PaulTurner911 Code
PostPosted: Sat Dec 13, 2014 10:14 am
ReefAngel.StandardHeater(Port2,74,76);
PostPosted: Sat Dec 13, 2014 10:58 am
I put it below void loop, it didnt activate after upload. Should I have it below void setup? I also changed it to 75 :)
**Put it in both and it still hadnt turned the heater on.
I lost one of my codes and modified the second most recent but also update the libs. I could use a set of eyes on my current code. I think i put everything back and removed the ELSE definition because its in the libs now and was giving an error.
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port6Bit | Port7Bit ;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port6Bit | Port7Bit ;
ReefAngel.LightsOnPorts =  Port3Bit | Port7Bit ;
ReefAngel.OverheatShutoffPorts = Port1Bit |Port2Bit | Port3Bit | Port6Bit | Port7Bit ;
// Heater (75-76)
ReefAngel.StandardHeater(Port2,75,76);
ReefAngel.Relay.DelayedOn( Port1,1 ); // Return Pump
//Port 2 Heater (75-76)
ReefAngel.ActinicLights( Port3 ); // Actinic LEDS
//Port4 Kalk/ATO
//Port5 Empty
ReefAngel.Relay.DelayedOn( Port6,120 );//Port6 Skimmer
ReefAngel.DayLights( Port7 ); // White LEDS
//Port8 Empty
//Moonlight Phase 9pm-10am (CH4-CH5)
if ( (hour() >=10) && (hour() <21) )
ReefAngel.PWM.SetChannel( 4,(0) );
ReefAngel.PWM.SetChannel( 5,(0) );
//Over Flow Protection
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.Off(Port1);
//ATO Protection
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.Off(Port4);
//Kalk Dose 60sec @ 11pm-12pm (every 15min)
if (hour() >=23 || hour() < 12)
ReefAngel.Relay.Set(Port4, now()%900<60);
///// Place your custom code below here
static int rmode;
byte modes[] = { Else, Lagoon, ReefCrest, ShortPulse, LongPulse, Gyre, NutrientTransport };
changeMode=false;
static unsigned long feeding;
if (now()-feeding<900) {
  // First 15 minutes after feeding mode stops. Return Pump is off
  // First 15 minutes after feeding mode stops. Smart_NTM
} else if (now()-feeding<4500) { // 15 minutes plus 1 hour
  // Continue NTM for the next 60 minutes (75 minutes total)
} else if (now()%SECS_PER_DAY<30600 || now()%SECS_PER_DAY>=81000) { // 8:30am / 10:30pm
  // Night mode (go to 30%)
  ReefAngel.DCPump.Speed=30;
  if (modes[rmode]==Else) {
    ReefAngel.DCPump.Speed=ElseMode(InternalMemory.DCPumpSpeed_read(),25,true );    // ElseMode on sync mode, Portal Speed Setting +/- 25%
ReefAngel.Portal( "paulturner911" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
ReefAngel.LCD.DrawOutletBox( 12, 80, TempRelay );
Thank you!!
PostPosted: Sat Dec 13, 2014 12:31 pm
The temp in your tank is 76.2 it won't go on until it drops below 75.
PostPosted: Sun Dec 14, 2014 6:42 am
I checked the relay activity, it didnt activate port 2. I woke up and took it off the RA and plugged it in to a power strip and cranked the house heater.
Please help
PostPosted: Sun Dec 14, 2014 7:10 am
Where'd you put it in the code? Can you post again?
PostPosted: Sun Dec 14, 2014 7:13 am
Actually your code looks fine. Not sure why its not on. Are you sure you loaded the code above?
PostPosted: Sun Dec 14, 2014 7:43 am
I have the code in both viod setup and viod loop, i was not sure where to put it, it compiles fine in both locations within the code.
This whats on there, uploaded it once with 74 as the activation, then 75. My chiller and RA are pretty far off on calibration. Ill throw a third on there to try to get an average and set the chillers correction factor. Ill upload it again and triple check.
// Heater (75-76)
//Port4 Kalk/ATO
//Port5 Empty
//Port8 Empty
//ATO Protection
static int rmode;
changeMode=false;
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
Its uploading without any issues... Port 2 is still not on
Something in my code conflicting? Could it have to do with the internal memory setting in the portal? I have assigned temps to them , but how would they know the ports for the chiller and heater?
Could or should I run the wizard again and cut my code in?
PostPosted: Sun Dec 14, 2014 10:15 am
The internal memory is not used with the command i gave you.
For now i recommend just manually tirn the port on and rely on the heater thermostat plus you have the chiller. I'm not sure why its not working. It should also be in loop not setup.
PostPosted: Mon Dec 15, 2014 12:55 pm
Ok, Ill remove it from the void setup section.
I would really like to have this functioning properly in the near future? What can I do to help troubleshoot? Can i confirm the file on the RA? Like I said, it should give an error if the RA was not taking the code, its uploading fine all around.
PostPosted: Mon Dec 15, 2014 1:02 pm
Maybe Roberto could take a look. I dont have an extra probe I can test with at the moment but I don't see anything wrong. I'll try and take another look later tonight.
Return to My PDE/INO file
