PaulTurner911 Code
Re: PaulTurner911 Code
Sorry... what is exactly that you want?
Sent from my SPH-L710 using Tapatalk 4
I know what the problem is. I'll post something tomorrow. Can you post your full code again.
Try this:
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit | Port8Bit;
ReefAngel.DayLights( Port1 ); // Return Pump
ReefAngel.StandardFan( Port2 ); // Canopy Fans
ReefAngel.ActinicLights( Port3 ); // Actinic LEDS
//Port4 Kalk/ATO
//Port5 Kalk Stir
//Port 6 NOT USED (Possibly Skimmer)
ReefAngel.DayLights( Port7 ); // MH 1
ReefAngel.DayLights( Port8 ); //MH 2
//Moonlight Phase 9pm-10am (CH4-CH5)
if ( (hour() >=10) && (hour() <21) )
ReefAngel.PWM.SetChannel( 4,(0) );
ReefAngel.PWM.SetChannel( 5,(0) );
//Over Flow Protection
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.Off(Port1);
//ATO Protection
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.Off(Port4);
//Kalk Dose 60sec @ 11pm-12pm (every 15min)
if (hour() >=23 || hour() < 12)
ReefAngel.Relay.Set(Port4, now()%900<60);
//Kalk Stir 12pm-1pm
if (hour() >=12 & hour() < 13)
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.Off(Port5);
///// Place your custom code below here
static int rmode;
byte modes[] = { ReefCrest, TidalSwell, ShortPulse, NutrientTransport };
changeMode=false;
static unsigned long feeding;
static boolean startFeeding=false;
if (ReefAngel.DisplayedMenu==FEEDING_MODE && startFeeding) {
feeding = now();
startFeeding=false;
startFeeding = true;
static boolean feedingStarted;
if (ReefAngel.DisplayedMenu==FEEDING_MODE && !feedingStarted) {
    feedingStarted=true;
    feeding = now();
  feedingStarted=false;
// Feeding Mode is 30 minutes
if (now()-feeding<=900) {
  // First 15 minutes after feeding mode. Pump is off
  ReefAngel.DCPump.Speed=0;
} else if (now()-feeding<=900+3600)) {
  // NTM after 15 minutes for the next 60 minutes
  ReefAngel.DCPump.Speed=InternalMemory.DCPumpSpeed_read(); // Resume previous speed
  // Night mode (go to 30%)
  ReefAngel.DCPump.Speed=30;
  ReefAngel.DCPump.Mode=modes[rmode];  // Put the mode to the random mode :)
ReefAngel.Portal( "paulturner911" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
[/quote]
This was the section I modified
feeding = now();
startFeeding=false;
Paulturner911
Post by Paulturner911 »
Thanks Lee, Ill let you know in the next few days. I really appreciate it.
Paulturner911
No bueno. Ive run the feedmode 3 times set at 1200 and the oven timer set at 15min. the NTM mode does not kick in at 901 (299 in countdown on LCD) Infact, the WP is not calling anymode untill I power cycle the unit, then it calls NTM. Any help would be great.
Here is my current code:
//Port4 Kalk/ATO
//Port5 Kalk Stir
//ATO Protection
static int rmode;
changeMode=false;
feeding = now();
startFeeding=false;
} else if (now()-feeding<=(900+3600)) {
Grrr
Alright will look at it again soon...are u sure you poaded this code successfully...the full code not editing ur existing????
It looks also like you messed up the if block because i don't see the conditional to go into night mode...the ntm section goes right into night mode. Please also post your full code. Stop pasting blocks.
I believe the code worked but went into night mode instead. Post the full code ill fix it and we'll try again.
Try this:
//Port4 Kalk/ATO
//Port5 Kalk Stir
//ATO Protection
static int rmode;
changeMode=false;
feeding = now();
startFeeding=false;
  feeding = now();
} else if (now()%SECS_PER_DAY<30600 || now()%SECS_PER_DAY>=81000) { // 8:30am / 10:30pm
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
Ok not sure where the missing line went between NTM and night mode it was gone for the past few pages. Please try the above code.
lnevo wrote:Im baffled here too...between you and sacohen i feel like im losing my mind....
I've been following this thread, because I want to set this up eventually and I saw this..
Sorry man. :(
No worries... I believe I found the errors... hopefully it should work. :) You just want the random piece, no?
Yes the randomness of the water modes and the Nutrient Transport Mode after feeding, but like you said wait until we have the other stuff working first.
I've just been following along for now.
Paulturner911
Thanks Lee, Ive been tied up and hadnt tried the revised code. The previous COMPLETE code you had posted gave me an error, so I cut in the "modified section" Thats how I ended up with the last (my current) code. Ill use your new code in its entirety and run it this afternoon.
Thank you again for all of your help and patience with us "noncoders" :)
Let me know if there's a compile error. I'd rather review it then have you potentially load bad code.
Paulturner911
Compile error:
redeclaration of 'long unsigned int feeding'
Try this:
//Port4 Kalk/ATO
//Port5 Kalk Stir
//ATO Protection
static int rmode;
changeMode=false;
  feeding = now();
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
That was one of the result of constant merging :)
Paulturner911
Compile error:
expected primary-expression before ')' token
Paulturner911
This is my current code, it is not calling NTM at 901 (299 countdown) not modes are acitvated until I power cycle the RA.
//Port4 Kalk/ATO
//Port5 Kalk Stir
//ATO Protection
static int rmode;
changeMode=false;
  feeding = now();
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
It is night mode now...lets try during the day. At least lets see if any difference. We're going to need to do some serial prints and see what is happening better...
Sorry this is messing you up here. I'm going to double check and triple check it all tomorrow. Maybe I will take a different approach and update memory and maybe use some custom vars to get some feedback on where we are...
Paulturner911
Thanks Lee. We had everything correct until we stepped over to the DC Pump Control :X .... I dont think it calls night mode until 10:30 so I think I was clear of that when I ran feedmode. Keep me posted, its not the biggest deal in the world, but Id like to get it up and running.
Me too!!
Ok, I found something obvious that would keep it in Step 1 of our routine...try this:
//Port4 Kalk/ATO
//Port5 Kalk Stir
//ATO Protection
static int rmode;
changeMode=false;
if (ReefAngel.DisplayedMenu!=FEEDING_MODE) feedingStarted=false;
  feeding = now();
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
Paulturner911
No go. It did call NTM at some point after the feedmode timed out, but only the first time I ran it.....The second time it activated another mode. This is not happening immediately after feedmode times out, but within 20min after.
Ok that sounds like some progress...let me work on it.
Ok. I think I got it!!! The issue is we extended feeding mode to the 30. Minutes but tried to change the mode to smart NTM and the speed, but when feeding mode is running the FeedingSpeed setting was overwriting what we were doing.
What we need to do is reduce the feeding timer to 15 minutes and then when we initiate the first 15 minutes after feeding mode we keep the return pump off for the extra 15 minutes while setting smart NTM. Then we can have smart NTM continue for the hour after that.
Please try this:
//Port4 Kalk/ATO
//Port5 Kalk Stir
//ATO Protection
static int rmode;
changeMode=false;
if (now()-feeding<900) {
  // First 15 minutes after feeding mode stops. Return Pump is off
  // First 15 minutes after feeding mode stops. Smart_NTM
} else if (now()-feeding<4500) { // 15 minutes plus 1 hour
  // Continue NTM for the next 60 minutes (75 minutes total)
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
Paulturner911 wrote:Thanks Lee. We had everything correct until we stepped over to the DC Pump Control :X ....
Yeah, the introduction of ReefAngel.DCPump.FeedingSpeed setting I believe was overriding what we were trying to do. This statement helped me to realize the issue. Crossed fingers...
