30%)
if (now()%SECS_PER_DAY<30600 || now()%SECS_PER_DAY >=81000) { // Time is before 8:30am and after 10:30pm
ReefAngel.PWM.SetDaylight(30);
ReefAngel.Portal( "paulturner911" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
status/chart.aspx?id=Paulturner911&filter=PWMD
Last edited by Paulturner911 on Mon Jun 23, 2014 12:14 pm, edited 2 times in total.
PostPosted: Mon Jun 17, 2013 8:55 am
Try this code, I added the following requested features:
Changed random mode to switch daily instead of hourly
Changed the duration for NTM and short pulse to use a better value (duration * 100) since the argument is milliseconds
Added in the NTM after feeding mode is done. (30 minutes pumps off, then 60 minutes of NTM)
Added indentations to make it readable.
  //ATO Protection
  //IDK Rimai Posted
  // #define Mem_B_RFMode           VarsStart+55
  int minOffset=25;
  int maxOffset=25;
  static int rmode;
  if (now()%SECS_PER_DAY==0 || changeMode=true) { // Change at midnight or if controller rebooted
    rmode=random(7); // Change the mode once per day to modes 0-6
    changeMode=false;
  if (mode==12) {
    mode=rmode;
  static unsigned long feeding;
    feeding = now();
  if (now()-feeding<=1800) { // 30 minutes after
  } else if (now()-feeding<=(1800+3600)) { // // First 30 minutes pump is off.. next 60 minutes will be in NTM
      ReefAngel.PWM.SetDaylight( NutrientTransportMode(min,max,duration*100,true) );
  } else if (mode==Constant) {               // Constant
  } else if (mode==Lagoon) {                 // Lagoon
  } else if (mode==ReefCrest) {              // Reef Crest
  } else if (mode==ShortPulse) {             // Short Pulse
      ReefAngel.PWM.SetDaylight( ShortPulseMode(min,max,duration*100,true) );
  } else if (mode==LongPulse) {              // Long Pulse
  } else if (mode==TidalSwell) {             // Tidal Swell
  } else if (mode=NutrientTransport) {       // Smart_NTM
  } else {                                   // Default
  int x,y;
  x = 15;
  y = 2;
    if ( a>2 ) x = 75;
    if ( a==3 ) y = 2;
    y += 10;
PostPosted: Mon Jun 17, 2013 2:35 pm
Error:
Ivalue required as left operand of assignment
PostPosted: Mon Jun 17, 2013 2:38 pm
It need == instead of =
PostPosted: Mon Jun 17, 2013 3:36 pm
Error
expected unqualified-id before "if"
PostPosted: Mon Jun 17, 2013 3:45 pm
Its this line above that...
It needs a {
PostPosted: Mon Jun 17, 2013 5:25 pm
Thanks guys, it took!!
Lee, what is your duration set at?
If I understand(rarely) I would set it at 25 inorder for reefcrest to run @45 +/-25.
I did this in the portal, while saving all read "OK" but DC Pump Speed & Duration- both ERR
PostPosted: Mon Jun 17, 2013 6:52 pm
The libraries arent supporting dc pump yet.
PostPosted: Mon Jun 17, 2013 7:34 pm
k, just seemed sketchy.
When I select custom in the portal ive only run 45 tonight no change (maybe it randomized 45 constant), Ill check to see if it changes tuesday. Night mode does work though! Just watched it click over.
Could I just remove ones that I dont want to run from this section??
} else { // Default
PostPosted: Mon Jun 17, 2013 7:43 pm
If you pick custom it will just do the tide mode which is almost a constant, unless you changed the mode==12 line.
Otherwise set the RFMode memory to 12 manually.
Next
Return to My PDE/INO file
