PaulTurner911 Code
PostPosted: Tue Jun 18, 2013 12:15 pm
OK, I jumped the gun and downloaded it at work. :)
I see in the wizard that you can set the mode, but I see no duration and no "custom" mode. Duration IS in the portal, but still no custom. Will I have a wat to select and randomize Lagoon, ReefCrest, and Long Pulse?
PostPosted: Tue Jun 18, 2013 12:27 pm
I suspect a lot will have to be changed (maybe it will be easy...) in order to incorporate the things we've done. However since it's all in the wizard it might be best to start fresh and go from there... just something to keep in mind.
PostPosted: Tue Jun 18, 2013 12:28 pm
Duration is only available on certain modes.
No custom with the wizard :(
If you are doing custom, you don't need the wizard :)
PostPosted: Tue Jun 18, 2013 12:34 pm
But he wants to utilize the DC Pump portal section... I think it be easiest to start with that fresh from the wizard and add his custom stuff back in after. :)
Also, off topic, but I had no idea new code was pushed :) The sticky with the changelog doesn't show up in New Posts. Can you bump it in the future when a new release is made. :D
PostPosted: Tue Jun 18, 2013 12:37 pm
I think Im going to stick with what Im running and possibly (with Lees help) come up with a way to randomize specific modes. I dont see much difference in the DC or the Vortec menus.....What would I gain in changing?
PostPosted: Tue Jun 18, 2013 12:51 pm
I just looked at the changes made in the libraries. It will be much easier to do everything with that because your whole if else block to look at the functions is all part of the ReefAngel class now.
You've got a lot of custom stuff so yeah, for you it might be easier to leave it for now, once I see how the new stuff is used, I can help you transition to it.
The main benefit will be that since you don't have a RF module, your using the memory locations, but your not tracking changes to speed duration and mode in the portal charts. (i.e. You can't do a chart on RFS for instance (RFSpeed). You can't even look at what that variable has been set for because the portal doesn't track memory addresses.
With the new libraries, the DCS (DC Speed) is now reported by /r99 and will be part of the XML sent to the portal, so you'll be able to view exactly what state your DC Pump is in and not just look at the PWMD output.
Also, since we'll be doing random modes each day you can track what your DCD value looks like to know which mode your controller chose that day :) Lots of cool things.
PostPosted: Tue Jun 18, 2013 1:34 pm
I like the idea of being able to identify what mode it IS or WAS in!! Please keep me posted.
PostPosted: Wed Jun 19, 2013 8:31 am
LOL, back in DEFAULT. UGH!!
Ill wait it out a few, and dabble in the wizard to see what I can do on my own this weekend..... I should be able to get my basic stuff back in after running the wizard, then Ill work on the WP40 stuff.
PostPosted: Wed Jun 19, 2013 7:24 pm
Ive run the wizard and stuck all of the custom in that I thought would not conflict. Basically everything with the exception of the custom feed mode and the custom randomized WP mode. The following was what I would like modified to work with the DC
//Feed Mode Delay on Pump
static boolean feeding=false;
static unsigned long feedingstarted = now();
if (!feeding)
feeding=true;
feeding=false;
///// Place your custom code below here
//IDK Rimai Posted
#define Mem_B_RFMode VarsStart+55
// Read memory for RF Wave Settings and use for Tunze/Jaebo
int mode=InternalMemory.RFMode_read();
int speed=InternalMemory.RFSpeed_read();
int duration=InternalMemory.RFDuration_read();
// Change this to what you want your min/max based on vortech speed
// This is for those functions that take both, but only one memory slot.
int minOffset=25;
int maxOffset=25;
int min=speed-minOffset;
int max=speed+maxOffset;
// Add random mode if we set to Mode to 12
static int rmode;
if (now()%SECS_PER_HOUR==0) {
rmode=random(7); // Change the mode once per hour to modes 0-6
if (mode==12) {
mode=rmode;
// keep wavemakers off for first 30 minutes of feeding mode.
if (now()-feedingstarted<=1800 && ReefAngel.DisplayedMenu==FEEDING_MODE) {
ReefAngel.PWM.SetDaylight( 0 );
//ReefAngel.PWM.SetActinic( 0 );
} else if (mode==Constant) {
// Constant
ReefAngel.PWM.SetDaylight( speed );
//ReefAngel.PWM.SetActinic( speed );
} else if (mode==Lagoon) {
// Lagoon
ReefAngel.PWM.SetDaylight( SineMode(min,max,duration,true) );
//ReefAngel.PWM.SetActinic( SineMode(min,max,duration,false) );
} else if (mode==ReefCrest) {
// Reef Crest
ReefAngel.PWM.SetDaylight( ReefCrestMode(speed,duration,true) );
//ReefAngel.PWM.SetActinic( ReefCrestMode(speed,duration,false) );
} else if (mode==ShortPulse) {
// Short Pulse
ReefAngel.PWM.SetDaylight( ShortPulseMode(min,max,duration,true) );
//ReefAngel.PWM.SetActinic( ShortPulseMode(min,max,duration,false) );
} else if (mode==LongPulse) {
// Long Pulse
ReefAngel.PWM.SetDaylight( LongPulseMode(min,max,duration,true) );
//ReefAngel.PWM.SetActinic( LongPulseMode(min,max,duration,false) );
} else if (mode==TidalSwell) {
// Tidal Swell
ReefAngel.PWM.SetDaylight( TidalSwellMode(speed,true) );
//ReefAngel.PWM.SetDaylight( TidalSwellMode(speed,false) );
} else if (mode=NutrientTransport) {
// Smart_NTM
ReefAngel.PWM.SetDaylight( NutrientTransportMode(min,max,duration,true) );
//ReefAngel.PWM.SetActinic( NutrientTransportMode(min,max,duration,false) );
// Default
ReefAngel.PWM.SetDaylight( TideMode(speed,minOffset,maxOffset) );
//ReefAngel.PWM.SetActinic( TideMode(speed,minOffset,maxOffset) );
Here is my current DC CODE
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit | Port8Bit;
ReefAngel.DayLights( Port1 ); // Return Pump
ReefAngel.StandardFan( Port2 ); // Canopy Fans
ReefAngel.ActinicLights( Port3 ); // Actinic LEDS
//Port4 Kalk/ATO
//Port5 Kalk Stir
//Port 6 NOT USED (Possibly Skimmer)
ReefAngel.DayLights( Port7 ); // MH 1
ReefAngel.DayLights( Port8 ); //MH2
//Moonlight Phase 9pm-10am (CH4-CH5)
if ( (hour() >=10) && (hour() <21) )
ReefAngel.PWM.SetChannel( 4,(0) );
ReefAngel.PWM.SetChannel( 5,(0) );
//Over Flow Protection
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.Off(Port1);
//ATO Protection
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.Off(Port4);
//Kalk Dose 50sec @ 8pm-12pm (every 15min)
if (hour() >=20 || hour() < 12)
ReefAngel.Relay.Set(Port4, now()%900<50);
// Add night mode (constant 30%)
if (now()%SECS_PER_DAY<30600 || now()%SECS_PER_DAY >=81000) { // Time is before 8:30am and after 10:30pm
ReefAngel.PWM.SetDaylight(30);
ReefAngel.Portal( "paulturner911" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
Return to My PDE/INO file
