PaulTurner911 Code
PostPosted: Sat Nov 08, 2014 5:59 am
Thanks! here is my current code
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port6Bit | Port7Bit ;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port6Bit | Port7Bit ;
ReefAngel.LightsOnPorts =  Port3Bit | Port7Bit ;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port6Bit | Port7Bit ;
ReefAngel.Relay.DelayedOn( Port6,120 );
ReefAngel.DayLights( Port1 ); // Return Pump
//Port 2 Chiller
ReefAngel.ActinicLights( Port3 ); // Actinic LEDS
//Port4 Kalk/ATO
//Port5 Kalk Stir
//Port6 Skimmer
ReefAngel.DayLights( Port7 ); // White LEDS
//Port8 Empty
//Moonlight Phase 9pm-10am (CH4-CH5)
if ( (hour() >=10) && (hour() <21) )
ReefAngel.PWM.SetChannel( 4,(0) );
ReefAngel.PWM.SetChannel( 5,(0) );
//Over Flow Protection
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.Off(Port1);
//ATO Protection
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.Off(Port4);
//Kalk Dose 60sec @ 11pm-12pm (every 15min)
if (hour() >=23 || hour() < 12)
ReefAngel.Relay.Set(Port4, now()%900<60);
//Kalk Stir 12pm-1pm
if (hour() >=12 & hour() < 13)
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.Off(Port5);
///// Place your custom code below here
static int rmode;
// Add Else Mode definition..
const int Else=16;
byte modes[] = { Else, Lagoon, Else, ReefCrest, ShortPulse, LongPulse, NutrientTransport };
changeMode=false;
static unsigned long feeding;
if (now()-feeding<900) {
  // First 15 minutes after feeding mode stops. Return Pump is off
  // First 15 minutes after feeding mode stops. Smart_NTM
} else if (now()-feeding<4500) { // 15 minutes plus 1 hour
  // Continue NTM for the next 60 minutes (75 minutes total)
} else if (now()%SECS_PER_DAY<30600 || now()%SECS_PER_DAY>=81000) { // 8:30am / 10:30pm
  // Night mode (go to 30%)
  ReefAngel.DCPump.Speed=30;
  if (modes[rmode]==Else) {
    ReefAngel.DCPump.Speed=ElseMode(InternalMemory.DCPumpSpeed_read(),25,true );    // ElseMode on sync mode, Portal Speed Setting +/- 25%
ReefAngel.Portal( "paulturner911" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
ReefAngel.LCD.DrawOutletBox( 12, 80, TempRelay );
  static unsigned long LastChange=millis();        // Set the inital time that the last change occurred
  static int Delay = random( 500, 3000);           // Set the initial delay
  static int NewSpeed = MidPoint;                  // Set the initial speed
  static int AntiSpeed = MidPoint;                 // Set the initial anti sync speed
  if ((millis()-LastChange) > Delay)               // Check if the delay has elapsed
    Delay=random(500,5000);                        // If so, come up with a new delay
    int ChangeUp = random(Offset);                 // Amount to go up or down
    if (random(100)<50)                            // 50/50 chance of speed going up or going down
    LastChange=millis();                           // Reset the time of the last change
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
The skimmer is still running the schedule of my white leds (old MH Port)
PostPosted: Sat Nov 08, 2014 1:21 pm
That needs to be inside loop with the other ports. Otherwise from what I can see it would just stay off...but definitely wouldn't be doing what it's designed to do.
PostPosted: Mon Nov 10, 2014 9:49 am
THANK YOU!
I HAVE NOTICED THAT THERE ARE NEW MODES ON THE PORTAL FOR THE JAEBO.
HOW WOULD I ADD THESE TO THE RANDOM FUNCTION?
DO I ADD THE NAMES IN HERE-
WRITE THEM EXACTLY AS THE LIST IN THE PORTAL MODES? IS THERE A BRIEF DESCRIPTION OF THE MODES ANYWHERE?
PostPosted: Mon Nov 10, 2014 9:57 am
Yes, just write them as listed in the portal.
This is how I have them in my code...
byte modes[] = { ReefCrest, Lagoon, Constant, TidalSwell, ShortPulse, LongPulse, Else, Gyre };
Really the only new ones are SineMode, Else and Gyre.
Else is a very random flow that emulates the Else mode of the Jebao pumps.
lnevo wrote:A gyre is like when you create a whirlpool in a swimming pool. At some point the momentum builds up and it has a strength of its own. The idea is one run pump in constant for x amount then switch the gyre into another direction.
AlanM wrote:Gyre is just like Long Pulse but with round edges. So it ramps up and back down while the opposing pump is off and then switches. The "duration" argument is in minutes, btw, not seconds, to support longer than 4 minutes. Since "Duration" is a byte number if it was in seconds it would overflow at 255 seconds.
I don't use SineMode it seems to mechanical to me.
PostPosted: Mon Nov 10, 2014 10:14 am
You will need the dev libraries to use the new modes.
PostPosted: Mon Nov 10, 2014 10:19 am
That's correct. I've been using then for a while now and forgot that they were still only in the dev libraries.
PostPosted: Sun Nov 16, 2014 5:37 pm
i havent done anything with the dev libs.
My custom wave mode called "Else" today but stayed at 30% all day. Portal showed else, 70% duration 20...
what wouldnt ti be like reef crest or lagoon mode?
PostPosted: Fri Dec 12, 2014 6:19 pm
Its been getting cold here and I decided to get a heater. I would like to have it on relay port 2 and only come on if the tank is below 74. Could someone please help code this?
//Port 2 Heater
//Port4 Kalk/ATO
//Port5 Empty
ReefAngel.Relay.DelayedOn( Port6,120 );//Port6 Skimmer
//Port8 Empty
//ATO Protection
static int rmode;
byte modes[] = { Else, Lagoon, ReefCrest, ShortPulse, LongPulse, Gyre, NutrientTransport };
changeMode=false;
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
I think this is my most current code! Thanks
PostPosted: Sat Dec 13, 2014 5:23 am
What temp do you want it to go off at? 74 is a bit low though, no?
PostPosted: Sat Dec 13, 2014 9:53 am
I would like it to turn on at 74 and off at 76. I never though I would need a heater here. My last tank had halides and would keep it just under 80. Now I have a chiller, that I run stand alone at 78, and the heater i want on the RA at 75. I want the heater on the RA for failure protection in case it locks ON when it fails, and it will... They both have a +/- 2deg so I assume another degree or two buffer to keep them from cycling each other. Any and all help is appreciated!
Return to My PDE/INO file
