PaulTurner911 Code
Re: PaulTurner911 Code
Somethings not right with the current code. The day after feedmode was activated the WP is at zero. Im guessing after NTM it never resumes our random custom mode. Also could you refresh me on the memory location of feedmode timer? Where could I find a list of all memory locations?
It's in the file in libraries/Globals/Globals.
Look for the string VarsStart.
Any chance you could revisit your logic on the feedmode? I've set the feedtime in the memloc to 900 and once that completes the return pump AND the wp turn. I'd like the wp to run NTM for a while before the returns kick on. Any help would be great.
Set the feed mode to however long you want them off. 900 is when ntm kicks on.
This doesn't seem to be the case. I've currently set the feedmode to 1800.... At the 900 mark nothing happens, and 0 all pumps turn on and run NTM.
Did you change 900 in your code at all? The code I posted above sets the speed to 0 only for the first 900 seconds after feeding mode started..then its NTM until 4500 seconds.
Can you set the feeding mode time longer than 1800 and tell me what happens at the 1800 mark?
What is port1 port2 port7 and port8?
I dont have an appropriate file reader to read globals/globals for memory locations.
Ive set the feedmode to 1860 and at 1800 nothing happens. Im assuming that at 960 the NTM should activate, it doesnt.
Port1- RETURN PUMP
2-FANS
7-MH
8-MH
these all turn off in feed mode
this is my code:
// Feeding Mode is 30 minutes
if (now()-feeding<=900) {
// First 15 minutes after feeding mode. Pump is off
ReefAngel.DCPump.Speed=0;
} else if (now()-feeding<=(900+3600)) {
// NTM after 15 minutes for the next 60 minutes
ReefAngel.DCPump.Speed=InternalMemory.DCPumpSpeed_read(); // Resume previous speed
// Night mode (go to 30%)
ReefAngel.DCPump.Speed=30;
ReefAngel.DCPump.Mode=modes[rmode]; // Put the mode to the random mode
Port1- RETURN PUMP
2-FANS
7-MH
8-MH
this is my code:
Im baffled here too...between you and sacohen i feel like im losing my mind...
Roberto binder anyone need a second set of eyes...speed and mode should be reset at 901 seconds..
Sorry... what is exactly that you want?
Sent from my SPH-L710 using Tapatalk 4
I know what the problem is. I'll post something tomorrow. Can you post your full code again.
Try this:
[/quote]
This was the section I modified
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit | Port8Bit;
ReefAngel.DayLights( Port1 ); // Return Pump
ReefAngel.StandardFan( Port2 ); // Canopy Fans
ReefAngel.ActinicLights( Port3 ); // Actinic LEDS
//Port4 Kalk/ATO
//Port5 Kalk Stir
//Port 6 NOT USED (Possibly Skimmer)
ReefAngel.DayLights( Port7 ); // MH 1
ReefAngel.DayLights( Port8 ); //MH 2
//Moonlight Phase 9pm-10am (CH4-CH5)
if ( (hour() >=10) && (hour() <21) )
ReefAngel.PWM.SetChannel( 4,(0) );
ReefAngel.PWM.SetChannel( 5,(0) );
//Over Flow Protection
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.Off(Port1);
//ATO Protection
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.Off(Port4);
//Kalk Dose 60sec @ 11pm-12pm (every 15min)
if (hour() >=23 || hour() < 12)
ReefAngel.Relay.Set(Port4, now()%900<60);
//Kalk Stir 12pm-1pm
if (hour() >=12 & hour() < 13)
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.Off(Port5);
///// Place your custom code below here
static int rmode;
byte modes[] = { ReefCrest, TidalSwell, ShortPulse, NutrientTransport };
changeMode=false;
static unsigned long feeding;
static boolean startFeeding=false;
if (ReefAngel.DisplayedMenu==FEEDING_MODE && startFeeding) {
feeding = now();
startFeeding=false;
startFeeding = true;
static boolean feedingStarted;
if (ReefAngel.DisplayedMenu==FEEDING_MODE && !feedingStarted) {
feedingStarted=true;
feeding = now();
feedingStarted=false;
} else if (now()-feeding<=900+3600)) {
ReefAngel.Portal( "paulturner911" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
feeding = now();
startFeeding=false;
Thanks Lee, Ill let you know in the next few days. I really appreciate it.
No bueno. Ive run the feedmode 3 times set at 1200 and the oven timer set at 15min. the NTM mode does not kick in at 901 (299 in countdown on LCD) Infact, the WP is not calling anymode untill I power cycle the unit, then it calls NTM. Any help would be great.
Here is my current code:
//Port4 Kalk/ATO
//Port5 Kalk Stir
//ATO Protection
static int rmode;
changeMode=false;
feeding = now();
startFeeding=false;
Alright will look at it again soon...are u sure you poaded this code successfully...the full code not editing ur existing????
It looks also like you messed up the if block because i don't see the conditional to go into night mode...the ntm section goes right into night mode. Please also post your full code. Stop pasting blocks.
I believe the code worked but went into night mode instead. Post the full code ill fix it and we'll try again.
Try this:
//Port4 Kalk/ATO
//Port5 Kalk Stir
//ATO Protection
static int rmode;
changeMode=false;
feeding = now();
startFeeding=false;
feeding = now();
} else if (now()%SECS_PER_DAY<30600 || now()%SECS_PER_DAY>=81000) { // 8:30am / 10:30pm
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
Ok not sure where the missing line went between NTM and night mode it was gone for the past few pages. Please try the above code.
I've been following this thread, because I want to set this up eventually and I saw this..lnevo wrote:Im baffled here too...between you and sacohen i feel like im losing my mind....
Sorry man.
No worries... I believe I found the errors... hopefully it should work. You just want the random piece, no?
Yes the randomness of the water modes and the Nutrient Transport Mode after feeding, but like you said wait until we have the other stuff working first.
I've just been following along for now.
Thanks Lee, Ive been tied up and hadnt tried the revised code. The previous COMPLETE code you had posted gave me an error, so I cut in the "modified section" Thats how I ended up with the last (my current) code. Ill use your new code in its entirety and run it this afternoon.
Thank you again for all of your help and patience with us "noncoders"
Let me know if there's a compile error. I'd rather review it then have you potentially load bad code.
Compile error:
redeclaration of 'long unsigned int feeding'
Try this:
That was one of the result of constant merging
//Port4 Kalk/ATO
//Port5 Kalk Stir
//ATO Protection
static int rmode;
changeMode=false;
feeding = now();
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
Compile error:
expected primary-expression before ')' token
