PaulTurner911 Code
PostPosted: Wed Dec 24, 2014 10:38 am
Patch submitted. There's now functions for StandardHeater2 and StandardHeater3 same for StandardFan. And if you pass a temp param less than 100 it will be multiplied by 10.
PostPosted: Sat Mar 07, 2015 10:47 am
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit ;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit ;
ReefAngel.LightsOnPorts =  Port7Bit | Port3Bit ;
ReefAngel.OverheatShutoffPorts = Port1Bit |Port2Bit | Port3Bit | Port5Bit| Port6Bit | Port7Bit| Port8Bit ;
ReefAngel.Relay.DelayedOn( Port1,1 ); // Return Pump
ReefAngel.Relay.DelayedOn( Port2,90 );// Skimmer
ReefAngel.ActinicLights( Port3 ); // Actinic LEDS
ReefAngel.StandardFan(Port4,790,800);//Chiller 79-80
ReefAngel.StandardHeater(Port5,750,760);//Heater 75-76
//Port6 Kalk/ATO
ReefAngel.DayLights( Port7 ); // White LEDS
//Port 8 Empty
//Moonlight Phase 9pm-10am (CH4-CH5)
if ( (hour() >=10) && (hour() <21) )
ReefAngel.PWM.SetChannel( 4,(0) );
ReefAngel.PWM.SetChannel( 5,(0) );
//Over Flow Protection
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.Off(Port1);
//ATO Protection
ReefAngel.Relay.On(Port6);
ReefAngel.Relay.Off(Port6);
//Kalk Dose  10pm-11pm
if (hour() >=22 || hour() < 23)
///// Place your custom code below here
static int rmode;
byte modes[] = { Else, Lagoon, ReefCrest, ShortPulse, LongPulse, Gyre, NutrientTransport };
changeMode=false;
static unsigned long feeding;
if (now()-feeding<900) {
  // First 15 minutes after feeding mode stops. Return Pump is off
  // First 15 minutes after feeding mode stops. Smart_NTM
} else if (now()-feeding<4500) { // 15 minutes plus 1 hour
  // Continue NTM for the next 60 minutes (75 minutes total)
} else if (now()%SECS_PER_DAY<30600 || now()%SECS_PER_DAY>=81000) { // 8:30am / 10:30pm
  // Night mode (go to 30%)
  ReefAngel.DCPump.Speed=30;
  if (modes[rmode]==Else) {
    ReefAngel.DCPump.Speed=ElseMode(InternalMemory.DCPumpSpeed_read(),25,true );    // ElseMode on sync mode, Portal Speed Setting +/- 25%
ReefAngel.Portal( "paulturner911" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
ReefAngel.LCD.DrawOutletBox( 12, 80, TempRelay );
I coded this and the ATO should only run from 10pm-11pm in my eyes. BUT, It doesnt seem to function correctly since I just uploaded and its 12.45pm and Port6 is ON. Any help would be great.
PostPosted: Sat Mar 07, 2015 11:25 am
Change the || to &&
PostPosted: Sat Mar 07, 2015 2:46 pm
Thank You!!
PostPosted: Sun Jun 14, 2015 11:16 am
Any idea what kind of run time I should get with two pumps on the Jeabo battery backup kit...??
Previous
Return to My PDE/INO file
